Visitors: 87
Total: 87
02: Home
59: Event Calendar
Psuedo Class 11
1 2 3 ... 8 9 10 ... 12 13 14
Posted: Tue Jan 17, 2012 04:52 AM
The engine has 5,000 miles on it. It is leaking along the case seam, mostly towards the front. I will look closer tomorrow, but it didn't look like oil was above the front of the seam.
Posted: Wed Jan 18, 2012 01:53 AM
I cleaned off the case and ran it for a few minutes...no leak. I shut it off and a few minutes later I saw a drip develop at the surface between the engine and trans. My guess is main seal. Sound like the right prognosis?
What causes this in 5,000? How can I prevent it from happening again?
Posted: Wed Jan 18, 2012 02:38 AM
If the oil is leaking out between the engine case and the transmission it is a good chance the main seal is the culprit. Failure at 5k miles seems odd. Could have been a defective seal or something like that.
Posted: Wed Jan 18, 2012 09:19 AM
I had to replace a flywheel that ad leakage issues a couple of years ago. It had pitting in the flywheel where the seal rides. I tried sanding out the pits, but the deeper I sanded, the bigger the pits got. It was as if they were flaws in the metal of the flywheel. The pits were too deep to sand out and still have enough diameter for the seal to still contact it.
Posted: Thu Jan 19, 2012 01:33 AM
I drained oil tonight and will pull engine tomorrow. Dirtjunkie is coming over on Sat to give me a hand. What a guy! Thanks Eric!
Posted: Thu Jan 19, 2012 02:37 AM
TIRES IN THE HOUSE!
Mondays order arrived today. My garage smells like a tire shop! Come get them whenever. Just make sure I'm here of course.
Posted: Thu Jan 19, 2012 05:31 AM
I just picked them up. Thanks again Tony for your williness to help and your friendship.
Posted: Thu Jan 19, 2012 07:38 AM
Damn I can smell it...and i like IT!!!
What can one DO......
Posted: Thu Jan 19, 2012 07:45 AM
As far as the oil leak....it doesnt seem to be running down the whole seam or is it.....looks to be right there at a pry point.
Any CASE history????
Posted: Thu Jan 19, 2012 12:39 PM
I caught the picture of the drip as it was happening. It continues to flow and spreads down the case. Here is a picture before I wiped it off:
Disregard the RTV on the bolt. That will be repaired this weekend as well.
Posted: Thu Jan 19, 2012 03:54 PM
I dont see any oil coming down from behind the flywheel in the first shot.....hmmm
Posted: Sun Jan 22, 2012 06:07 AM
I had help today from Dirtjunkie. I replaced the main seal, although it still looked good. However there was no o ring for the flywheel, just some material of some sort in the groove. I cleaned that out and put a new o ring in. I tightened all my bolts I could get to, and used degreaser on the engine. I also repaired a oil strainer stud. When I had changed the oil last time, I found one was loose and had something in the threads similar to JB Weld. I had put a 1/4"x20 stud in at the time to hold it, but repaired it properly today by drilling and tapping it for a 8mm to 6mm step stud. Went nice and slow and used grease in the bit and tap. Plugged the large hole where the strainer went with paper towels and my son held a vacuum next to the bit while I drilled (Good advice Dirtjunkie!!!). Used blue locktight on the stud and buttoned everything up. Mounted the original exhaust back on and mounted my new Grabber tires. We'll see if it has a big leak in the morning...
Posted: Sun Jan 22, 2012 11:29 PM
No big leak! Small drip on the case, something I can live with..I think.
Posted: Mon Jan 23, 2012 03:13 AM
I found some inexpensive foam floar covering at Big Lots that I installed for a headliner. It use to be a sunroof so making something work around the framework required material with a little stiffness. I hope it works out.
Posted: Sun Jan 29, 2012 06:16 AM
I put an alternator on a few months ago on a 1385cc with a Solex 30pict1 and while driving on fwy for 40+ miles, it slightly hesitates or sputters. I take my foot off of the gas and put it back on and it is fine for a while, then does the same thing. It never dies. My tank doesn't have a vent, and my metal filter is under the tank. I noticed my fuel line almost lays on top of my heater box, but doesn't touch (3" body lift). I'm curious where to start?
Thanks,
John
25 Kreed 26751 3" Body Lift, Class 11...
 Tue Apr 10, 2018 02:26 PM
Kreed View latest post
No new posts Projects and Builds New Class 11 Build - PepeBlanco 4 pepeazul 5373 New Class 11 Build - P...
60 wideopenmotorsports 48064 CLASS 5 Resurrection!
 Mon Feb 22, 2016 05:23 PM
No new posts VW Volkswagen & Baja Bug General Discussion 5-1600 vs Class 11 Version 3 2 wideopenmotorsports 3475 5-1600 vs Class 11 Ver...
 Thu Oct 08, 2015 08:12 PM
No new posts Projects and Builds Class 11 PepeAzul 3 pepeazul 5628 Class 11 PepeAzul
 Fri Jul 17, 2015 02:29 PM
