Latest: strike77
Overall: 3575
Visitors: 142
Total: 142
02: My Account
17: My Account
30: Home
67: My Account
76: Pictures
82: Event Calendar
89: My Account
111: Home
129: My Account
134: Home
135: My Account
136: Home
1 2 3 ... 72 73 74 ... 103 104 105
Posted: Tue Jan 03, 2012 01:23 AM
What can one DO......
Posted: Fri Jan 06, 2012 06:12 PM
Hit something hard enough to pull out the drivers side lower control arm.
It broke the torsion leaves where the grub nut goes. I just tightened it up as I want to go to coil over as I need new leaves and shocks and 4 sets of leaves and new shocks rival coil over prices.
I also fixed a persistant oil leak that dumped a good two foot trail when I came home form Sycamore last Sunday. Now it is drip free again.
Posted: Mon Jan 09, 2012 12:36 AM
Installed door seals and took off my roof rack to sell. :^(
Posted: Wed Jan 11, 2012 09:06 AM
CUT UP.....my best girl.
Damn that hurts!>!>!>
Posted: Wed Jan 11, 2012 01:35 PM
Put on some 27x8.50r14 rear tires and rims I am borrowing to see how it effects my gearing.
Posted: Thu Jan 12, 2012 06:15 AM
And?
Posted: Thu Jan 12, 2012 01:36 PM
And?
Based on the weight of my car, size of engine and gearing, the 27x8.5r14 makes a difference. They seem small though.
Posted: Sat Jan 14, 2012 05:30 PM
Put the header and quietpack back on.
Posted: Sat Jan 14, 2012 10:16 PM
Clean parts, cleaned more parts, sanded parts and then sanded parts. Paint is soon.
Posted: Sun Jan 15, 2012 07:00 PM
Finished plumbing the oil lines and the oil hose separators and mounted them. received new racing lug nuts from summit so I studded the drums and installed. Installed new shoes and wheel cylinders on the front of the car. Installed front turn signals and finished up the wiring for those.
More to do today.
Posted: Sun Jan 15, 2012 09:19 PM
I installed my front hood seal, tighted the bolts on my case (small leak), and tightened my header I installed this week.
Posted: Tue Jan 17, 2012 04:57 AM
Just ordered two 7.00-15 General Grabbers for the front of the 5-1600. They will be replacing the 235's I have right now.
Posted: Tue Jan 17, 2012 05:03 AM
put the front beam back on the rail project.
Posted: Tue Jan 17, 2012 05:27 AM
Went for a drive today around Lake Pleasant. Fun offroading. Found holes in my header and muffler. Going to pull it off and go back to stock exhaust for now.
Found that the case is leaking pretty good now along the front split. I pulled my front tires off in preparation for the new General Grabber AT2 205/75r15 that WideOpenMotorsports ordered me today.
Posted: Thu Jan 19, 2012 08:53 AM
Tipped my cow over on its side.
Ya gotta luv this car!!!!!
VW4LIFE
4 Admin_AzBaja 5900 Baja Bugs on Wiki need...
285 MusicManiac 223576 Re: Baja sightings
No new posts VW Volkswagen & Baja Bug General Discussion Had to go play in the rain today! 1 azdesertrat87 63 Re: Had to go play in ...
 Mon Jul 16, 2018 08:00 PM
0 Northmountainauto 662 Shop Baja
No new posts New Members Baja hiding in Chandler 9 Upsbaja 2302 Baja hiding in Chandle...
