Visitors: 145
Total: 145
28: Home
32: Event Calendar
42: Event Calendar
45: Home
76: Event Calendar
78: Home
108: My Account
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Changing over to 3-rib bus trans... maybe?
planenutz
planenutz
Post Post subject: Changing over to 3-rib bus trans... maybe?
Posted: Mon Jan 16, 2012 03:51 AM
I got a price from a guy of $900 for everything: used 3-rib trans (low miles, of course..), 930 CV's, and stub axles. Is that too high of a price for a package deal?
Thanks
Post Post subject: Re: Changing over to 3-rib bus trans... maybe?
Posted: Mon Jan 16, 2012 04:07 AM
If the trans is not built then $900 is a bit too much in my opinion. The trans is the key to everything. Check to see who built the trans and what is in it.
planenutz
planenutz
Posted: Mon Jan 16, 2012 04:12 AM
From what I gathered, the trans is bone stock. It was a project that he lost interest in a few years ago and is getting ready to sell now. Sounded like the CV's and stub axles might be used also.
What would a good counter offer be?
ROCKSLAYER
ROCKSLAYER
Posted: Mon Jan 16, 2012 05:18 AM
sounds a bit high if the 3 x 3 arms are not included.i picked up a built 002 bus tranny,chromemoly 3 x3 rear arms,wide 5 disc brakes ,axles,930 cvs stubs complete in excellent condition for 1200.00 .
Posted: Tue Jan 17, 2012 07:22 PM
Price out a rebuilt, the core charge and new axles and cvs.
I'm gonna guess KNOWN good used tranaxle $300 used axles and cvs $300
Posted: Wed Jan 18, 2012 04:16 AM
Unless you are putting a bone stock T2 trans back into a bus, it is no more than a core. You will need to have it geared for the tire/engine combo used and beefed up for off road use.
If you will not be doing any heavy duty off roading, then build up a nice T1 trans. If you are definitely going long travel and are going to beat it up off road then go T2.
gman3850
Colonel
Colonel
gman3850
Posted: Wed Jan 18, 2012 05:02 AM
if your looking for a built t1 ive got one for sale
Posted: Wed Jan 18, 2012 05:20 AM
[quote="wideopenmotorsports"]Unless you are putting a bone stock T2 trans back into a bus, it is no more than a core. You will need to have it geared for the tire/engine combo used and beefed up for off road use.
I don't race but have been known to play a bit hard and have had pretty good luck with known good used 3 ribs but I try not to abuse them. Granted I'd like to lower 3/4 gears about 10% just to get them a bit closer but for the highway stock 4th gear runs 3000 rpms @ 65 mph with the 33" tires I have. It does make sense if one is going to get it rebuilt to get it race prepped ahead of time. I'm with you 100% on it just just being worth core value if you can't take one for a test drive.
Posted: Wed Jan 18, 2012 06:55 AM
Dons Bus Box gets $400 for a core trans, Axles are worth $200, Offer $600 or just buy a rebuilt one if he turns it down.
planenutz
planenutz
Posted: Wed Jan 18, 2012 08:19 AM
alright, thanks guys. I appreciate the advice.
planenutz
planenutz
Posted: Wed Jan 18, 2012 08:20 AM
No new posts VW Volkswagen & Baja Bug General Discussion needed asap swing axle trans 5 Dirtjunkie 2846 needed asap swing axle...
 Fri Oct 12, 2012 06:10 AM
17 TwistedMetal 13677 Which trans with a 22r...
 Mon Dec 05, 2011 01:51 AM
chrispy56 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Instructions to install 002 trans. in 1969 1600 Baja?J 12 glenf 10985 Re: Instructions to in...
 Fri Apr 24, 2009 06:45 PM
DONT View latest post
No new posts VW Volkswagen & Baja Bug General Discussion trans adapter for 1.6 hyundai motor 1 trumpit 1889 Re: trans adapter for ...
 Wed Dec 17, 2008 05:03 PM
No new posts VW Volkswagen & Baja Bug General Discussion Value of a great running 1974 1600 and trans? 2 TwistedMetal 1439 Re: Value of a great r...
 Mon Oct 27, 2008 07:11 AM
TwistedMetal View latest post
