Visitors: 255
Total: 255
13: Pictures
14: Home
16: Pictures
96: Pictures
99: Pictures
114: Event Calendar
118: Pictures
138: Event Calendar
150: Baja Forums
161: Event Calendar
166: Event Calendar
170: Pictures
171: Pictures
179: Event Calendar
180: Baja Forums
183: Baja Forums
185: Baja Forums
190: AMAZON.com
197: AMAZON.com
198: AMAZON.com
202: AMAZON.com
203: Baja Forums
204: Baja Forums
205: AMAZON.com
207: Baja Forums
208: AMAZON.com
209: AMAZON.com
210: Baja Forums
211: Baja Forums
212: Baja Forums
213: Baja Forums
214: Baja Forums
215: Baja Forums
217: Baja Forums
218: Baja Forums
219: Baja Forums
220: Baja Forums
221: AMAZON.com
223: My Account
224: Baja Forums
225: Event Calendar
226: AMAZON.com
227: AMAZON.com
229: AMAZON.com
230: Event Calendar
231: Baja Forums
232: AMAZON.com
233: AMAZON.com
234: AMAZON.com
235: AMAZON.com
236: Baja Forums
237: AMAZON.com
238: AMAZON.com
239: AMAZON.com
240: AMAZON.com
241: Baja Forums
242: AMAZON.com
243: AMAZON.com
244: AMAZON.com
245: AMAZON.com
246: Home
247: Baja Forums
248: Event Calendar
249: AMAZON.com
250: AMAZON.com
251: AMAZON.com
252: Baja Forums
253: Pictures
254: AMAZON.com
255: AMAZON.com
FABINC 5-1600 Build
1 2 3 4 5 6 7 8 9
Posted: Sun Nov 27, 2011 03:33 AM
Got the exhaust built and the motor/trans in.
Tailight/turn signals, dual coils mounted along with the oil filter adapter.
Used 6" offroad lights and rewired with DOT legal HI/LOW beam halogen units.
Started the wiring for lights and engine. Also need to plumb the lines for the oil cooler which is now inside the car. My plan is to have it on the road the first of the year.
Posted: Sun Nov 27, 2011 07:27 PM
Planning on using a fuse panel and several relays for all the lights and accessories. Lots to do.
Posted: Tue Nov 29, 2011 07:30 AM
Its looking pretty sweet....Really liking the stock arm look.
Tires nice and tight to the torsion.
What can one DO......
Posted: Tue Dec 20, 2011 01:23 AM
Got a little more work done. Still chasing a few wiring gremlins, but it is coming along nicely. Hope to start it this weekend and then start testing.
Added another light to the front. The middle one fills the space nicely.
Found these fasteners at Lowes. I was not going to put the trim back on and I think these fill the trim holes and look relatively clean.
Started the plumbing for the oil lines.
Routed lines through the body and protected them with some grommets.
Finished product. Lines nice and tight. Just need to build an oil line support bracket and I can cross this off the list.
Posted: Tue Dec 20, 2011 04:10 AM
NICE WORK
Posted: Tue Dec 20, 2011 04:17 PM
It looks like the list is getting shorter.
Posted: Wed Dec 21, 2011 11:27 AM
Question What are those fasteners? They look like plastic rivets. My son is thinking of using pop rivets in his. More info please?
Posted: Wed Dec 21, 2011 11:40 AM
I suggest some sort of strap to support the Supertrapp off the exhaust.
I like the idea for the headlights. Are those EMPI 6" offroad lights? The H5006 units fit right in? Cool
Don't forget to wire for a license plate light and a dust light.
Posted: Thu Dec 22, 2011 10:38 PM
In regards to the exhaust. It came with a bracket. Just have not installed it yet.
Lights fit the housings perfectly with no modifications.
The plastic pieces are in the automotive fastener section at lowes. They have several different styles and sizes. Mine are made for a gm product vehicle.
Posted: Mon Jan 09, 2012 04:33 AM
Got a little more work done this weekend. Started with the off road air cleaner
setup.
Elbow is from Lowes plumbing Dept. A little modification and it worked great. Flexible hose is from a Ford Explorer. 25¢ at a local parts swap. Air cleaner is an off road unit from Latest Rage.
Fits nice an tight up under the rear cage.
Posted: Mon Jan 09, 2012 04:36 AM
Also wanted to create some spacers to keep the oil lines from touching.
Just need to buy some hose clamps to hold it all together.
Last edited by wideopenmotorsports on Mon Jan 09, 2012 04:40 AM; edited 1 times in total
Posted: Mon Jan 09, 2012 04:38 AM
Also finished up the wiring for the majority of the car.
Just a few more things to go.
Posted: Mon Jan 09, 2012 04:39 AM
NICE mod!!!
Posted: Mon Jan 09, 2012 04:57 AM
I saw this rock n rolling machine yesterday...VERY COOL!
Posted: Mon Jan 09, 2012 03:54 PM
Nice job on the wiring.
1 2 3 4 5 6 7 8 9
26 1963BAJA 7400 The Socal Honda Build
 Fri Jun 23, 2017 12:15 AM
1963BAJA View latest post
Cheapskate special
26 Azdrtdog 11495 New father/son budget ...
 Fri Jun 16, 2017 10:26 PM
No new posts Projects and Builds New Class 11 Build - PepeBlanco 4 pepeazul 5254 New Class 11 Build - P...
101 SuburbanLegend 134802 Carbon Footprint...aka...
 Thu Oct 08, 2015 08:28 PM
No new posts VW Volkswagen & Baja Bug General Discussion 5-1600 vs Class 11 Version 3 2 wideopenmotorsports 3397 5-1600 vs Class 11 Ver...
 Thu Oct 08, 2015 08:12 PM
