Visitors: 114
Total: 114
01: Home
03: Home
51: Event Calendar
81: Links
96: Event Calendar
105: Home
1 2 3 ... 72 73 74 ... 103 104 105
Posted: Tue Jan 03, 2012 12:23 AM
What can one DO......
Posted: Fri Jan 06, 2012 05:12 PM
Hit something hard enough to pull out the drivers side lower control arm.
It broke the torsion leaves where the grub nut goes. I just tightened it up as I want to go to coil over as I need new leaves and shocks and 4 sets of leaves and new shocks rival coil over prices.
I also fixed a persistant oil leak that dumped a good two foot trail when I came home form Sycamore last Sunday. Now it is drip free again.
Posted: Sun Jan 08, 2012 11:36 PM
Installed door seals and took off my roof rack to sell. :^(
Posted: Wed Jan 11, 2012 08:06 AM
CUT UP.....my best girl.
Damn that hurts!>!>!>
Posted: Wed Jan 11, 2012 12:35 PM
Put on some 27x8.50r14 rear tires and rims I am borrowing to see how it effects my gearing.
Posted: Thu Jan 12, 2012 05:15 AM
And?
Posted: Thu Jan 12, 2012 12:36 PM
And?
Based on the weight of my car, size of engine and gearing, the 27x8.5r14 makes a difference. They seem small though.
Posted: Sat Jan 14, 2012 04:30 PM
Put the header and quietpack back on.
Posted: Sat Jan 14, 2012 09:16 PM
Clean parts, cleaned more parts, sanded parts and then sanded parts. Paint is soon.
Posted: Sun Jan 15, 2012 06:00 PM
Finished plumbing the oil lines and the oil hose separators and mounted them. received new racing lug nuts from summit so I studded the drums and installed. Installed new shoes and wheel cylinders on the front of the car. Installed front turn signals and finished up the wiring for those.
More to do today.
Posted: Sun Jan 15, 2012 08:19 PM
I installed my front hood seal, tighted the bolts on my case (small leak), and tightened my header I installed this week.
Posted: Tue Jan 17, 2012 03:57 AM
Just ordered two 7.00-15 General Grabbers for the front of the 5-1600. They will be replacing the 235's I have right now.
Posted: Tue Jan 17, 2012 04:03 AM
put the front beam back on the rail project.
Posted: Tue Jan 17, 2012 04:27 AM
Went for a drive today around Lake Pleasant. Fun offroading. Found holes in my header and muffler. Going to pull it off and go back to stock exhaust for now.
Found that the case is leaking pretty good now along the front split. I pulled my front tires off in preparation for the new General Grabber AT2 205/75r15 that WideOpenMotorsports ordered me today.
Posted: Thu Jan 19, 2012 07:53 AM
Tipped my cow over on its side.
Ya gotta luv this car!!!!!
VW4LIFE
4 Admin_AzBaja 5200 Baja Bugs on Wiki need...
285 MusicManiac 208993 Re: Baja sightings
Off-road event
1 wideopenmotorsports 348 Re: Baja run in March
 Mon Jan 08, 2018 05:09 PM
No new posts VW Volkswagen & Baja Bug General Discussion Considering buying a Baja Bug, but I have questions 4 AutomotiveDino 3296 Considering buying a B...
 Mon Jun 19, 2017 09:39 AM
daelan37 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion What is my Baja really worth? 1 Treeposter 942 What is my Baja really...
 Sat Jun 17, 2017 04:06 PM
