Visitors: 307
Total: 307
20: Event Calendar
54: Pictures
55: Pictures
56: Pictures
57: Pictures
60: Event Calendar
62: Event Calendar
89: Event Calendar
99: Event Calendar
150: Baja Forums
157: Event Calendar
161: Event Calendar
164: Event Calendar
169: Event Calendar
171: Event Calendar
172: Event Calendar
173: Baja Forums
180: Baja Forums
181: Baja Forums
182: Baja Forums
190: AMAZON.com
191: Event Calendar
193: Baja Forums
195: Baja Forums
197: AMAZON.com
198: Pictures
202: AMAZON.com
204: AMAZON.com
205: AMAZON.com
207: AMAZON.com
208: AMAZON.com
209: AMAZON.com
210: AMAZON.com
212: Baja Forums
213: Baja Forums
214: Groups
218: Event Calendar
219: Baja Forums
220: Baja Forums
221: Baja Forums
222: Baja Forums
223: Baja Forums
225: Baja Forums
226: AMAZON.com
227: Baja Forums
229: Baja Forums
230: AMAZON.com
231: Event Calendar
232: AMAZON.com
233: AMAZON.com
234: AMAZON.com
235: AMAZON.com
236: Event Calendar
237: Event Calendar
238: AMAZON.com
239: AMAZON.com
240: AMAZON.com
241: AMAZON.com
242: AMAZON.com
243: AMAZON.com
244: Baja Forums
245: Baja Forums
246: AMAZON.com
247: AMAZON.com
248: AMAZON.com
249: Baja Forums
250: AMAZON.com
251: AMAZON.com
252: Baja Forums
253: Baja Forums
254: Baja Forums
255: Baja Forums
256: Baja Forums
257: Baja Forums
258: Baja Forums
259: Baja Forums
260: Baja Forums
261: Baja Forums
262: Baja Forums
263: Baja Forums
264: Baja Forums
265: AMAZON.com
266: Baja Forums
267: AMAZON.com
268: AMAZON.com
269: AMAZON.com
270: AMAZON.com
271: Pictures
272: AMAZON.com
273: AMAZON.com
274: AMAZON.com
275: AMAZON.com
276: AMAZON.com
277: AMAZON.com
278: AMAZON.com
279: AMAZON.com
280: AMAZON.com
281: AMAZON.com
282: AMAZON.com
283: AMAZON.com
284: AMAZON.com
285: Baja Forums
286: AMAZON.com
287: AMAZON.com
288: AMAZON.com
289: AMAZON.com
290: AMAZON.com
291: AMAZON.com
292: Baja Forums
293: AMAZON.com
294: AMAZON.com
295: AMAZON.com
296: AMAZON.com
297: AMAZON.com
298: Baja Forums
299: Baja Forums
300: Baja Forums
301: AMAZON.com
302: AMAZON.com
303: AMAZON.com
304: AMAZON.com
305: AMAZON.com
306: AMAZON.com
307: AMAZON.com
Bill's Baja project
1 2 3 4 5 6 7 8 9
allisontech
allisontech
Posted: Thu Dec 01, 2011 01:27 AM
Ran into another question tonight, The trailing arms I have from Dons are the heavy duty stock width,sheet metal, 1" longer type,the rear brake kit I have is the E brake disc type,I have found the standard weld on brackets I bought for the trailing arms are to small,"The bolt holes are to close together"they are made for the non E brake small calipers. Does anyone make a larger weld on bracket, or am I going to have to fab one up from some 1/4" plate?
It's a never ending adventure I tell ya, at least I'm finding this stuff before I get to that point in the build!
allisontech
allisontech
Posted: Sun Dec 04, 2011 04:50 PM
Finally replaced both door pillars this weekend,hung both the doors temporarily to be sure everything will adjust out. Then we pulled the body off the pan. Now the fun can begin!
Time to start installing some parts!!
DeathBug
DeathBug
Posted: Mon Dec 05, 2011 08:06 PM
oh yeah... Cool let the fun begin..!!! Nice well organized garage...
allisontech
allisontech
Posted: Wed Dec 14, 2011 02:57 AM
been working my butt of the last two weeks, I managed to get the pans cut out, new quarter panel has arrived. Still waiting on the wheels. I will get some more pics posted soon. Thanks for the clean shop comment!
allisontech
allisontech
Posted: Thu Dec 15, 2011 12:59 AM
Here is the chassis with the pans removed
And a pic of the quarter panel
Posted: Thu Dec 15, 2011 02:34 AM
Nothing like new metal for the new year.
What can one DO......
Gunpilot
Gunpilot
Posted: Fri Dec 16, 2011 05:59 AM
Don't drill the dimples on the fenders. Make sure they match up first. I made that mistake a few months ago.
Charlie Don't Surf!
allisontech
allisontech
Posted: Mon Dec 19, 2011 01:55 AM
Good advice, the fiberglass front fenders have not been drilled yet.
allisontech
allisontech
Posted: Mon Dec 19, 2011 02:10 AM
Made a little more progress this weekend I'm down to a bare chassis now.
Can anyone tell me if these look like drop spindles from the pictures? the car looked to be dropped in the front.
I'm installing 3" raised spindles but I could sell them if they are drop spindles
Posted: Mon Dec 19, 2011 07:34 AM
Yes those are dropped spindles for a lowered stance. See the little hole drilled in the spindle to the left in the last pic? It's in the flat area near the ball joint boss. That would be the center of the spindle shank if the spindle were stock height.
allisontech
allisontech
Posted: Tue Dec 20, 2011 12:46 AM
10-4 they look to be 2 1/2" drop. do I need to use the camber adjuster inserts when I have a adjustable front beam for lift? They had them on the ball joints for the drop spindles.
Posted: Tue Dec 20, 2011 10:49 AM
The old speedo cable hole.
Definitely drops.
Is there one drilled for the new spindle location????
If so the differences is your total drop.
As for camber adjustments......Ive never used them.
On three inch raised for drive and play.....that might be something to get knocked around and kicked out of adjustment.
allisontech
allisontech
Posted: Mon Dec 26, 2011 03:42 PM
Finally got the pans in and seam sealed, I used the 3M stuff on the outside "Bottom" and the cheaper Auto zone stuff on the inside seams. You can really tell the difference in quality between the two. Did some trading of parts I wasn't going to use and picked up a double front and rear bumper set I'm going to try and sell them locally only thing I'm going top keep is the light bar.
Here are some pics of the floorpans now
Time to start installing some suspension parts!!!!
Posted: Mon Dec 26, 2011 04:30 PM
Nice....nothing like fresh floors.
Cant wait to see the chassis roll on a new set of fours.
Posted: Mon Dec 26, 2011 09:36 PM
Your getting there. Looks good with new pans.
1 2 3 4 5 6 7 8 9
5 Admin_AzBaja 6774 Baja Bugs on Wiki need...
1568 mufasavnvmc 998726 Re: what did you do to...
285 MusicManiac 241203 Re: Baja sightings
No new posts VW Volkswagen & Baja Bug General Discussion FREE VW BAJA'S 0 azdesertrat87 9 FREE VW BAJA'S
1199 Dalton 338273 My 69 project
