Visitors: 101
Total: 101
02: Pictures
11: My Account
12: Event Calendar
Bill's Baja project
1 2 3 4 5 6 7 8 9
allisontech
allisontech
Posted: Thu Dec 01, 2011 01:27 AM
Ran into another question tonight, The trailing arms I have from Dons are the heavy duty stock width,sheet metal, 1" longer type,the rear brake kit I have is the E brake disc type,I have found the standard weld on brackets I bought for the trailing arms are to small,"The bolt holes are to close together"they are made for the non E brake small calipers. Does anyone make a larger weld on bracket, or am I going to have to fab one up from some 1/4" plate?
It's a never ending adventure I tell ya, at least I'm finding this stuff before I get to that point in the build!
allisontech
allisontech
Posted: Sun Dec 04, 2011 04:50 PM
Finally replaced both door pillars this weekend,hung both the doors temporarily to be sure everything will adjust out. Then we pulled the body off the pan. Now the fun can begin!
Time to start installing some parts!!
DeathBug
DeathBug
Posted: Mon Dec 05, 2011 08:06 PM
oh yeah... Cool let the fun begin..!!! Nice well organized garage...
allisontech
allisontech
Posted: Wed Dec 14, 2011 02:57 AM
been working my butt of the last two weeks, I managed to get the pans cut out, new quarter panel has arrived. Still waiting on the wheels. I will get some more pics posted soon. Thanks for the clean shop comment!
allisontech
allisontech
Posted: Thu Dec 15, 2011 12:59 AM
Here is the chassis with the pans removed
And a pic of the quarter panel
Posted: Thu Dec 15, 2011 02:34 AM
Nothing like new metal for the new year.
What can one DO......
Gunpilot
Gunpilot
Posted: Fri Dec 16, 2011 05:59 AM
Don't drill the dimples on the fenders. Make sure they match up first. I made that mistake a few months ago.
Charlie Don't Surf!
allisontech
allisontech
Posted: Mon Dec 19, 2011 01:55 AM
Good advice, the fiberglass front fenders have not been drilled yet.
allisontech
allisontech
Posted: Mon Dec 19, 2011 02:10 AM
Made a little more progress this weekend I'm down to a bare chassis now.
Can anyone tell me if these look like drop spindles from the pictures? the car looked to be dropped in the front.
I'm installing 3" raised spindles but I could sell them if they are drop spindles
Posted: Mon Dec 19, 2011 07:34 AM
Yes those are dropped spindles for a lowered stance. See the little hole drilled in the spindle to the left in the last pic? It's in the flat area near the ball joint boss. That would be the center of the spindle shank if the spindle were stock height.
allisontech
allisontech
Posted: Tue Dec 20, 2011 12:46 AM
10-4 they look to be 2 1/2" drop. do I need to use the camber adjuster inserts when I have a adjustable front beam for lift? They had them on the ball joints for the drop spindles.
Posted: Tue Dec 20, 2011 10:49 AM
The old speedo cable hole.
Definitely drops.
Is there one drilled for the new spindle location????
If so the differences is your total drop.
As for camber adjustments......Ive never used them.
On three inch raised for drive and play.....that might be something to get knocked around and kicked out of adjustment.
allisontech
allisontech
Posted: Mon Dec 26, 2011 03:42 PM
Finally got the pans in and seam sealed, I used the 3M stuff on the outside "Bottom" and the cheaper Auto zone stuff on the inside seams. You can really tell the difference in quality between the two. Did some trading of parts I wasn't going to use and picked up a double front and rear bumper set I'm going to try and sell them locally only thing I'm going top keep is the light bar.
Here are some pics of the floorpans now
Time to start installing some suspension parts!!!!
Posted: Mon Dec 26, 2011 04:30 PM
Nice....nothing like fresh floors.
Cant wait to see the chassis roll on a new set of fours.
Posted: Mon Dec 26, 2011 09:36 PM
Your getting there. Looks good with new pans.
1 2 3 4 5 6 7 8 9
5 Admin_AzBaja 7133 Baja Bugs on Wiki need...
1568 mufasavnvmc 1013001 Re: what did you do to...
285 MusicManiac 244562 Re: Baja sightings
1199 Dalton 346886 My 69 project
