Latest: strike77
Overall: 3575
Visitors: 110
Total: 110
03: Event Calendar
05: Event Calendar
16: Event Calendar
56: Pictures
68: Pictures
71: Event Calendar
91: Pictures
106: Event Calendar
1 2 3 ... 70 71 72 ... 103 104 105
Posted: Mon Nov 14, 2011 04:44 AM
Started rebuilding the front bumper support for the 1 piece & gas tank, just gotta make the head light mounts and its done. Then gotta replace the steering box and figure out whats wrong with the right rear (it sags really bad) and she'll be on the road again.
Posted: Mon Nov 14, 2011 07:13 AM
Made up some brackets to attach new seats to the old seat adjustment. They worked out so that I can get some adjustment. Also tacked in cross bar on roll cage for seat belts and got all tabs located and tacked in. Got front bumper all tacked up and ready to disassemble and weld up. Hopefully will get the adapter for the motor ordered tomorrow. Then I can start the rear bumper.
Posted: Sat Nov 19, 2011 05:37 AM
Prepped for floor removal
Looked harder at a cage laying around
Said what the heck that will turn out pretty damn cool
Pulled out a benchseat out of a toyota 4x4
Said I dont believe it
Redesigned the members of the cage
And Ordered a set of pan halves
What can one DO......
Posted: Sun Nov 20, 2011 06:38 PM
Bought a single throttle body EFI off the SAMBA for the balanced 1.6 build.
FUN FUN FUN
Very Happy
Posted: Fri Nov 25, 2011 10:42 PM
re indexed rear tortions, still sits a little lower on the right rear, I may need to put that side up another notch(even thought they are both set at the same degrees right now) finished re mounting the 1 piece front end. now just have to get it smogged next week.
Posted: Sat Nov 26, 2011 03:20 AM
Not a whole lot but jake sure had fun
Ran outta control gas today......BLACK FRIDAY to boot.
Grabbed my spare from the house and will hit it hard tomorrow.
Posted: Sun Nov 27, 2011 03:35 AM
Rear Bumper Mod Today
Posted: Sun Nov 27, 2011 05:49 AM
MAN! That deep sump sure makes you take a LOT of ground clearance out from under that Baja with stock rear arms, doesn't it?
Posted: Sun Nov 27, 2011 10:52 AM
About 2 1/2 in. But I love my Berg sumps. And she still rides pretty high with the 33s.
Posted: Mon Nov 28, 2011 11:56 PM
WoooooHooooo she passed smog with flying colors, no down to the DMV to get plates.
Posted: Tue Nov 29, 2011 07:06 AM
Put a skid plate on the bottom and it is all good!
Posted: Wed Nov 30, 2011 04:14 AM
Worked on the dash still need to get the speedo installed
Posted: Sat Dec 03, 2011 08:32 AM
And thought now aint that great!!!!
Posted: Sun Dec 04, 2011 03:20 AM
Posted: Sun Dec 04, 2011 08:44 AM
Skid plate looks good POC. How much space is between it and the sump?
I ask because I've seen so many Bajas with their skidplates right up against their engines with no room for the skidplate to to its job. I NEVER expect a skidplate to be totally non-flexible. They need a little space to give.
4 Admin_AzBaja 5895 Baja Bugs on Wiki need...
285 MusicManiac 223495 Re: Baja sightings
No new posts VW Volkswagen & Baja Bug General Discussion Had to go play in the rain today! 1 azdesertrat87 44 Re: Had to go play in ...
 Mon Jul 16, 2018 08:00 PM
0 Northmountainauto 644 Shop Baja
No new posts New Members Baja hiding in Chandler 9 Upsbaja 2272 Baja hiding in Chandle...
