Visitors: 123
Total: 123
08: Pictures
16: Event Calendar
63: Home
81: Event Calendar
116: Event Calendar
118: Pictures
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Need Help....Adjusting the aim of the headlights on a Baja
jemizasi
jemizasi
Post Post subject: Need Help....Adjusting the aim of the headlights on a Baja
Posted: Thu Nov 10, 2011 06:25 PM
Okay, I did a search on the site to find out how to adjust the headlights on a Baja, but I only found a few topics and nothing that described what I need.
I understand at what level and the basics of aiming my headlights properly, which is what I found. But, what I do not know is what mechanism on the headlight allows for the adjustment. Most times, in other vehicles, it is a screw that moves the direction of the headlight up or down, but in a Baja setup I am unclear what to look for. I cannot find the adjustment screw, if there is one.
I have not yet taken apart the assembly to look closer, but I figured the adjustment screw would be out in the open and easy to access.
DeathBug
DeathBug
Post Post subject: Re: Need Help....Adjusting the aim of the headlights on a Ba
Posted: Thu Nov 10, 2011 06:42 PM
if you could attach a pic of the light setup it would be a great help with the assessment.. Wink for example.. is it on a pivot mount welded to a cage setup or does it have a fender / hood mounted headlight bucket so on and so forth..
ghettodish
ghettodish
Posted: Thu Nov 10, 2011 07:05 PM
My only tip is park in front of a level brick wall. You'll have something good to aim at.
Posted: Fri Nov 11, 2011 01:39 AM
I pull my car out into a parking lot, aka The Mall. I adjust the highs 1st then the lows should fall into place. I sit in the car and set them to the spot I like them. If you do the lows 1st you will find out the highs are hunting for squirals.
thing
thing
Post Post subject: Re: Need Help....Adjusting the aim of the headlights on a Baja
Posted: Fri Nov 11, 2011 04:00 AM
This.
I try to find a dark street to use. Once you adjust the high beam the low beam takes care of itself.
jemizasi
jemizasi
Posted: Fri Nov 11, 2011 05:54 PM
I can't seem to attach the pictures I took, but based on what you are saying, I have a fender mount headlight.
If I could attach the pictures, I would, but I can't figure out how with the messaging for this site.
DeathBug
DeathBug
Posted: Mon Nov 14, 2011 06:49 PM
have the pics uploaded through photobucket or somethin similar.. with fender mounts, you need to locate or install adjusters around the metal trim under the metal ring that holds the headlight in..
you can kinda see that i installed two upper adjusting bolts..
4 Admin_AzBaja 5223 Baja Bugs on Wiki need...
1567 mufasavnvmc 856028 what did you do to you...
 Tue Aug 15, 2017 03:29 AM
285 MusicManiac 209477 Re: Baja sightings
Off-road event
1 wideopenmotorsports 372 Re: Baja run in March
 Mon Jan 08, 2018 05:09 PM
No new posts VW Volkswagen & Baja Bug General Discussion Considering buying a Baja Bug, but I have questions 4 AutomotiveDino 3312 Considering buying a B...
 Mon Jun 19, 2017 09:39 AM
daelan37 View latest post
