Latest: slyster
Overall: 3568
Visitors: 88
Total: 88
22: Event Calendar
27: Event Calendar
44: Event Calendar
45: Event Calendar
46: Pictures
51: Event Calendar
74: Event Calendar
81: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- rear main seal
rear main seal
Post Post subject: rear main seal
Posted: Sun Nov 13, 2011 02:28 AM
Make sure you have a flyywheel lock and torque to 235.
Remember to replace the o-ring in the flywheel on the crakshaft side.....its kinda tucked up in there.
Any specs you may need you can find @ chirco.....along with alot more info and fun stuff to buy.
Good Luck & have fun
What can one DO......
Post Post subject: Re: rear main seal
Posted: Sun Nov 13, 2011 02:50 AM
I wouldnt run the motor like that. My suggestion if you want to try to use the motor without tearing it apart is to get an 8 dowell fixture and drill 4 more holes in the crank. make sure you flatten the little burrs where the dowells wallowed the holes out, do both the crank and the flywheel.
Posted: Sun Nov 13, 2011 03:13 AM
That would be the IDEAL fix for the existing problem.....but ive seen some pretty bad end results from people drilling OFFhand.
My last purchase had a crankshaft that came with it like that....that crank and flywheel were definitely mated and tossed in the recycling bin together.
But anyways it would be the ideal fix if done correctly...square to the chuck in a press.
baja66
baja66
Posted: Sun Nov 13, 2011 05:08 AM
can u tern the old flywheel into a 8 hole?
Posted: Sun Nov 13, 2011 05:54 AM
Like Daryll said
Try Kustom1Warehouse.net part number 5004
Posted: Sun Nov 13, 2011 06:21 AM
Yes.
Posted: Mon Nov 14, 2011 06:22 AM
217ft/lbs
baja66
baja66
Posted: Mon Nov 14, 2011 08:33 PM
okay im starting to rip my hair out so i stuck the flywheel back on and torq it dwn but i have about 1/4 inch off play?? does this mean crank bearing are toasted??
Posted: Tue Nov 15, 2011 04:02 AM
It might be the thrust on the rear main bearing...thats what gives you the endplay on the crank.
baja66
baja66
Posted: Tue Nov 15, 2011 04:08 AM
pull the whole engine apart ??? im not a aircooled expert i do american v8s mostly
Posted: Tue Nov 15, 2011 04:36 AM
Check some other resources on how to set endplay on the crankshaft....it might help you out alittle better.
baja66
baja66
Posted: Wed Nov 16, 2011 01:27 AM
so did the end play and got it to about 1. 16 of a inch and then drov it down the block flywheel came off and bottom end bearing are toasted. any one got a parts engine or a complete case with cam and crank
Posted: Wed Nov 16, 2011 07:25 AM
Sorry to here that bro........werent you working on a possible irs conversion outta the junkyard for your 66........was there a block with that rearend ?????
baja66
baja66
Posted: Wed Nov 16, 2011 04:04 PM
yea i went to get it and the tranny had a crack:( but a got a 1500cc single port for a trade for my engine with 15000 miles, i will find some dual port heads
Posted: Fri Nov 18, 2011 03:58 AM
Chin up and have fun..........at times it might seem alittle overwhelming !!!
No new posts VW Volkswagen & Baja Bug General Discussion Max angle for rear axles 5 Wattsd 2575 Re: Max angle for rear...
 Fri Jan 29, 2016 04:03 AM
Wattsd View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Rear Rim Backspacing 1 LittleBaja 1441 Rear Rim Backspacing
 Fri Nov 06, 2015 03:13 AM
JWHracing View latest post
what do you use
4 bdrdunes 2114 Baja bug rear led ligh...
 Thu Dec 18, 2014 02:55 AM
No new posts Projects and Builds Possible rear seat?? 4 TattooedIrish 3365 Possible rear seat??
 Thu Aug 30, 2012 08:55 AM
Rigger View latest post
irs,swingaxle
3 desertbaja 2537 Re: 1968 vw beetle rea...
 Tue Aug 28, 2012 04:37 PM
