Visitors: 138
Total: 138
21: Event Calendar
32: Pictures
61: Event Calendar
81: Pictures
94: My Account
96: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Need Help....Dash lights go out when I switch to high beams
jemizasi
jemizasi
Post Post subject: Need Help....Dash lights go out when I switch to high beams
Posted: Thu Nov 10, 2011 07:30 PM
Dash lights work great when my low beams are on. But, when I switch to high beams on my '66 Baja, the dash lights go out. This poses a problem if I need the high beams, and I can't see how fast I am going in the dark.
A long time ago, I had this problem in a vehicle of mine. But instead of fixing the problem, I just stuck a reading light on the dash and aimed it at the speedometer for night time use. I really don't want to do that this time around.
Does anyone know why this would be happening?
DeathBug
DeathBug
Post Post subject: Re: Need Help....Dash lights go out when I switch to high be
Posted: Thu Nov 10, 2011 07:46 PM
are you running toggle switches or factory switches..? i am running toggle type and my dash lights are wired to the low / running lights.. so i have my high beams on a separate toggle and need to leave my low beams on otherwise i am running only high beams.. Laughing just them.. really.. no taillights or anything..
DeathBug
DeathBug
Posted: Thu Nov 10, 2011 07:55 PM
also, if your running both on a single switch, your dash lights are probably wired to the low beam so when you turn on your highs it will automatically turn off your lows.. how are your tail lights..? do they turn off too? not brake lights, just the running / marker lights.. they should be on the same circuit i think.. so when your running lights are on so are your dash.. and your high beams should be on a different one so they don't interfere.. for example, you wouldn't want your running lights and dash to get brighter just cause you turn on your high beams.. or dimmer because of more power draw.. lol..
No new posts VW Volkswagen & Baja Bug General Discussion Baja bug Dash
Looking for a carbon fiber dash
1 deputyrick 2067 Baja bug Dash
 Sat Jan 09, 2016 04:44 AM
JWHracing View latest post
No new posts Events and Get Togethers World Wide led auto lights 4 Stella2015 2666 Re: led auto lights
 Wed Apr 08, 2015 03:03 PM
No new posts Events and Get Togethers World Wide This was a fun get together. Christmas Lights Tour
Not Baja's but a great idea for a Baja run
7 Yummi 5161 This was a fun get tog...
 Sat Dec 14, 2013 10:48 PM
Yummi View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Brake light switch?? 3 sandbuggy 2809 Re: Brake light switch...
 Sun Nov 17, 2013 08:21 PM
No new posts VW Volkswagen & Baja Bug General Discussion dash insert 6 blubaron66 4475 Re: dash insert
 Sun Jun 24, 2012 04:12 AM
