Visitors: 110
Total: 110
20: Event Calendar
52: Pictures
86: Event Calendar
1 2 3 ... 68 69 70 ... 103 104 105
Posted: Mon Oct 17, 2011 04:11 PM
[quote="biblethumpncop"]I hope that works Eric. What did it turn out to be?
Turns out the front hose was pinched and the metal line at the motor was partially blocked.
Posted: Mon Oct 17, 2011 04:12 PM
Washed, buffed with a light compound and waxed it. Didn't help. Sad
Actually drove mine for the first time in 5 years of ownership. Took it to the Chirco show and parked between James and Preston (with another car in between). Had some idiot in a Toyota truck back into it when I was hooking up the tow bar in the alley behind Chirco's.
Then at home drove it around a little bit more.
madman74
madman74
Posted: Mon Oct 17, 2011 04:43 PM
So did it tow out there ok? thats a long way after sitting so long!
Oops it broke!
Posted: Mon Oct 17, 2011 05:06 PM
The lights fell off leaving your house, so I tie strapped them to the bumper. Checked the lug torque on the way down and all went well.
Posted: Tue Oct 18, 2011 02:06 AM
Pushed the bug back into the cleaned and painted garage, no more red and white walls and black and white checker board floor. This will be easy to wash the floor.
Posted: Wed Oct 19, 2011 05:47 AM
I assembled the carb with a 1" spacer after adding the alternator. I found my throttle cable is too short now. I made it work, but it idles too high now. Time to buy an extention or longer cable.
TINMAN
TINMAN
Posted: Thu Oct 20, 2011 11:47 PM
ran my buggy at the strip at LVMS last night
TRUMP 2020
Posted: Fri Oct 21, 2011 01:32 AM
So how did it do? and how long before we see it lowered with some slicks on it. HAHA
crestfallen
crestfallen
Posted: Fri Oct 21, 2011 04:18 AM
Put mine away for the snowy season Sad
Posted: Fri Oct 21, 2011 06:42 AM
E/Ts or it didn't happen!
TINMAN
TINMAN
Posted: Fri Oct 21, 2011 09:44 PM
18.00 at about74 mph on the first run i drove it nice and easy to make sure it would go strait. that ended up being my only run of the night due to about 5 oil downs by a Nissan a Volvo and a bunch of Mustangs
TRUMP 2020
Posted: Sat Oct 22, 2011 01:43 AM
18! that gives me hope then. i bet i can at least go 17.99 Smile
Posted: Sat Oct 22, 2011 02:07 AM
today i fixed a couple of oil leaks. put new o-rings under the stock oil cooler, rerouted my oil return from the turbo, and replaced the seal between the drive flange and the side cover as well as the cap that goes inside the drive flange.
Posted: Sat Oct 22, 2011 02:13 AM
pulled the rust filled tank out again and realized I need a new one. Anyone got a tank i can borrow for a couple weeks? Or a set of straps for a 10" poly tank.
Posted: Sat Oct 22, 2011 05:20 AM
I took my bug to get tested for emissions today- failed hydrocarbons at idle BIG time! 5000/500
4 Admin_AzBaja 5200 Baja Bugs on Wiki need...
285 MusicManiac 209015 Re: Baja sightings
Off-road event
1 wideopenmotorsports 349 Re: Baja run in March
 Mon Jan 08, 2018 05:09 PM
No new posts VW Volkswagen & Baja Bug General Discussion Considering buying a Baja Bug, but I have questions 4 AutomotiveDino 3297 Considering buying a B...
 Mon Jun 19, 2017 09:39 AM
daelan37 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion What is my Baja really worth? 1 Treeposter 942 What is my Baja really...
 Sat Jun 17, 2017 04:06 PM
