Latest: ecthemc
Overall: 3567
Visitors: 124
Total: 124
50: Home
58: Home
63: Event Calendar
118: Event Calendar
123: My Account
Baja Forums -:- AzBaja.com Members -:- New Members -:- new guy with questions
zach1779
zach1779
Post Post subject: new guy with questions
Posted: Mon Oct 17, 2011 04:37 AM
I'm new to the vw scene, just picked up my fist bright red 67 baja a few weeks ago.
I've spent some time working on cars, but am definitely not a mechanic.
I love the car. The previous owner built a 1915 for it and put less than 1k miles on it. I'm not sure about too many of the internals, but I do know its got a balanced Scat cam, and dual Dellorto 40 carbs.
I hope to use this thing as a daily driver with the ocasional camping or fishing trip.
A few days ago I went to leave work and could not get the thing to shift while the engine was running. Everything was fine in neutral, but if I tired to put it in any gear I'd just hear a wining sound and could not get the shifter to move in place (I did not use excess force). When I attempted reverse all I got were grinding sounds. Also, the pedal was very light. It took almost no force to push the clutch. Since I had just replaced the clutch pedal hook, I assumed the clutch cable had gone bad(I've read that if one goes, the other soon will). I quickly replaced the cable and still had the same issues, so I decided to take a look at the clutch.
Today, after an hour and a half battle I managed to pull the engine and found the T/O bearing cross shaft arms to be bent way out. And the little clips that hold the bearing in place were resting at the bottom of the bell housing.
Seems I finally found the problem.
I don't think I'll have any trouble replacing the T/O bearing cross shaft, but I want to know if there is anything else I should take the time to replace while I've already got the engine out? I was planning on replacing the throttle cable already, but I don't know if theres any other maintenance needs that i just might as well do while everything is apart?
I don't know much about clutches, do I need to replace my TO bearing? it seems fine, rolls very smoothly. It does not just pop apart to be repacked, is there a way to re-grease it so i don't have to replace it?
And since the clips that hold it in were found just laying at the bottom of the bell housing, I have no idea how they are suposed to secure the bearing in place.....does anyone have a diagram or picture?
www.cbperformance.com/...uctID=1480 is what i was planning to use for a replacement T/O bearing cross shaft. Does anybody know of a stronger one? I got my 'heavy duty' clutch hook form CB Performance and was not really impressed this its 'heavy dutyness'.
Sorry for the long-winded post, but any advice would really be appreciated. I have pics of the T/Obearing, clutch and tranny if that would be helpful for anybody.
I will also throw up a few pics of my bug when the sun is out.
Thanks in advance for your help
Posted: Mon Oct 17, 2011 06:35 AM
I would definitely replace the bearing and the clips. If you have the eallier style bearing without the support sleeve bolted to the bell housing that the bearing slides on, the clips you get should be the type which the wire makes more than a complete circle. They slip into the hole on the side of the bearing, and with some cursing and conniving (I use a pair of Channelock pliers to hook the clips on the arms). Make sure the hooked end of the clips go up into the notch on the back side of the arms and the bearing fits into the big notch on the side of the arm facing you. I presume you have the early style as the later style has clips built into the bearing.
zach1779
zach1779
Post Post subject: new guy with questions -now with pics
Posted: Mon Oct 24, 2011 01:11 AM
Sorry for the delay
I just finished replacing the clutch cross shaft and throw out bearing. All is well on my bug now.
Thank you for you input MojaveRacer
Here are the delayed promised pictures
[img]http://www.azbaja.com/coppermine/displayimagepopup/pid=735/fullsize=1.html[/img]
[img]http://www.azbaja.com/coppermine/displayimagepopup/pid=733/fullsize=1.html[/img]
www.azbaja.com/copperm...ize=1.html
No new posts VW Volkswagen & Baja Bug General Discussion Considering buying a Baja Bug, but I have questions 4 AutomotiveDino 3134 Considering buying a B...
 Mon Jun 19, 2017 09:39 AM
daelan37 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Simple Questions- Wiring 7 camronbitzer 4073 Simple Questions- Wiri...
 Tue Jul 05, 2016 01:12 AM
No new posts VW Volkswagen & Baja Bug General Discussion Tow Bar questions 3 ghs215 1439 Tow Bar questions
 Mon Nov 16, 2015 01:45 PM
No new posts New Members New Guy Questions 6 Apoc 3340 New Guy Questions
 Wed Jun 19, 2013 01:17 AM
Apoc View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Outdoorsman Questions/Outback vs Squareback 10 Grunt-0341 6749 Re: Outdoorsman Questi...
 Sat Oct 27, 2012 07:07 AM
Grunt-0341 View latest post
