Visitors: 122
Total: 122
19: Event Calendar
20: Event Calendar
46: Pictures
47: Home
52: Home
62: Event Calendar
109: Pictures
119: Home
120: Home
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Not a baja buttt still figured you guys could admire it.
The following users give thanks for this topic perrib - Tue Oct 11, 2011 03:59 PM
bajaboi727
bajaboi727
Post Post subject: Not a baja buttt still figured you guys could admire it.
Posted: Tue Oct 11, 2011 01:11 AM
Hey everyone,!
Hows it going?
As many of you guys know, I sold my baja, and got into the world of mustangs. I bought a 99 w/ 60k on her comepletely stock and started to have some fun.
Well, My uncle, who many of you know is a big part of my car life as well has an 99 cobra, fully built T56, fully forged 03 cobra terminator swap( AC condensor all the way to the gas tank is from a crashed terminator.) with the Kenne Bell 2.8 making about 600 to the wheels on the daily tune.
On to the point, after a night of crazy fun at the Cruise on Central this weekend, while our group was cruising together mking one last trip down, we got all got on it pretty good from a light, I see him pull a few car lengths with my other uncle in his ws6, when all H*ll let loose. The pressure plate in the clutch grenaded taking out the input shaft, bell housing, wire harness, the rest of the clutch, and the back of the block. Along with shooting pieces through the floor board like it was butter, blew the gas pedal off the pedal assembly and bent all the pedals. took out the exhaust,as well. It also broke 4 f the 6 spots on the block where the trans bolts up. Looks like we get to pull the motor out of this thing this weekend, to pull the trans all we did was disconnect the drive shaft, and unbolt the trans crossmember.
Overall, It's going to cost about 5.5k to get it all back together, but she'll be coming back bigger, badder, stronger, and thankfully no one was hurt. It was pretty scary to see the entire car light up like a top fuel funny car, and blow chunks and just hammeer the rev limiter knowing my family was inside. We are going to make a custom under carrage scatter shield thatcover thes entire drive line from front of trans all the way back to the drive shaft loop.
Here are some carnage Pics:
Figured you guys could admire, enjoy, and sykmpathize sense we are ultimately all just gear heads. and I wanted to say hi and let you all know I'm lurking aroun the vw world still every chance I get.
Posted: Tue Oct 11, 2011 06:35 AM
Big Daddy lost some toes from a cluch blow up. He built the rear engine dragster so he could save his feet from this.
Posted: Tue Oct 11, 2011 06:44 AM
WOW!!!
One reason to keep it mellow on the street. Damned lucky the carnage wasn't of the hospital sort. I can't believe there isn't a scattershield readily available for that engine/trans combo. I wouldn't want a car with that sort of power without one.
Post Post subject: Re: Not a baja buttt still figured you guys could admire it.
Posted: Tue Oct 11, 2011 04:01 PM
You got lucky that time. I'm sure someone makes a scatter shield. There is even one made to make a 2.7 bi turbo Audi hook up to a GM or Ford 4 and 5 speeds.
bajaboi727
bajaboi727
Posted: Tue Oct 11, 2011 06:23 PM
Yea, people make one. I'll keep eveyrone updated on what exactly we end up doing.
VIN70
VIN70
Posted: Wed Oct 12, 2011 03:13 AM
big daddy ed roth?? rat fink?
Mannyr7
Mannyr7
Posted: Wed Oct 12, 2011 03:23 AM
"Big Daddy" Don Garlits
TINMAN
TINMAN
Posted: Wed Oct 12, 2011 04:26 AM
Garlits was lucky to survive this a lot of drivers didn't. a clutch explosion is serious business glad everyone is okay.
TRUMP 2020
Posted: Wed Oct 12, 2011 06:43 AM
"Big" is quite the drag racing legend. I bet that most people dont know he is a UFO investigator though. look it up.
69baja69
69baja69
Posted: Mon Jan 23, 2012 08:16 PM
in a vw bug you can do a wheelie, blow a clutch and still be relatively safe!
69baja69
69baja69
you find many UFO's out there in your neck of the woods?
5 Admin_AzBaja 6797 Baja Bugs on Wiki need...
1568 mufasavnvmc 999867 Re: what did you do to...
285 MusicManiac 241510 Re: Baja sightings
0 Northmountainauto 1534 Shop Baja
