Latest: BlackIrish05009
Overall: 3574
Visitors: 141
Total: 141
19: Pictures
21: Event Calendar
23: My Account
40: Pictures
44: Pictures
55: My Account
119: Event Calendar
136: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- quick easy increase in HP?
woodin
woodin
Post Post subject: quick easy increase in HP?
Posted: Mon Sep 05, 2011 01:37 AM
my winter project for this year is going to be to increase the HP in my baja somehow. what would be the quickest, easiest, cheapest way to do that? turbo? larger displacement? i would like to go with a bigger bore, but i'd rather not have to machine my heads and case. ideas people! thanks
Posted: Mon Sep 05, 2011 04:00 AM
Might help to tell us what you're setup presently is- engine size, carburetion, trans setup and tire size might be useful info as well...
crestfallen
crestfallen
Posted: Mon Sep 05, 2011 05:56 AM
^^Agreed. Moar info bro.
woodin
woodin
Post Post subject: Re: quick easy increase in HP?
Posted: Mon Sep 05, 2011 07:03 AM
74' super. all stock motor 34-pict carb. not sure of tire size but they're not too much taller than originals off it
crestfallen
crestfallen
Posted: Mon Sep 05, 2011 07:11 PM
A good tune up is where Id start. Your looking at a stock dp engine, more than likely with an non-counterweighted crank. Thats gonna limit power slightly. How are you looking to gain power? Shave and mildly port the heads for better flow, go to dual 34's on a stock engine. Add in a mild cam and a header, and it would be decent. Honestly if your just looking for bolt on power, go with dual 34's and a header. Non-countered engines can run good, but its easy to overbuild them. Ive seen a bad example that involved a stock dp with a 7k rev limiter box, a mid-range cam, and dual carbs.
Just my 2cents
Ejbbal21
Ejbbal21
Posted: Wed Sep 07, 2011 11:36 PM
Simple thing to do is what was mentioned above. Tune up, dual 34 pic carbs and a little head work. If it were me and even on tight budget I would put a stroker crank and a cam upgrade in it if I were to split the case. If you were thinking about going bigger then you have already committed to doing some machine work. Assuming that you have a good dual relief case then the price difference in P&L (piston and liners) sizes in minmal If any. I have always liked a 2180 (82X92) lots of lowend torque and great relyibilty. You can build one with your stock heads and a single 44 weber. It's a great setup, besides if you want to upgrade it from there its as simple as a set of 044 heads and an additional 44 weber and you have a whole new animal with out needing to split the case again. Just my .02
By the way sometimes it's easier to find a new to you case and start from scratch. I assume that you still have to emissions it? let just say that there are some of us here that have wild beasts for motors that will no way in hell pass an emissions test. We there for have stock 1600 that end up on our cars every year or two around emissions time. Wink I have heard anyway.
No new posts Projects and Builds Just a quick little project...
56 wideopenmotorsports 46266 Just a quick little pr...
 Sun Mar 08, 2015 12:29 AM
yellowchev View latest post
No new posts Club AzBaja (Arizona Chapter) electrcial quick connections for winch. (DALTON) 7 vwboat 2409 electrcial quick conne...
 Sun Apr 20, 2014 02:42 PM
No new posts VW Volkswagen & Baja Bug General Discussion quick help/won't start 5 Pointvirus 2855 quick help/won't start
 Sun Oct 21, 2012 07:42 AM
Pointvirus View latest post
No new posts VW Volkswagen & Baja Bug General Discussion quick welding question 2 Brettucks 1943 quick welding question
 Sat Apr 10, 2010 08:31 PM
DONT View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Looking for easy/cheap seat swap 6 bajagill 5169 Re: Looking for easy/c...
 Sat Oct 03, 2009 09:22 AM
bajagill View latest post
