Latest: Smokey4
Overall: 3593
Visitors: 73
Total: 73
25: Links
37: Home
38: My Account
54: Links
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Wide Ball Joint front end?
Darn_Near
Darn_Near
Post Post subject: Wide Ball Joint front end?
Posted: Mon Sep 05, 2011 07:59 PM
is there any way to get a wide ball joint front end? I Don't want much just a couple of inches to match the rear end. I have ordered 3x3 arms for the rear. I have thought (once that cured me) about cutting the frame and going to a link pin but that idea just doesn't appeal to me. Already have disk brakes and 3inch lift spindles. Don't wanna throw them away and start over. It will be a street Baja. I have an 1835 engine Built and will use it on the street. Right now I have the floor pans cut out and next step is powder coating the frame then going back together with running gear. Front end is the minor hang up so far. Any ideas would be greatly appreciated. Thanks in advance from Grandpa and Lane. Laughing
Measure it with a micrometer
Mark it with chalk
Cut it with an AX
Beat it together
Put VW on it
DRIVE THE SNOT out of it!
T_Town_Baja
T_Town_Baja
Post Post subject: Re: Wide Ball Joint front end?
Posted: Mon Sep 05, 2011 08:20 PM
Yes!
If you have the skills and tools available, you can widen it yourself for darn near free. I have widened several BJ beams, from 4" to 8" over.
6" Wider is what you want to match the rear 3x3's. If you dont want to do it yourself, BugZyla can make a beam in any length for you:
www.thesamba.com/vw/cl...?id=942666
Blaine
Darn_Near
Darn_Near
Posted: Mon Sep 05, 2011 08:51 PM
Thanks for the input. I hadn't thought about widening it myself. Looks like it would be simple enough to do, little elbow grease which I have lots of, a little welding which I can do. Only question I have is there a kit or is it just slice it and add adjusters and put it back together? I have never been inside of the beams so it is all new to me. But willing to try DARN_NEAR anything once.
Mark it with chalk
Cut it with an AX
Beat it together
Put VW on it
T_Town_Baja
T_Town_Baja
Posted: Mon Sep 05, 2011 09:28 PM
Couple different ways to do it, one way is to take two BJ beams and cut them two inches off center and combine the two halves that are longer, giving you a +6 beam.
Or, cut the middle out of yours, add 4 adjusters and a 6" piece in the middle of them, this will give you a + 6 beam and allow you to use your existing leaves cut in half and re-dimpled. The key here is, you push the adjusters towards the outside of the beam 1" on each side.
Blaine
T_Town_Baja
T_Town_Baja
Posted: Wed Sep 07, 2011 03:45 AM
Heres a good deal if you do want to convert to Linkpin.
Its all you would need for a direct bolt on conversion (using BugZyla's conversion beam)
www.azbaja.com/ForumsP...html#70124
Thats a great price, I believe the beam alone cost more than that new.
Blaine
Darn_Near
Darn_Near
Posted: Wed Sep 07, 2011 08:12 AM
I wish I had seen that BEFORE I bought the disk brake kit and the 3" taller spindles. So I am sorta stuck with BJ front end. I didn't even know they made such a kit as that. Pretty darn neat.
Mark it with chalk
Cut it with an AX
Beat it together
Put VW on it
No new posts VW Volkswagen & Baja Bug General Discussion Lifting a super beetle front end 1 72sbbaja 2257 Re: Lifting a super be...
 Wed Jul 02, 2014 04:42 PM
Front End question
12 ButchW 7515 Re: What's the best wa...
 Sun Oct 27, 2013 04:42 AM
No new posts VW Volkswagen & Baja Bug General Discussion Class 11 and wide-eye mix
19 phulc 9769 Class 11 and wide-eye ...
 Mon Jul 22, 2013 07:50 PM
biblethumpncop View latest post
No new posts Club AzBaja (Arizona Chapter) bj front disk brakes with raised spindles 2 vwboat 3454 Re: bj front disk brak...
 Thu Dec 13, 2012 03:03 PM
No new posts VW Volkswagen & Baja Bug General Discussion WATED: Wide 5 Aluminim Rim and Tire
Something like a Center line
1 DEDSLED2012 2522 WATED: Wide 5 Aluminim...
 Tue Mar 13, 2012 07:52 AM
