Visitors: 178
Total: 178
18: Pictures
19: Pictures
20: Pictures
26: Pictures
38: Event Calendar
45: Pictures
94: My Account
95: My Account
96: My Account
98: My Account
99: My Account
118: Pictures
140: Event Calendar
152: My Account
153: My Account
154: Event Calendar
164: Baja Forums
168: Baja Forums
176: Event Calendar
1 2 3 ... 64 65 66 ... 103 104 105
ghettodish
ghettodish
Posted: Thu Jun 30, 2011 01:32 AM
I'm still flipping coins over mounting the shifter on top of the tunnel. I'm trying to figure out what to about the parking brake.
Rybob
Rybob
Posted: Fri Jul 01, 2011 05:24 AM
Very nice Hyperwrx. I have been wondering what your plans were for that thing since you posted your original thread.
(o\|/o)
Hyperwrx
Hyperwrx
Posted: Fri Jul 01, 2011 08:16 PM
Thanks Rybob. I am new to this baja thing and am kinda just making it up as I go along. All the great pictures here give me ideas.
Just purchased a new starter this morning I need to install and a few breather filters in the vent system.
Posted: Sun Jul 10, 2011 03:02 AM
Finally installed the 2, 2lb residual valves on the front brakes (disc) to correct the 2 pumps on the pedal, NOT! Rolling Eyes So Sad Still gotta pump the pedal. No! No! No! No!!!! I did notice with the e brake on I have a solid pedal w/o pumping. Hhhhhmmmmmm... Guess I need the rv on the rear brakes (drum). Rolling Eyes
siacs
siacs
Posted: Sun Jul 10, 2011 12:30 PM
That almost tells me that you have an adjustment issue with the rear. Maybe a bad soft line
Posted: Sun Jul 10, 2011 04:38 PM
Soft lines are only 2 years old and are braided. I've had this issue from day one with new parts so I don't "think" it's an adjustment issue. I have the rear brakes set where the wheel turns less than 1 revolution freely. That rev is with 31" tires.
Perhaps that needs to be tighter?
siacs
siacs
Posted: Mon Jul 11, 2011 12:36 PM
I can tell you that I have had the hardest time with brakes on these VW's. I have been doing brakes for 25 yrs. If you read the threads about brakes you will see that I am not alone. It shouldn't be any different but it is, For me anyways.
Posted: Wed Jul 13, 2011 05:40 AM
There should be NO NEED for an RPV for the rear brakes on a Bug with disc fronts.
The proper adjustment procedure for VW drum brakes is to:
- Make sure the hand brake is fully released
- tighten them until the wheel cannot be turned by hand.
- Both adjuster stars for each wheel MUST be adjusted one at a time, not just one adjuster then quit.
- then back them off until they rotate but drag enough to stop the rotation in less than a turn. I personally do not allow the tire to "spin" to less than a revolution, I set them a little tighter.
Adjustment of the drum brakes should be done about every 3,000 miles.
The hand brake cables should be adjusted so that after adjusting the brake shoes, the hand brake lever is about the top of the bottom seat cushion when the rear wheels are locked.
FLBaja
FLBaja
Posted: Sun Jul 24, 2011 06:23 PM
I originally cut out so much of the door frame where the hinges attached that it was flexing and cracking the metal. So I cut it out and added some 3/16 plate steel to mount the doors to. Should be alot stronger
FLBaja
FLBaja
Posted: Sun Jul 24, 2011 06:27 PM
In order to get the tires somewhat flat instead of looking like a jacked up swingaxle, I am cutting off the trailing arm mounts and repositioning them.
Here is how it lines up with the tire straight up and down
Almost done cutting and grinding!
Posted: Mon Jul 25, 2011 12:25 AM
Spent the week at OBX (Outer Banks) NC play'n on the beach with the baja. Got stuck twice. Real dry and loose sand this trip. Got pulled out by my bro-in-law first time, second time I used a method I learned from Baja Bugs and Buggies. Jacked it up and filled in under the rears.
Today after returning home yesterday, we washed and vac'd her out. On the return trip the pin on the fuel pump walked out consequently stalling gas flow. WTF? Rolling Eyes Embarassed Easy fix, just gotta ding the shaft to prevent that issue again.
Posted: Mon Jul 25, 2011 01:46 AM
Made some lower front suspension stiffeners and relocated the master brake cylinder to the fire wall. Pictures tomorrow after the paint dries and I get them installed.
jone$yyy
jone$yyy
Posted: Mon Jul 25, 2011 06:14 AM
put my motor and trans back together re wired everything
now time to add on to my cage and strengthen the front more and make a roof rack
FLBaja
FLBaja
Posted: Sun Jul 31, 2011 08:42 PM
Got the rear suspension back in. Now if I could only find where my baggy of nuts and bolts to mount the tranny is.....
crestfallen
crestfallen
Posted: Wed Aug 03, 2011 09:23 PM
Not mine but tuned this today..
And got mine in Hot VWs again...
5 Admin_AzBaja 6771 Baja Bugs on Wiki need...
285 MusicManiac 241181 Re: Baja sightings
No new posts VW Volkswagen & Baja Bug General Discussion FREE VW BAJA'S 0 azdesertrat87 8 FREE VW BAJA'S
No new posts VW Volkswagen & Baja Bug General Discussion Had to go play in the rain today! 3 azdesertrat87 1276 Re: Had to go play in ...
0 Northmountainauto 1520 Shop Baja
