Latest: danmcfly
Overall: 3577
Visitors: 118
Total: 118
05: Event Calendar
08: Event Calendar
09: Pictures
18: Pictures
21: Event Calendar
22: Pictures
27: Pictures
28: Event Calendar
50: Event Calendar
54: My Account
55: My Account
77: Event Calendar
87: Event Calendar
97: Pictures
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Mileage
Mileage
tsutt
tsutt
Post Post subject: Mileage
Posted: Sun Jul 10, 2011 05:14 PM
Just curious as to what kind of mileage yall are gettin with the different engines, trannies, setups. When i build up my bug its intended to be a daily driver.
Posted: Sun Jul 10, 2011 06:43 PM
Man... that's kind of an open question. It would say there are a lot of variables involved in that.
- My baja, with 002 close ratio, 33" tires, 2187cc, FK8, custom-ported 044 heads with 42x37.5 valves, dual 44 IDF's gets about 12. If I baby it around town and go easy on the pedal, it gets about 12. If I run it all day hard with the pedal to the floor in the dirt, it gets about 12. I don't know how that works, but it does.
- My 1835cc Westy, dual Kaddies (modified), really hot hand-ported 041 heads, C35 cam, 1.25 rockers got 16.9 over a period of 500 miles before I put an SVDA distributor in it. It'll do even better now, but I haven't measured it lately. It's got plenty of poop, and will actually lift the front wheels off the ground if I drop the clutch.
- The Baja Squared gets over 20 with a basic 1641, stock everything except a little head work and dual ICT's (the devil's carbs, btw, but they fit on a Type 3). It's got a 002 in it and 30" tires, so with different gearing, it would do even better.
Posted: Sun Jul 10, 2011 06:46 PM
My little 1385cc with 4.37 gearing, full steel body, 3" body lift and 3" suspension lift, 30 pict 1 carb and original style muffler gets about 23-25 mpg with the 225/70r15 General Grabber Tires during in city driving.
Last edited by biblethumpncop on Sun Jul 10, 2011 06:51 PM; edited 1 times in total
tsutt
tsutt
Posted: Sun Jul 10, 2011 06:50 PM
Yes it is an open ? and for that very reason. And your answering exactly as i hoped. Thanks. How about some h2o runners also. AZBAJA? It's all about the witch way to go with it.
Todd
tsutt
tsutt
Posted: Mon Jul 11, 2011 09:34 PM
Anybody else? would definitely like to know what some of the water pumpers are getting.
Post Post subject: Re: Mileage
Posted: Tue Jul 12, 2011 12:42 AM
2180 single carb 10-24 MPG.
Posted: Tue Jul 12, 2011 07:32 AM
Let's all slow down here. First: motor size and carb. Second: tire size and type of wheel ( steel vs aluminum). Third: intended use (mostly street, street and minor off road, street and major offroad).
What we have won't help you until we know exactly what your plans are.
tsutt
tsutt
Posted: Tue Jul 12, 2011 10:46 AM
Did you read my first post? Pretty much says what it says. I havent had a bug for 30 years, I have no idea what they get for mileage. with a little info i'm fully capable of discerning the info. Thank you. And BTW I don't have any plans yet. hmm maybe i can use some of the info to decide on the path.
Todd
Posted: Tue Jul 12, 2011 02:06 PM
We all know how big tires can effect mileage, so with that said let's assume the following:
Steel bodied Baja with some fiberglass
31-10.50-15 & 7.00-15 tires on steel wheels
1776 with a single 44
002 trans (geared for 31" tires)
You might get 20. This does depend a lot on how you gear your tranny. Street vs off road gearing.
Posted: Wed Jul 13, 2011 06:01 AM
Body configuration has a great deal to do with fuel mileage in a Baja Bug. A full body sedan like a Class 11 style car with 225 tires will get much better fuel economy than a similar car with a bugeye Baja body kit with the same tires and unmodified front fenders.
Posted: Wed Jul 13, 2011 10:21 AM
I get about 16 to 18 mpg on the highway. My 360 V8 Drag car would get 18 to 20 MPG.
The Baja has 4.37 with a .82 4th. so on the highway it is running around 3000 rpm. (31x12.4 rear tires) not good for MPG. But on the other hand if I just drive the car around down, 2 and from work and stay below 55mph. I get plenty of hours per gallon of run time. I'm not working the motor and it does real nice in stop and go. I also have a 1 piece hood and Roof Rack with a spare tire. This works like a big Air Dam at highway speeds, so that also eats up the MPG
tsutt
tsutt
Posted: Wed Jul 13, 2011 10:32 AM
AZ, is that a carberated 2.3 or a FI.
Posted: Wed Jul 13, 2011 10:35 AM
Holley 350 4B Progresive.
Ejbbal21
Ejbbal21
Posted: Wed Jul 20, 2011 06:01 PM
I have a nasty turbo 2332 with the lowest gearing you can put in an 002 with 31" tires. Top speed is about 60mph at 3k rpm in 4th....... Don't ask. Seriously though I think I'm between 10 and 12.
No new posts VW Volkswagen & Baja Bug General Discussion gas mileage 6 oman 3957 Re: gas mileage
 Wed Aug 20, 2008 09:05 PM
oman View latest post
21 danjones333 9514 Re: gas mileage
 Wed Mar 19, 2008 07:49 PM
danjones333 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion mileage 7 tsutt 3195 Re: mileage
 Sat Mar 17, 2007 07:13 PM
