Visitors: 124
Total: 124
80: Event Calendar
96: Pictures
106: Event Calendar
112: Home
122: Pictures
Psuedo Class 11
1 2 3 4 5 ... 12 13 14
Posted: Mon Jun 20, 2011 04:28 AM
He did a nice job on the bumpers, they fit the car very well.
Posted: Wed Jun 22, 2011 03:14 AM
Those bumpers kick arse! Just adapt a light bar to your rack and you are set. Excellent job! Laughing
TINMAN
TINMAN
Posted: Wed Jun 22, 2011 11:38 PM
Looks great you've motivated me to do my own 11 car .
TRUMP 2020
Posted: Thu Jun 23, 2011 01:20 AM
Do it! Put the flatback kit on it as well!
70bugdriver
70bugdriver
Posted: Thu Jun 23, 2011 02:43 AM
what is your bolt pattern you have on the bug?
Posted: Fri Jun 24, 2011 03:30 AM
It has the IRS 4 bolt VW pattern. I dropped the bug off last night and should have it back on Saturday.
Posted: Sat Jun 25, 2011 10:39 PM
I got a sneak peak of the side bars he made at my request. I wanted tube side bars with expanded steel on them. He sent me the photo from his phone. I will get the bug back tonight and take some pictures this weekend.
Posted: Sat Jun 25, 2011 10:45 PM
SWEEEEEEET!!!!!
Posted: Sun Jun 26, 2011 03:39 AM
Nice.
Posted: Sun Jun 26, 2011 10:02 PM
Here are the latest photos I took today. I am very pleased.
Posted: Sun Jun 26, 2011 10:54 PM
Your car kicks arse! Love the class 11 look!x
TINMAN
TINMAN
Posted: Sun Jun 26, 2011 11:49 PM
Looking good I hope to see this thing in person and dirty at the AZ baja playday at the hassayampa in Nov.
TRUMP 2020
Posted: Sat Jul 02, 2011 07:13 AM
biblethumpncop wrote:
I found a new German original style exhaust at the Bugarama for $40. Score! Picked up a set of adjusters for Dirtjunkie to install and some door handles with keys. I put the exhaust on and it appears to be much higher than the old header and quietpack. I hope to have it lifted soon and then paint another coat of bedliner on it by the end of April. Oh ya, the pinging is now gone.
I need some advise on exhaust. The stock exhaust has pulled some of the "pep" away from the little engine. My options are limited since the engine is based on a 40hp and a 1600 exaust and header won't fit...that means no thing header. So, I still have the header and quietpack that hung down low. I'm thinking of putting the header back on and buying a hideaway muffler that tucks it in by the passenger tire. I think that will get it up higher. Does anyone have experience with these mufflers? Any thoughts? Daryll? Perri? Tony? Eric? Anyone?
Posted: Sat Jul 02, 2011 04:42 PM
Header, u-bend, muffler tucked underneath and a good skid plate.
Posted: Mon Aug 29, 2011 12:52 AM
I haven't driven my bug much over the summer due to the heat. I have a buddy that is borrowing it, so it is getting driven each day. As a result, I've had to replace the rear wheel bearings and plug wires that failed. The bug is a 3rd vehicle for me, and since I traded in my Silverado, we are without any kind of vehicle that can haul something to the dump or from Home Depot. That got me thinking...
I could sell it and pick up a little truck that would allow me to tote stuff around items. Or I can hang onto the bug and convert it to a flatbed. Some of you may remember that I had bought a flatback kit and was going to convert my bug to a flatbed earlier in the year. I sold the fiberglass flatback kit to Dirtjunkie, and opted to make the bug like a class 11 military bug.
I am thinking of going back to the flatbed design again though. Except I think I will have the kit made out of metal. My bug has a Bugzylla 3" body lift on it, which would provide stiffness for the pan. When I cut through the roof, I will run into the wiring. That sucks since I had Daryll completely re-wire it. I can use connectors though to repair it. I'm thinking of cutting the body well past the pillar, which will give it an extended cab. But I don't think I could have a side window in the extended area. I imagine I would have a panel welded in the void. I may also have the sides cut low enough so that the flatbed doesn't stick up as high as the flatback kit did.
Anyone have any ideas on the topic?
25 Kreed 26704 3" Body Lift, Class 11...
 Tue Apr 10, 2018 02:26 PM
Kreed View latest post
No new posts Projects and Builds New Class 11 Build - PepeBlanco 4 pepeazul 5363 New Class 11 Build - P...
60 wideopenmotorsports 48004 CLASS 5 Resurrection!
 Mon Feb 22, 2016 05:23 PM
No new posts VW Volkswagen & Baja Bug General Discussion 5-1600 vs Class 11 Version 3 2 wideopenmotorsports 3466 5-1600 vs Class 11 Ver...
 Thu Oct 08, 2015 08:12 PM
No new posts Projects and Builds Class 11 PepeAzul 3 pepeazul 5621 Class 11 PepeAzul
 Fri Jul 17, 2015 02:29 PM
