Visitors: 99
Total: 99
03: Event Calendar
42: Event Calendar
47: My Account
99: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Rear torsion housing adjuster
ghettodish
ghettodish
Post Post subject: Rear torsion housing adjuster
Posted: Wed Jun 29, 2011 05:16 AM
How many of you actually have and use a rear torsion adjuster? Is it worth it to install? Just asking since I have body off the pan, and wondering if I should install one.
If you use one, which do you have? I see that Pacific Customs has at least 3 different ones.
Posted: Wed Jun 29, 2011 11:16 AM
i don't have one in my car nor do i have any real 1st hand experience with them. i have heard of people who race their cars stripping them out or breaking the little adjuster keys. i've also heard that they can make reindexing the rear of the car a lot easier, just loosen them, install the torsions, and crank them back up.
the difference in the ones that are on pacific customs site is based on the size of the torsion tube. don't know what stock is off the top of my head, but 1 size listed will be for stock torsion tube and the others should be for if you're building a car from scratch and using some other tubing rather than the stock housing, would be my guess
Post Post subject: Re: Rear torsion housing adjuster
Posted: Thu Jun 30, 2011 02:22 AM
Spend the money and get the Sway Away unit. Ask Desertrat87 how well the Empi copy holds up. I have the Sway Away one but have been to lazy to install it.
azdesertrat87
azdesertrat87
Posted: Fri Jul 01, 2011 12:44 AM
It doesn't I haven't had any problems with the arms or adjusting bolts. But I had to put a 1/2" plate under the adjustment bolts they were bending the housing in so they almost touched, Then I actually ripped the metal and crusched the other side of the adjuster, had to drive back home from Red Creek on a boworred pair of 4x4" boards Not fun but made some interesting videos check it out on www.arizonavolkswagenclub.com under trail talk and then Red Creek. Once back it was a supreme mother grinding out all of the old adjuster, I did pay for the sway-a-way night and day differance, I also supported the front of the adjuster by tying it into my frame. Would I recomend one? Defanetly. But get a good one and install it properly! After our 400 Miler I broke one of my custom 2x4" front arms again driving harder than the equipment was desined to go so now I'm in the prosses of upgrading to Fodrill arms and speed costs money so how fast do you want to spend!
No new posts VW Volkswagen & Baja Bug General Discussion Max angle for rear axles 5 Wattsd 3918 Re: Max angle for rear...
 Fri Jan 29, 2016 05:03 AM
Wattsd View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Rear Rim Backspacing 1 LittleBaja 2473 Rear Rim Backspacing
 Fri Nov 06, 2015 04:13 AM
JWHracing View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Coils Ver Torsion bar 12 Darn_Near 7317 Coils Ver Torsion bar
 Wed Oct 21, 2015 06:29 PM
thing View latest post
what do you use
4 bdrdunes 2996 Baja bug rear led ligh...
 Thu Dec 18, 2014 03:55 AM
No new posts Projects and Builds Possible rear seat?? 4 TattooedIrish 4340 Possible rear seat??
 Thu Aug 30, 2012 08:55 AM
Rigger View latest post
