Latest: rcwtony
Overall: 3607
Visitors: 183
Total: 183
23: Event Calendar
27: Event Calendar
38: Home
42: Event Calendar
51: My Account
55: Event Calendar
56: Home
63: Event Calendar
68: Event Calendar
71: Event Calendar
72: Event Calendar
82: Event Calendar
111: Pictures
112: Event Calendar
116: Home
121: Event Calendar
135: Event Calendar
140: Event Calendar
147: Pictures
151: Home
152: Event Calendar
154: Event Calendar
157: Event Calendar
158: Event Calendar
159: Home
164: Baja Forums
165: Home
170: Event Calendar
172: Home
175: Event Calendar
176: Baja Forums
177: Baja Forums
178: Baja Forums
182: Contact Admin
Baja Forums -:- AzBaja.com Members -:- New Members -:- TrailRail2110-My New Obsession**pics**
Post Post subject: Re: TrailRail2110-My New Obsession**pics**
Posted: Wed Apr 21, 2010 02:09 PM
An executive rail. When you get done with those from tires put some 30" BFGs on it the off road ride will greatly improve.
TrailRail2110
TrailRail2110
Post Post subject: TrailRail2110-My New Obsession**pics**
Posted: Fri Apr 30, 2010 04:52 PM
I work for State Farm Insurance, so i get to wear a suit everyday. kinda funny to driving the dune buggy dressed up but at least its more fun then my ford.
TrailRail2110
TrailRail2110
Posted: Mon Mar 21, 2011 05:31 PM
I bought some 1300 Plus paddle tires and Douglas wheels for $300, Now i can really tear it up at the dunes!
So this prompted me to also want a faster motor so i am getting my motor from about 80hp to about 150hp, mostly by switching from the single port head to a port/polished dual port head among other goodies.
But now i have to get a Trans that can handle the power so i am switching from my built 4.37 to a built 4.12.
I am quite excited! Maybe this year i can actually beat those Diesel trucks that alway kicked my butt at the dunes sand drag.
Posted: Tue Mar 22, 2011 12:46 AM
Between you with that High HP 2110 and Wheel Works and his Ecotech up grade in his Baja.....
My little 1915 will be sucking nothing but both of yours dust... I mean.... Literary Sucking Dust.... So Sad
No! No! No! No!!!! Hmmmmm ... : Turbo Question … Supercharger… Question
AHhhhhh … Big Brother is running Ford Power…. "Hey AzBaja"…
These guys are picking on Little Brother...
Posted: Tue Mar 22, 2011 03:03 AM
One thing I noticed is your shoulder belt harness mounting if you are unfortuanate enough to get hit the shoulder belt will compress your spine.
TrailRail2110
TrailRail2110
Posted: Tue Mar 22, 2011 04:43 PM
any suggestions?
i was looking at some high back seats where the straps go through the seat. i have the MI buggy builders show/swap meet this weekend so maybe i can pick up some nice stuff.
Posted: Sat Apr 16, 2011 03:03 PM
You need to raise the bar up behind your seat so it is almost level with your shoulders, yes you would get a bit compacted as it is now.
You also need some bigger tires, Cool nice rail, good mods you have made to it. Love driving mine to work as well.
Baja, you don't need no stinking baja Laughing
And you can't let a little bad weather keep you from riding either.
Keep it up, looking good!
Posted: Tue Apr 19, 2011 01:08 AM
Perrib and Leather have it right about the shoulder harness. And the seat won't have any say-so in the matter. Your shoulder harness should only hold you back into the seat, not down into it. The lap belt has the job of keeping your body down into the seat (or up when you're inverted). Using the shoulder harness to hold you down into the seat causes compressive fracture of the spine So the angle from the top of your shoulder to the mounting bar needs to be within about 10 degrees of horizontal. Typically the bar should be about 4 inches below the top of you shoulders as you sit in the car. Having the shoulder belts mounted low also allows your upper torso and head to slide forward under the belt in a frontal impact (running into something). Steering wheel rims don't taste all that good! They also don't feel so great on the chest. The way to fix this is to add a 1-1/2" x .095 tube across the cage at the correct height. The faster your engine, the more you need this!
TrailRail2110
TrailRail2110
Posted: Wed Jun 22, 2011 10:03 PM
I was able to get 4x new wheels real cheap and took my extra set tires and slapped them on. So now i am running 31x10.5.r15 on all four corners. I will try them out for the first time this weekend, i figure if i air them down to 20-25psi it should make the ride even smoother!
Also, that new turbo muffler that is in the picture is WAY better than the super trapp that i was running before. The buggy is so much more enjoyable to drive around town with the muffler it is much quieter and has a deeper tone, i can listen to my music and not have to worry about pissing off some cop. plus i get a little more torque back in the low end, the down side is that it cuts out around 6K. So if i am at the dunes or the sand drags, i will run my super trapp so i can reach 7-8K. Although i was thinking of switching over to a series 40 welded flowmaster muffler, thinking it should get my high rpm's back, thoughts?
Here is a video of my first couple rips down the sand drag, hope the video works.
[video width=250 height=200]http://s911.photobucket.com/albums/ac317/hendrix0284/?action=view&current=1308776220.mp4[/video]
Posted: Thu Jun 23, 2011 02:25 AM
I think 7-8K is stretching your luck beyond reason in a VW motor. Especially if you plan to drive it to work on Monday morning. Valvetrain, case, rods, crank, flywheel, clutch and gearbox all object to that sort of RPM. Do you have a scattershield? Sure your legs aren't right next to the bellhousing, but the GAS TANK is! And swingaxle gearboxes were designed for 40hp in mild use on the street with 5.20-15 tires. You can spend 10s of thousands on them and still not deal with 7-8K rpm.
OTOH, I agree entirely with the Turbo Muff. It was invented for use on a 3 liter 6 cyl turbo engine with all exhaust through one 2" size muffler. It should handle all the output of your normally aspirated VW.
TrailRail2110
TrailRail2110
Posted: Thu Jun 23, 2011 05:52 PM
I was doing 6k drops at the sand drags, maybe i should ease up on it. I work a normal job and cant afford to rebuild my motor every year.
here is the link to the drag video.
Sand Drag video
If you think the turbo is better than the Welded muffler i will leave it alone. Like i said i love the sound. Also, I think the turbo is forest legal so i dont need to run a super trapp in the woods, but i could be wrong.
No new posts Events and Get Togethers World Wide Hassayampa Pics/Vids 5 wideopenmotorsports 5443 Hassayampa Pics/Vids
 Sun Nov 22, 2015 10:34 PM
No new posts Projects and Builds Pics of my dads build 10 Reggie 8168 Pics of my dads build
 Wed Apr 25, 2012 02:18 AM
Reggie View latest post
No new posts Club AzBaja (Arizona Chapter) WHAT THE HELL!! WHERE ARE THE PICS, 9 jamesr6168 9653 WHAT THE HELL!! WHERE ...
 Fri Dec 24, 2010 02:43 AM
jamesr6168 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion fun weekend (video + pics) 2 thext94 3769 Re: fun weekend (video...
 Tue Nov 02, 2010 06:47 AM
thext94 View latest post
No new posts Events and Get Togethers World Wide April 16th Offroad Adventure - PICS POSTED -
95 jon6.0 42889 Re: April 16th Offroad...
 Tue May 04, 2010 03:49 PM
