Latest: ecthemc
Overall: 3567
Visitors: 133
Total: 133
03: Event Calendar
19: Event Calendar
54: Home
55: Event Calendar
58: Event Calendar
91: Event Calendar
94: Event Calendar
103: Event Calendar
Baja Forums -:- AzBaja.com Members -:- Projects and Builds -:- Squareback attack, the Ugly Orange Squareback
DustinT3
DustinT3
Post Post subject: Re: Squareback attack, the Ugly Orange Squareback
Posted: Fri Apr 01, 2011 07:39 PM
Pics of the seats mounted on top of stock base. It's a little high, but it was easier than building custome mounts.
DustinT3
DustinT3
Posted: Fri Apr 01, 2011 07:41 PM
My new meats.
Found a great deal on a set of barely used 29" swampers. A little too agressive than I wanted, but it was a good deal. Now I just need to raise the susopension a bit.
Posted: Sat Apr 02, 2011 04:44 AM
You won't loose traction with those tires. Sorry to hear about your back it took a great Chiropractor and massage therapist to get mine useeable. I also do lots of stretching in the AM and have an inversion table. Make sure your regular doc takes the time to study the xray. My friend had a fourth opinion on ten year old xrays and the 4th found a crack that once fixed stopped the phantom sudden pain.
DustinT3
DustinT3
Posted: Sat Apr 02, 2011 05:06 AM
Back has been good for the most part. It gets a little tense/tight still, but no spasms.
Yeah, no traction loss here, unless I catch air ofcourse, but I'm not going to be set up for that. Just simple dirt road excursions for now. The messy stuff I'll reserve for my 4x4.
DustinT3
DustinT3
Posted: Sat Apr 02, 2011 05:14 AM
My wife thinks i'm wiered for wanting to keep this thing ugly. I love the rusty wheels. It will be the coolest ugly car around damnit!
I do have to replace a fender and pull the front apron out so the hood will actually close. I was going to repalace both venders, but for what this car is it's not worth replacing both. Just the passenger side is banged up good. I bought some pumpkin orange spray paint at wallymart and I'll scuff it up so it matches the rest of the faded paint.
Other than that no body work, save for trimming the fenders a tidge.
Waiting on a rebuit master cylinder to come in and I should be good to go on registering it to finally drive around.
_-Mad-Max-_
_-Mad-Max-_
Posted: Sat Apr 02, 2011 11:25 AM
What did your seats come out of? Just wondering
Thanks
jeremy
im in need of a new front clip for my 74 ghia, i dont care what year its from but i need one in order to fix my front end, can anyone help out?
DustinT3
DustinT3
Posted: Sat Apr 02, 2011 02:38 PM
I'm not sure. I bought them at the GCC swap meet. The guy had a huge flat bed of them for 80 bucks a pair. I took a business card, but have lost it.
DustinT3
DustinT3
Posted: Mon Apr 04, 2011 10:45 PM
Thanks
jeremy
I found the business card of the guy that had the seats. His name is Andy and his cell is 602-405-8815
DustinT3
DustinT3
Post Post subject: Squareback attack, the Ugly Orange Squareback
Posted: Thu Apr 07, 2011 12:39 PM
Got the new MC in. Brakes are better, but there is still room for improvement. They work better after a few pumps. I've bled them 4 times and each time they've got better. Maybe a few more attempts at bleeding them will complete the job. If not, I must have a pin hole leak somewhere.
I have some clearance issues with the front tires and wheel well. I have about an inch more that I can raise the front suspension, but the car sits level right now with only having tweaked the rear. I'd love to get more lift out of it, but then I'd have to change axles/flanges...something I'm not too educated on just yet.
I found that one of my injector plugs was disconected (must have nocked it loose when I replaced all the hoses to the air box recently) I adjusted the timing too. It sounds and runs great! I still can't believe that after 25yrs of sitting, it runs.
I just want to start driving it....meh... leagally that is. I need to get it insured, licensed and hopefully it will pass emmisions. I'll probably try and do that within the next few days.
DustinT3
DustinT3
Posted: Sat Apr 09, 2011 07:09 PM
Took it thru emissions.....FAILED the idle test. The HCs were too high.
Posted: Mon Apr 11, 2011 10:13 PM
Could be blow-by past tired rings jacking up the HC level.
DustinT3
DustinT3
Posted: Sat May 21, 2011 11:11 PM
I've been busy on the Squareback the last month. As I attempted to take it to Bill at Affordable German to get it to pass emissions my clucth started acting funny. Low and behold the springs on the clutch plate some how dislodged themselves and started tumbling around in there. OOPS!
DustinT3
DustinT3
Posted: Sat May 21, 2011 11:34 PM
Anyway, you know how it goes, one thing leads to the next....
I figured, well, since I've got the motor out I may as well take it apart and clean it all up. Remember this thing had sat for some 25 yrs. I kept finding more and more grass in places I couldn't even imagine.
Look closely and you can see the spring to the auotmatic air control unattached and just hangin' out.
DustinT3
DustinT3
Posted: Sun May 22, 2011 12:01 AM
Look what I found "deflected" on the deflector plate....
That would have "screwed" (pun intended) things up real quick if it had fallen through.
I'm glad I decided to take everything apart!
DustinT3
DustinT3
Posted: Sun May 22, 2011 12:23 AM
I had some clearance issues up front with the swampers. Without a body lift, I had to "wedge" the fender wells (sorry in advance to you purests) and welded a nut on the arms to limit the turning radius ever so slightly so that the tires no longer rub.
No new posts Projects and Builds my 70 squareback build 9 70square 4698 my 70 squareback build
 Thu Feb 21, 2013 12:24 AM
No new posts VW Volkswagen & Baja Bug General Discussion Outdoorsman Questions/Outback vs Squareback 10 Grunt-0341 6756 Re: Outdoorsman Questi...
 Sat Oct 27, 2012 07:07 AM
Grunt-0341 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Baja squareback project
What do I do?
9 Triller 11926 Baja squareback projec...
 Tue Oct 23, 2012 01:53 AM
No new posts Projects and Builds 73 baja squareback
28 73square 18799 73 baja squareback
 Fri Jul 20, 2012 03:53 PM
73square View latest post
No new posts Projects and Builds 70 ugly daily driver 0 Zaroc 2234 70 ugly daily driver
 Wed Feb 16, 2011 08:06 PM
Zaroc View latest post
