Visitors: 115
Total: 115
02: Home
27: Event Calendar
29: Event Calendar
59: Event Calendar
76: Home
84: Event Calendar
100: Event Calendar
112: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- glue and sound deadener removal?
madman74
madman74
Post Post subject: glue and sound deadener removal?
Posted: Wed Nov 08, 2006 12:41 AM
Ok I am starting on cleaning up the intereor on my baja. I am having a hard time removing the glue they used on teh sound deadener. I have scraped, ascetone, wire wheel, but its still hard to remove, its easier getting off old under coating! so how do you guys do it? anything ou know that works well other than sand blasting?
thanks
Shawn
Oops it broke!
Post Post subject: Re: glue and sound deadener removal?
Posted: Wed Nov 08, 2006 01:48 AM
lacquar thinner is better, pour it on and let it soak abit... how about some heat ?
Posted: Wed Nov 08, 2006 02:40 AM
laquer thinner and a match Twisted Evil
lots of elbow grease!
maybe try some floor stripper.....why not!?
Posted: Wed Nov 08, 2006 03:02 AM
I just scrapped mine. It was hard but I think you'll just make a mess with the chemicals, and then just end up scrapping!! Laughing
Posted: Wed Nov 08, 2006 03:46 AM
Roll Lock scotch brite discs for your die grinder like these.
cgi.ebay.com/50p-3-COA...dZViewItem
3-M also makes one that is rubber with sand impregnated in it with long bristles that is great for hard to get to areas and places with little tabs and screws and doesnt get torn when you go over that stuff. I get those at space age and they are about $6 each.
madman74
madman74
Posted: Wed Nov 08, 2006 04:12 AM
I tried the scotch brite discs, but they keep snapping off on the threaded plastic part. I have never had problems like this on any other bugs that i have cleaned up. this glue just grabs stuff, its like the no-skid rubber stuff they use in tool trays. i dont think it original.
Oops it broke!
elryano
elryano
Posted: Wed Nov 29, 2006 03:39 AM
some times if your not worried about u can burn it off with a propane torch
azhunter
azhunter
Posted: Wed Nov 29, 2006 05:23 AM
<<<<<<<<used ro-loks with good luck
No new posts VW Volkswagen & Baja Bug General Discussion BODY REMOVAL '66 BAJA (HELP!) 5 ClassZero 4476 BODY REMOVAL '66 BAJA ...
 Sat Sep 07, 2013 05:08 PM
ClassZero View latest post
Replacement Possible or Not
3 jemizasi 3815 1966 VW Beetle Fuel Se...
 Fri Apr 29, 2011 05:51 AM
No new posts VW Volkswagen & Baja Bug General Discussion Anyone ever use/ hear reviews about sound pads from chirco? 7 bajaboi727 3942 Anyone ever use/ hear ...
 Sun Oct 31, 2010 08:51 AM
bajaboi727 View latest post
No new posts Projects and Builds Engine Cage Removal and Installation???? 4 glenf 3263 Engine Cage Removal an...
 Wed May 27, 2009 04:01 PM
glenf View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Sound Deadener!? 3 bajaboi727 2454 Re: Sound Deadener!?
 Sat Mar 14, 2009 08:54 PM
danjones333 View latest post
