Latest: slyster
Overall: 3568
Visitors: 127
Total: 127
60: Event Calendar
72: Pictures
79: My Account
104: Event Calendar
119: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Rack and pinion problem
Bunnyhunny425
Bunnyhunny425
Post Post subject: Rack and pinion problem
Posted: Fri Apr 29, 2011 06:55 AM
Hi, I'm new here. So this might be a stupid question or it might not even make sense, but here it goes. Have a long travel Baja and was trying to hook up a center rack and pinion. It hooked up fine but the steering is backwards. When turning left the bug goes right and vise versa. Is it because the bug is made for rear tire steering and the center rack is for front wheel steering? Idk? Am I supposed to use a center rack and pinion for a Baja with a-arms? Or what? What can I do to make the steering work right??
HELP!!
Thanks
Posted: Fri Apr 29, 2011 03:06 PM
Your rack is mounted upside down
Bunnyhunny425
Bunnyhunny425
Posted: Fri Apr 29, 2011 04:42 PM
Well if I mount it the other way it would be to high for the tie rods to work and they would rub the housing. Any solution?
Thanks
Posted: Fri Apr 29, 2011 07:02 PM
Any pic's so we can see what is up?
Posted: Sat Apr 30, 2011 03:29 AM
Make sure you can mount the rack upside down. If no do not do it you will have problems.
2nd there are rear steer and front steering set ups. On the VW you need a rack that will work with rear steer. If you put a rack in from somthing like a pinto or Mustang II popular with the kit car bunch you have a front steer type rack in a rear steer type car so left is right and right is left etc.
if the part were the tie rods hook to the spindal point to the back of your car it is rear steer. if it points to the front it is a front steer car.
Post Post subject: Re: Rack and pinion problem
Posted: Sat Apr 30, 2011 06:38 AM
Yes, Pics please.
No new posts VW Volkswagen & Baja Bug General Discussion Cool VW Bug Roof Rack 0 wideopenmotorsports 1730 Cool VW Bug Roof Rack
 Wed Jun 15, 2016 09:46 PM
No new posts VW Volkswagen & Baja Bug General Discussion Rack and Pinion setup on a Baja bug 3 DFWbaja 2384 Rack and Pinion setup ...
 Fri Jan 30, 2015 01:44 PM
No new posts VW Volkswagen & Baja Bug General Discussion rack & pinion w/stock fuel tank 0 ghettodish 1618 rack & pinion w/stock ...
 Wed Nov 09, 2011 06:44 AM
ghettodish View latest post
No new posts VW Volkswagen & Baja Bug General Discussion I have a problem
Can anyone help me
8 PaDan 4576 Re: I have a problem
 Tue Jul 12, 2011 06:33 AM
Rickman View latest post
No new posts VW Volkswagen & Baja Bug General Discussion I need a roof rack? 5 homeshark66 7035 I need a roof rack?
 Mon Jun 06, 2011 06:53 PM
DustinT3 View latest post
