Visitors: 117
Total: 117
45: Event Calendar
62: Home
76: Pictures
77: Event Calendar
Baja Forums -:- AzBaja.com Members -:- Projects and Builds -:- BaJa BuGgIn BUILD
BaJa BuGgIn BUILD
bajabuggin
bajabuggin
Post Post subject: BaJa BuGgIn BUILD
Posted: Fri Apr 22, 2011 04:15 AM
[/b]Been meaning to start this forum for awhile now. Mostly for comments, suggetions, and props. Started with a POS rolling chassis already (mostly) cut up for baja. The build started with myself and James from FABINC. James has built some of the baddest rails ive ever seen so i knew as a friend and partner this was gunna be done right. there are only 3 FABINC baja foundations built (so far). James designed and we started the FAB. Since foundation has been built, James has moved out of state and i have resumed build by myself. here are some pics of so far build.
Post Post subject: Re: BaJa BuGgIn BUILD
Posted: Sat Apr 23, 2011 04:09 AM
Nice work. Smile
Grunt-0341
Grunt-0341
Posted: Sat Apr 23, 2011 07:41 PM
Looking good Cool
Grunt-0341
81mm Mortar Man
1st Battalion 6thMarines
1985 - 1989
Semper Fi
Rom 1:16
www.infowars.com
www.oathkeepers.org
thepatriots.us/
Posted: Sun Apr 24, 2011 12:37 AM
Very Nice Work… I like the attention to detail…
Posted: Sun Apr 24, 2011 01:33 AM
BAD ASS! Cool
bajabuggin
bajabuggin
Posted: Wed Apr 27, 2011 02:18 AM
Next step is running the brake and clutch lines, should have that done by the end of the week.
Anyone have any suggestions on rhino lining the inside? I dont want to do carpet so im thinking that'd be a reasonable alternative since it is strickly offroad.
thanks for the complements, its been a hell of a project
Posted: Wed Apr 27, 2011 06:08 AM
I just black spray paint the floors in mine, drill a few holes to let the water out and it's been fine for years now.
bajabuggin
bajabuggin
Posted: Wed May 11, 2011 07:03 AM
Cut some fat out last night, and spot welded in new section. Decided to use dupont bed liner for the pan. hopefully i can get that done by weeks end.
Posted: Sun Jan 29, 2012 11:36 PM
Anymore updates on your car? I would like to see how it it coming along.
Posted: Mon Jan 30, 2012 12:48 AM
As far as my header clearance, the down tubes are straight and are no where near the exhaust.
Looks like James modified them to work with a baja header.
bajabuggin
bajabuggin
Posted: Wed Jul 25, 2012 04:27 AM
Project Baja still rolls on! been very busy with with perusing my A&P license. I will post pics this coming weekend when i can get back out in the garage.
allisontech
allisontech
Posted: Wed Jul 25, 2012 10:37 AM
Looks sweet!
blubaron66
blubaron66
Posted: Wed Jul 25, 2012 04:19 PM
love watching your progress...its also nice when you can get your buddy's to help...all my buddy's wouldn't know the difference between a screw driver and a wrench. keep it coming...
Posted: Fri Jul 27, 2012 10:08 PM
Cool,
4 Admin_AzBaja 5587 Baja Bugs on Wiki need...
1568 mufasavnvmc 890929 Re: what did you do to...
285 MusicManiac 216198 Re: Baja sightings
0 Northmountainauto 67 Shop Baja
No new posts New Members Baja hiding in Chandler 9 Upsbaja 1154 Baja hiding in Chandle...
