Visitors: 121
Total: 121
04: My Account
23: Event Calendar
28: Event Calendar
110: Event Calendar
111: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- New to Bajas?
New to Bajas?
1 2 3 4 5 6 7 8 9
The following users give thanks for this topic Anonymous - Mon Mar 09, 2009 02:16 AM
AZ_Born_n_Raised
AZ_Born_n_Raised
Post Post subject: Re: New to Bajas?
Posted: Wed Mar 09, 2011 05:55 AM
Woohoo! Finally got ahold of a baja. It's a 69, and boy does it need some work done to it, but I don't mind at all..I can already tell it needs new shocks all around, and either some work done to the current engine in it, or just swap it out for a better one, the engine does have an oil leak, but I haven't gotten the chance to hunt down exactly where it's coming from, it also needs an air cleaner and it stutters when I get into the gas like it's being flooded, but evens out once the rpms go up
AZ_Born_n_Raised
AZ_Born_n_Raised
Posted: Fri Mar 11, 2011 07:38 AM
Ok, a few specs I've learned so far about my bug..It's got a ball joint front end, and an IRS rear. The carburetor is a 34 pict-3 Bocar, idk if that's a good carb or if there's a slightly better one I can get. (Sorry, I'm kind of a carburetor virgin Embarassed ) And it's got a highway transmission setup. Any and all tips and suggestions for making this bugger (no pun intended Razz ) run better are highly appreciated. Thanks. Smile
Post Post subject: New to Bajas?
Posted: Wed Mar 23, 2011 12:32 AM
coool
Shalamara
Shalamara
Posted: Thu Apr 21, 2011 11:17 AM
On page one of this post and post #10 Kevin said that super beetles were harder to convert to Baja's. Why and what years are the best to convert.
New to VW's and Baja's. Most driving would be onroad with some mild offroad and dune runs On the Oregon cost.
crestfallen
crestfallen
Posted: Thu Apr 21, 2011 03:48 PM
supers have macpherson strut front ends, which need to be replaced with a regular vw beam or a long travel setup to work offroad.
IMO 68(autostick)-70 are the best years for baja because they offer IRS, are remotely cheap and easy to find, and because they arent the best looking years, no one will blame you for "ruining a classic" lol
Posted: Thu Apr 21, 2011 08:12 PM
There are whole threads and forums devoted to why one should not use a Macpherson Strut front end or a Super Beetle offroad. Reasons include hard to find body kits, strut suspension is very weak (in offroading terms) and not readily converted to long travel, pan extends quite a ways straight forward of where the beam pan ends resulting in poor clearance, and a number of other reasons. If you have a Super and want to offroad it, the body can be trimmed near the cowl for a regular 1-piece front clip (can be trimmed to fit a curved window), the pan cut off at the front bulkhead and a beam or a-arm front suspension mounted to a full cage, and then you've gotten rid of the objections.
Cazper802
Cazper802
Posted: Sat Apr 23, 2011 04:47 AM
Hey everybody I am BRAND new to the vw scene. I bought a 68 about 4 months ago as a daily driver. I did misc to get her up and running. The wiring is like a blind, deaf, mute did it all while high and drunk. It is bad but it does run and for $600 I didn't figure I could do any wrong. I have always loved just going redneck and off road so I figured a Baja is the way to go. I know I am purchasing the book mentioned on the 1st post tomorrow. Any suggestions where I should really start other than that. This will be a lifted daily driver with the ability to cut out across a field and play in some mud. Not looking to impress anybody so looks don't mean that much to me as long as it gets the job done.
1968 Bug
bajacrazy
bajacrazy
Posted: Wed Oct 12, 2011 08:33 PM
hay man i need some advice welli have a 1967 vw baja and it has a swing axle and i only get about 4-5 inches of clareence with it so i want to get more clearence for better offroad capibility so i was wondering what type of transmission i should go with an irs trans or a bus trans. so i just need some advice its a daily driver but i want to play with it more off road as well as drive it everyday oh ya and theres a kit that i can get its a 3x3 with all the stuff and i was also wondering what type of trans that will work for so can someone get back to me asap thanx Question Question Question Cool
Posted: Thu Oct 13, 2011 11:55 PM
Crazybaja...Having responded to your post on the gearbox upgrade thread, one other question I have here is....
When you say you have 4" of clearance...Do you mean between the tire and the fender when the car is sitting still?
The stock swingaxle rear suspension should provide about 8" of rear wheel travel. The stock ball joint beam should provide about 5-1/2" of travel. The front travel is not going to improve much short of replacing it with a linkpin front end...which is not really a bolt-in swap unless you buy conversion trailing arms from Bugzyla. I get 10-1/4" of travel with my original 1958 linkpin beam/trailing arms and spindles with fabricated shock mounts and 8" shocks.
The 3x3 rear kit requires a roll cage to mount the shocks to inside the interior of the car with the shocks through holes cut in the rear wheel wells. And IRS pivot brackets will have to be welded to the torsion housing for the trailing arms to mount to and stiffer torsion bars will be needed to handle the added leverage force from the longer arms and long shocks such as Fox or Kings will be needed also. It's not a bolt-in deal. Then you should be upgrading to a 002 or 091 Bus IRS gearbox with stub axles for Type 2 or Type 4 CVs, or Porsche 930 CVs, which also requires upgrade of the CV flanges on the gearbox. The 3x3 arms generally come without shock mounts on them and need those and the upper mounts and the IRS pivots fabricated by someone who is familiar with VW offroad suspension.
I'm not trying to talk you out of this. I just want you to go in with your eyes open.
Rupert
Rupert
Posted: Thu Jan 05, 2012 06:54 AM
you should get the Traxxas Slash 2wd or the 4wd and get a pro line Baja body and put it on. The Traxxas Slash is a better R/C car. The Dura Trax body is nice I like the roof rack. I have a Traxxas 4WD in its way out here to Afghanistan for me to mess around with. I also have the pro line Baja body on the way once I paint it ill post some pics
Posted: Fri Jan 06, 2012 04:29 AM
And this was in response to...?????????????
Fit4mma
Fit4mma
Posted: Wed Mar 07, 2012 02:14 AM
John from Vegas!! Looking for a pre smog rag top Baja that can be used as a daily driver. Don't want to go crazy with the mods, just keep it clean and functional. I have ordered VW Baja bugs and buggy and already own "how to keep your VW alive for ever. Looking forward to making new friendships.
Posted: Fri Mar 09, 2012 06:56 PM
Welcome John!
Good luck on your search for a Baja. Those are good books to have for a Baja owner. I used to race with Jeff Hibbard who wrote the Baja Bugs and Buggies book. In spite of the age of the book, most everything in it's still very applicable.
stevekim7d2
stevekim7d2
Posted: Sat Mar 10, 2012 05:37 PM
Hey everybody, Sand Shooter type Sand Rail, mostly built for the sand, but.......Im going to mostly use it in the desert............... but not kill it, First off, it has a Knock Off front end set up. wheels with no lug nuts, just 2 nuts on the spindle to keep the wheel from falling off, 2nd, anyone have any 'a little wider' knock off wheels, mine are I think only 4" maybe 5" wide, by 15' tall, I need like some 6" or 7" wide knock offs..........
So, tires all around would really help, I am looking for used 30", 31" tires for the rear, and some skinny tires for the front, I have to tow this on its tires behind my Jeep, so I need decent tires, I bout 195x65x15 used tires, but even a Llantra, Mexican tire store said they would be to wide for my wheels...............
Any ideas?
Steve-O
Spend every minute with your family, you will never get that time back.
Posted: Tue Mar 13, 2012 07:27 AM
Any ideas?
Steve-O
Those "knock-off" wheels are called "spindle mounts" as the spindle nut is what holds the wheel on. They were never available with wide rims as that isn't what has been used on them for sand dunes over the decades. For 195s you do NOT need 6 or 7 " rims. i have 7.00-15s on 3.5" rims on mine. My buddies use 205s on their 4" rims. And desert racers running in Class 10 and Class 12 use 4" x 15" wheels with 33 x 10.50 tires all around. 195s are NO sweat. I can install them on my manual tire machine. If the tire shop guys think it won't work, they don't know what they're doing.
But for desert use, it would be better if you got a set of drum brakes and hook them up. They will bolt right on your spindles as that's how the spindles came form the factory. Then regular wide 5 pattern wheels will bolt on. They may not be stylish, but stock 15 x 4 wheels work VERY well and are lighter than any of the "white spoke" wheels and only aluminum wheels like Centerlines are lighter. The stock ones are about as strong as the white spoke ones too.
1 2 3 4 5 6 7 8 9
180 BugZyla.com 85654 BAJAS at SONIC Eastsid...
 Thu Jun 14, 2018 09:10 PM
thing View latest post
55 GHOSTRIDER 39298 hello from ghostrider ...
 Sat Apr 29, 2017 06:16 AM
GHOSTRIDER View latest post
No new posts New Members New to bajas from Vt. 14 vtbaja 9460 New to bajas from Vt.
 Wed Aug 14, 2013 08:18 PM
No new posts Events and Get Togethers World Wide Bajas, Bugs, and Buggies at Sycamore Creek-March 2nd
55 JWHracing 33542 Bajas, Bugs, and Buggi...
 Sat Mar 09, 2013 07:55 PM
JWHracing View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Full bodied bajas 2 desertbaja 3754 Full bodied bajas
 Sun Aug 19, 2012 05:29 AM
sandfreaks View latest post
