Latest: xbluegto
Overall: 3573
Visitors: 75
Total: 75
02: My Account
16: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- VW noob
VW noob
RynoTheWyno
RynoTheWyno
Post Post subject: VW noob
Posted: Tue Apr 19, 2011 01:17 AM
Hello AzBaja!!! Very Happy
I just scored the MUTHER of all craigslist trades and landed myself a sick Baja! Twisted Evil Ive wanted a bug for a long time and definitely lucked out and landed myself one thats in real nice shape and mostly re-done.
[img] Uploaded with ImageShack.us[/img]
Theres a few things I need to work on....clutch is first, then the balljoint situation needs to be addressed....
....Id like the frontend as high as the rear and bulletproof. I plan to use these kingpins.....these will bolt right up, right?
Thats it for now...I look forward to learning as much as I can from all you VW vetrans and thanks in advance...Im off to buy some metric sockets....
Posted: Tue Apr 19, 2011 01:32 AM
Nice find,Welcome to the sight,,,,And no that linkpin will not bolt right up,,3 choices, Cut out pan head exchange it for a linkpin pan head, Buy a pre made front axle from bugzyla or replace ball joint and run what ya brung!
Posted: Tue Apr 19, 2011 01:34 AM
No. That linkpin front end does NOT bolt up to your ball joint car. It requires some modification. The tubes are spaced farther apart on the ball joint beam than on the linkpin beam. Adding that buggy front frame structure to a full roll cage in the car and cutting away some of the ball joint framehead would be one way to do it. replacing the ball joint frame head with a linkpin frame head would be another. A 3rd way would be to contact Daryl at Bugzyla about some conversion arms to put those spindle assemblies on your ball joint beam.
Posted: Tue Apr 19, 2011 01:36 AM
Razz Mojave,,,,,,lol
Posted: Tue Apr 19, 2011 02:08 AM
I hope thats not a fuel line i see in the pic of your ball joints, if so that would be my first move,,
RynoTheWyno
RynoTheWyno
Posted: Tue Apr 19, 2011 03:58 PM
Run what I brung! Hahaha I like your style, james lol I'll have to run what I brung because it wont sit still very long once I get that clutch disk in there Fri, have to take a closer look at that fuel line, good looking out. Thanks for the info fellas....conversion arms...I have some research to do....
Posted: Tue Apr 19, 2011 07:06 PM
There are 2 "lines" visible in that photo guys. One is the fresh black with yellow stripe brake hose. The other is the grundgy looking plastic and fabric covered hose along the edge of the pan. That is the line from the fuel vapor canister to the carb. part of the emissions system. I've never yet dealt with one of those systems which was intact and fully connected. So I can't even tell you how it should be hooked up. But a manual will.
RynoTheWyno
RynoTheWyno
Posted: Tue Apr 19, 2011 07:15 PM
Charcoal canister, expansion tank (wondered what that was) and the lines all seem intact, so I'll prolly leave it. Thanks for the heads-up.
Posted: Wed Apr 20, 2011 03:39 AM
Was talk,n about the old one not the nice and purty brake line,,,Follow it up into the trunk area tell us where it goes, if its and old canister its ok to yank,,,lol What year is the baja?
NAXZ
NAXZ
Posted: Wed Apr 20, 2011 05:42 AM
its a '72
RynoTheWyno
RynoTheWyno
Posted: Wed Apr 20, 2011 04:26 PM
Yes, its a 72 super with an 1835 and a later bug trans (3-rib?)
From that point in the picture, the line crosses over to the drivers side, up thru the fender over to the pass side of the trunk and into the expansion tank.....I thought it was a reserve....
Also from that point in the picture the line goes back to the charcoal canister which was hangin on by a thread....should this stuff stay or go?
This kinda stuff was always the first things to go on my old mopars lol....
Post Post subject: Re: VW noob
Posted: Thu Apr 21, 2011 01:34 AM
Depends on inspection for tags, I see you have a non stock carb, If all they do is the em test, And it passes no problem but if thay inspect for smog equip, then it should stay, that yr model is suppose to have it so they just might check, Dont know, never had anything new than a 67 inspected, And i dont have inspections in my state, and i dont think it a super beetle by the looks of your front shocks and ball joints, looks like a standard to me,,lol
RynoTheWyno
RynoTheWyno
Posted: Thu Apr 21, 2011 02:15 AM
The book says that equip came in the super, but I havent ran the vin yet so I dont know for sure
In Arizona (or Cochise County at least) anything pre-75 or registered as a classic is smog-exempt.
Posted: Thu Apr 21, 2011 07:57 PM
Wrong! Your car is NOT a Super. It's a Deluxe. Most Americans call them "standard" when they have a beam front suspension like yours, but all Bugs sold in the US were at least "Deluxe". They came with chrome hubcaps, bright trim around windows and along side of body and running boards, radio, carpet, 67 and earlier had bumper guards, etc. A "Standard" model was sold in Europe and 3rd world countries. They came with plain wheels/painted hubcaps, no "chrome" trim except door handles, plain window seals, plain bumpers with no guards, a filler plate where the radio goes, rubber floor mats, etc. Supers all had Macpherson Strut front suspension. 73 and later Supers had curved windshields.
If you don't have to smog it, I would delete the charcoal canister system. As it is now it's a hazard. But if you move to another county in AZ, the odds are good that you would have to get it smogged. Some counties require smogging cars back to around 68 (? - I'm in Cali, so I don't work under the same rules as AZ, but guys report smogging their cars on here. I'll leave it to the AZ guys to clarify on this).
Posted: Thu Apr 21, 2011 11:45 PM
67 and newer need testing as of now, They are trying to change it ,but for now thats how it is in AZ. I played hell trying to get mine to pass with my new motor and its a 67
No new posts New Members Noob with a thing... 5 gcarter85 4362 Re: Noob with a thing....
 Fri Jan 07, 2011 03:07 AM
Grunt-0341 View latest post
No new posts New Members Anutha Noob... 1 tasbaja 1685 Re: Anutha Noob...
 Fri Dec 31, 2010 06:56 AM
No new posts New Members Noob with a T3 1 DustinT3 1897 Re: Noob with a T3
 Sun Dec 05, 2010 07:23 PM
Rybob View latest post
No new posts New Members Noob outta Seattle 6 beginnerbaja 3882 Re: Noob outta Seattle
 Sun Feb 11, 2007 08:41 PM
Mykul View latest post
No new posts New Members Noob 11 R.e.J. 3483 Re: Snow
 Sat Nov 25, 2006 10:42 PM
R.e.J. View latest post
