Visitors: 102
Total: 102
02: Home
20: Event Calendar
37: Home
47: Pictures
49: Home
53: Event Calendar
59: Event Calendar
79: Pictures
86: Event Calendar
89: Event Calendar
1 2 3 ... 59 60 61 ... 103 104 105
Mjolnir
Mjolnir
Posted: Sat Apr 09, 2011 01:58 AM
AZ_Born_n_Raised wrote:
Finally got the engine put together, and drove it into Tucson yesterday. Went all the way to BAP to look at stuff, and on the way home it kept dying..it was acting like it wasn't getting any fuel. Help please? I think it may be the fuel pump =\
Did you fuel the car before going back?
If you did, it could be water contamination...
If not, get some fuel in the carb, and CAREFULLY disconnect the fuel supply hose, and then put it inside a clear glass jar with a lid and a punched hole for the hose... hold it CAREFULLY while another starts the car; have extinguishers at the ready...
You're watching for a pretty strong fuel delivery into the jar...if its weak or almost non-existent, its your pump...
Shut down before you over-fill that jar...or unpleasant hijinks will ensue...
Check your fuel for any water at the same time...you'll see it at the bottom of the jar...
REMEMBER...CAREFULLY, with all due respect that you're handling volatile liquids near a running engine...
Dave
AZ_Born_n_Raised
AZ_Born_n_Raised
Posted: Sun Apr 10, 2011 08:01 AM
No, I didn't fuel it before coming back. And the fuel filter is empty of fuel while the bug is running..isn't it supposed to have quite a bit of fuel in it all the time?
Posted: Sun Apr 10, 2011 01:28 PM
Make sure you do not have junk in your fuel lines change your filters. Check your tanks for anything clogging the fuel intake. Maybe a bad fuel pump.
AZ_Born_n_Raised
AZ_Born_n_Raised
Posted: Sun Apr 10, 2011 06:27 PM
If it is the fuel pump, where would I be able to get a replacement for fairly cheap?
Hyperwrx
Hyperwrx
Posted: Mon Apr 11, 2011 07:08 PM
Bought a aluminum dash. Hunting for gauges, switches, and buttons.
Looking for Autometer black faced gauges. Do not really need to be the same model line, just black. Speedometer, tachometer, oil pressure, oil temp, volts, and cylinder head temp.
Anyone have used stuff they're looking to get rid of?
Posted: Mon Apr 11, 2011 08:51 PM
Any diagnosis? Symptoms? Kinda hard to help from here without info on what is or is not checked or working.
A fresh clean filter will tend to be nearly empty as the fuel passes through it quickly. A dirty one will look full of fuel as the fuel flow is held up in the filter housing. i know it seems strange, but it's true.
I suggest Chirco for a pump.
bajaben1
bajaben1
Posted: Wed Apr 13, 2011 11:49 PM
Got new clutch put in, new TO bearing, mounted motor, put vaccuum lines on dual carbs (hope this will work, I dont' have mechanical advance distributor) Mounted motor, hooked wires up (looks like thats where they go) drained oil (PO put oil in but never started motor, been sitting for a while, better safe than sorry) put on throttle pinch bolt thingy, put tube through housing also for throttle cable. Tomorrow I'll put new oil in,crank the motor to get lubrication, check valves for adjustment, put spark plugs in, put fuel line into gas can, and see if it starts
dansbaja
dansbaja
Posted: Thu Apr 14, 2011 03:36 AM
Got a new carb, got running good, really good, getting it registered tomorrow, takin it to Johnson valley Friday!
Posted: Fri Apr 15, 2011 03:52 AM
Take it to Johnson Valley while you can. There is a meeting this evening at Victorville about the Marine Corps Take-Over of the Johnson Valley area. We are losing it!!!!!!!!!!
You're elected (NOT BY ME!!!) Senator says nobody goes out there anyway...It's just empty desert...I suppose the tens of thousands who were there for the race car crash into the crowd in August don't count...
dansbaja
dansbaja
Posted: Fri Apr 15, 2011 04:03 AM
Yea that sucks I wish I could go to the meeting but leaving tomorrow and live bout 3 hours away. Need to involved, we need places like Johnson valley, we need a place to get away to, a place where we like to have family time, a place to get out and do something!
Posted: Fri Apr 15, 2011 06:26 AM
Got a used set of unique Ten spoke wide five rear wheels (15x8) for the rail project I have.
tobiism
tobiism
Posted: Sat Apr 16, 2011 06:09 AM
I bought one!
My '73 coming home on the flatbed
in the garage, Max likes it!
crestfallen
crestfallen
Posted: Sat Apr 16, 2011 11:26 PM
removed engine to replace Single port heads with 041 dps and to change cam to c35... Found cracked #3 cylinder. Glad I caught it when I did.
Posted: Mon Apr 18, 2011 01:35 AM
OUCH! Good catch.
I pulled the dead battery from mine today. Dunno what the hell killed it. Evil or Very Mad She's been in storage for a couple months. Confused
dansbaja
dansbaja
Posted: Mon Apr 18, 2011 03:48 AM
Back from Johnson valley, family had a blast, " we needed that" wife figured out how to drive stick"will post pic later that was funny"
5 Admin_AzBaja 8350 Baja Bugs on Wiki need...
285 MusicManiac 255385 Re: Baja sightings
No new posts VW Volkswagen & Baja Bug General Discussion FREE VW BAJA'S 0 azdesertrat87 1214 FREE VW BAJA'S
No new posts VW Volkswagen & Baja Bug General Discussion Had to go play in the rain today! 3 azdesertrat87 2021 Re: Had to go play in ...
0 Northmountainauto 2181 Shop Baja
