Latest: George
Overall: 3576
Visitors: 119
Total: 119
13: Pictures
22: Event Calendar
27: My Account
51: Event Calendar
58: Pictures
67: Event Calendar
72: Event Calendar
112: Pictures
1 2 3 ... 58 59 60 ... 103 104 105
bajaben1
bajaben1
Posted: Tue Mar 29, 2011 10:49 PM
Brought home a second baja, this one is a 70, with those sweet white spoke rims. Now the surgery begins, I have to move the engine and all the goodies from the 65 i bought last week over to the 70, just wondering if i should convert it all to wide 5 or stay with the 4 lug. Hope i can convert the link pin front to the 4 lug so i can keep those sweet rims.
Rybob
Rybob
Posted: Fri Apr 01, 2011 10:28 PM
Went to Bugzyla to order my Conversion beam! Also going back for the tie rods etc. Cant wait to get this thing off the pavement Smile
(o\|/o)
AZ_Born_n_Raised
AZ_Born_n_Raised
Posted: Sat Apr 02, 2011 01:29 AM
Managed to get ahold of a second engine (finally) with a better case, but worse heads then the first, so I'm just gonna take the best from the 2 and put em together into one. Hope to have the baja up and running by next weekend
bajaben1
bajaben1
Posted: Sat Apr 02, 2011 03:33 AM
Pulled my motor today, need to get 200mm flywheel so it will fit into my 70 irs trans, also found out (while trying to put my car onto jack stands) that my heater channel on the rear drivers side, is complete junk, maybe i can cut the back out of my 65 and weld it in there? or maybe just replace it.
bajaben1
bajaben1
Posted: Sat Apr 02, 2011 03:39 AM
Hyperwrx
Hyperwrx
Posted: Sun Apr 03, 2011 03:38 AM
1. Put on 4 DZUS clips on 1 piece front end.
2. Got new front tires.
3. Turns on electric fuel pump and flooded the Empi 40 with gas going everywhere. Only 2 pounds of fuel pressure. Not sure what the problem is.
4. Mounted battery in box in the back.
5. Redid brakes lines on the front and put in new mater cylinder.
Posted: Tue Apr 05, 2011 10:03 AM
I'm thinking you might like to put hard lines for you fuel pump inside the car. Also your pump is to high it needs to be below the fuel tank. most fuel pumps/vane pumps will not pull a vacuum so there is now way to prime your pump.
Hyperwrx
Hyperwrx
Posted: Tue Apr 05, 2011 03:35 PM
Thanks for the suggestion. Yesterday pulled the electric fuel pump and reg out and went back to old mechanical pump and it started right up.
Posted: Wed Apr 06, 2011 07:58 AM
Can't say that I've ever run across any 5-lug hub to 4-lug wheel adapters. They COULD be made from 4-lug hub to 5-lug wheel adapters. But I would expect trouble with the 5-lug pattern lugs interfering with the wheels.
4-lug front drums do not fit onto link pin spindles. I have seen some disc kits that come un-drilled and if you then got them drilled to 4-lug...????
Posted: Wed Apr 06, 2011 04:08 PM
Wheel adapters are readily available in both 4 to 5 and 5 to 4 lug. You can buy linkpin rotors in 4 lug.
bajaben1
bajaben1
Posted: Thu Apr 07, 2011 01:30 AM
Thanks guys, i don't know what i'd do without you, actually i do,........NOTHING.
Hyperwrx
Hyperwrx
Posted: Thu Apr 07, 2011 04:18 AM
New tires on. Have about 15" of clearance in front and back.
Rybob
Rybob
Posted: Thu Apr 07, 2011 05:35 AM
NICE! What tires are those? You should make a project and build section thread, and make sure its pic heavy, because every time i log on i see more progress on that car! It looks like its coming along quite nicely! Cool
(o\|/o)
bajaben1
bajaben1
Posted: Fri Apr 08, 2011 12:03 AM
Found out the motor in the bug i bought as a parts car (purchased for the motor and rollbar and other parts) is actually a 1915, with new heads pistons and all the goodies, it has never been started. Sweet, christmas in april..... bought a pressure plate and TO bearing to fit it into my 70 irs baja
AZ_Born_n_Raised
AZ_Born_n_Raised
Posted: Fri Apr 08, 2011 10:30 PM
Finally got the engine put together, and drove it into Tucson yesterday. Went all the way to BAP to look at stuff, and on the way home it kept dying..it was acting like it wasn't getting any fuel. Help please? I think it may be the fuel pump =\
4 Admin_AzBaja 5917 Baja Bugs on Wiki need...
285 MusicManiac 223875 Re: Baja sightings
No new posts VW Volkswagen & Baja Bug General Discussion Had to go play in the rain today! 3 azdesertrat87 105 Re: Had to go play in ...
0 Northmountainauto 713 Shop Baja
No new posts New Members Baja hiding in Chandler 9 Upsbaja 2353 Baja hiding in Chandle...
