Latest: strike77
Overall: 3575
Visitors: 348
Total: 348
10: My Account
22: Event Calendar
26: Pictures
28: Pictures
29: Pictures
30: Pictures
31: Pictures
36: Pictures
37: Pictures
39: Pictures
40: Pictures
43: Pictures
50: Pictures
51: Pictures
58: Pictures
94: Pictures
103: Pictures
106: Pictures
108: Pictures
110: Event Calendar
113: Pictures
124: Pictures
128: Pictures
131: Pictures
132: Pictures
134: Event Calendar
136: Pictures
137: Pictures
139: Pictures
140: Pictures
142: Pictures
144: Pictures
147: Pictures
148: Pictures
149: Pictures
150: Pictures
151: Pictures
152: Pictures
154: Pictures
155: Pictures
156: Pictures
157: Pictures
160: Pictures
161: Pictures
162: Baja Forums
164: Pictures
168: Pictures
173: Pictures
176: Baja Forums
190: Event Calendar
195: Baja Forums
196: Baja Forums
197: Baja Forums
198: Baja Forums
199: Baja Forums
201: Baja Forums
202: Baja Forums
203: Baja Forums
204: Baja Forums
205: Baja Forums
207: AMAZON.com
208: Baja Forums
209: Baja Forums
210: AMAZON.com
212: AMAZON.com
213: AMAZON.com
214: Baja Forums
215: Baja Forums
216: Baja Forums
217: Baja Forums
218: Baja Forums
219: Baja Forums
220: AMAZON.com
221: Baja Forums
222: Event Calendar
225: Baja Forums
226: Baja Forums
227: Baja Forums
229: AMAZON.com
230: AMAZON.com
231: Baja Forums
232: AMAZON.com
233: Baja Forums
234: AMAZON.com
235: AMAZON.com
236: Baja Forums
237: AMAZON.com
238: AMAZON.com
239: Baja Forums
240: Baja Forums
241: AMAZON.com
242: Baja Forums
243: Baja Forums
244: Pictures
245: Baja Forums
246: Baja Forums
247: AMAZON.com
248: AMAZON.com
249: Pictures
250: Pictures
251: Pictures
252: Baja Forums
253: Baja Forums
254: Baja Forums
255: Pictures
256: AMAZON.com
257: Pictures
258: Pictures
259: Pictures
260: Pictures
261: AMAZON.com
262: AMAZON.com
263: Baja Forums
264: My Account
265: My Account
266: AMAZON.com
267: Baja Forums
268: Baja Forums
269: Baja Forums
270: Baja Forums
271: Baja Forums
272: Baja Forums
273: Baja Forums
274: Pictures
275: Baja Forums
276: Baja Forums
277: AMAZON.com
278: Baja Forums
279: AMAZON.com
280: Baja Forums
281: Baja Forums
282: Baja Forums
283: Baja Forums
284: Baja Forums
285: Baja Forums
286: Baja Forums
287: AMAZON.com
288: Baja Forums
289: AMAZON.com
290: Pictures
291: Baja Forums
292: Baja Forums
293: AMAZON.com
294: AMAZON.com
295: Baja Forums
296: Baja Forums
297: AMAZON.com
298: Baja Forums
299: Baja Forums
300: AMAZON.com
301: AMAZON.com
302: AMAZON.com
303: AMAZON.com
304: My Account
305: Baja Forums
306: AMAZON.com
307: Baja Forums
308: Baja Forums
309: Pictures
310: Baja Forums
311: AMAZON.com
312: AMAZON.com
313: Baja Forums
314: Baja Forums
315: Pictures
316: Pictures
317: Pictures
318: Event Calendar
319: Pictures
320: AMAZON.com
321: Baja Forums
322: AMAZON.com
323: Baja Forums
324: Baja Forums
325: Baja Forums
326: Baja Forums
327: Baja Forums
328: Pictures
329: Baja Forums
330: Baja Forums
331: Baja Forums
332: Baja Forums
333: Baja Forums
334: Baja Forums
335: AMAZON.com
336: AMAZON.com
337: Baja Forums
338: Baja Forums
339: Baja Forums
340: Baja Forums
341: Baja Forums
342: Baja Forums
343: Baja Forums
344: Baja Forums
345: AMAZON.com
346: Baja Forums
347: AMAZON.com
348: Baja Forums
Baja Forums -:- AzBaja.com Members -:- Projects and Builds -:- New Baja Build.. W/ Questions
logan44
logan44
Post Post subject: New Baja Build.. W/ Questions
Posted: Sun Apr 03, 2011 09:57 PM
Ok guys let me introduce myself. I'm 18 and have just gotten a Baja to build. I started with a simple pan buggy and now I'm hooked on Vw's.
Stats:
1969 Bug
1600 DP
Single Carb
IRS rear
Adjusters up front
I have a 4 pt bolt in cage(IDK how safe these kit roll cages look)
2 RaceCraft Susp. Seats
Set of 30x9.50x15's if they will fit
Fuel Cell to replace the back seat
I have a few questions though..
Right now it doesnt charge. I did the two tests I read about and the generator puts about 40-50 volts out with no load, so it tested good right? I also polarized it and it spun.. (another indication it is good?)
It wasnt passing the tests until I found a wire broken inside. It was the wire that connects to the DF terminal on the inside of the generator. Not the brush wire though..
The regulator looks new so obviously the P.O had the same problem..
The GEN light will come on if I run a jumper to its terminal on the regulator from the battery, but no other time. Not even if the belt is off. I think that is wrong, right?
I'm pretty mechanically inclined I just havent worked on VW's that much.. Give me a mopar and I can re-wire it in an hour lol.. (Ask me how I know Shocked )
Anyway, here she is.. Not to bad for what I got it for!
Posted: Sun Apr 03, 2011 10:26 PM
Welcome to the site. Keep the pics coming
jone$yyy
jone$yyy
Posted: Mon Apr 04, 2011 07:02 AM
nice car
Post Post subject: Re: New Baja Build.. W/ Questions
Posted: Tue Apr 05, 2011 04:12 AM
Welcome to AzBaja. If you can rewire an ol Mopar the VW is just as easy. The Bentley has the wiring diagram and test procedures for the generator. Generator supplies the ground for the gen light. With the key on if you ground the wire from the light to the regulator the light should light up. Building Bajas and Buggies shows how to modify the 4 point cage for best results.
Posted: Tue Apr 05, 2011 09:53 AM
I have a Duster and a Baja, Done wiring on both. If your Baja wiring is a rats nest just stand at the Back of the car and yank it all out. I did a full rewire on my baja in about 2 days. Has lasted me for well over 18 plus years now.
I also have ran an Orange Box from Duster on the Baja granted it has a Ford Engine, GM Alt, Chrysler Electron ignition and the Horn our of a Lincoln.
logan44
logan44
Posted: Tue Apr 05, 2011 05:04 PM
Haha Azbaja that is exactly what I did. I have since re wired almost everything, or at least have the wires laying in place. I found a rear windshield too! I'm trying to have it road worthy by my graduation in May
DeathBug
DeathBug
Posted: Tue Apr 05, 2011 05:27 PM
ha ha ha.. i think any original v-dub should have ALL wiring replaced A.S.A.P.... mine was completely trashed, and doin it myself took a few days bumper to bumper... good luck with the deadline and don't forget the great resorces at hand here in the forums! Twisted Evil
logan44
logan44
Posted: Fri Apr 08, 2011 03:26 AM
Ufta.. After a battle with the distributor I'm back making progress. Pictures coming tomorrow.
I have a set of 30x9.5x15's in the shop. Will they fit?. I put them up to the baja but its to close to call just by looking. What do you guys think?
Posted: Sat Apr 09, 2011 04:50 AM
They fit but trim the fenders or plan on launching the fenders in rough terrain.
logan44
logan44
Posted: Sat Apr 09, 2011 07:07 AM
Good to here. I think it will look sweet.
What about rubbing while turning? Is it bad?
logan44
logan44
Posted: Sat Apr 09, 2011 07:14 AM
Here is the progress from today..
-Mocked the seats
-Started a new dash
-Cleaned it up
-Tried to start it, no go
I have spark, i think I am getting fuel, gapped the new plugs, checked points... What am I missing? Timing?
-Mounted the VR and the other small box. What is the smaller one on the right?
More pics!
Posted: Sun Apr 10, 2011 10:29 PM
The relay on the right is the hi / low beam relay. Good spark and firing order correct? Fuel squirting from accelerator pump?
Posted: Mon Apr 11, 2011 10:31 PM
30 x 9.50s should fit fine on the rear. Too big for the front unless you have wider beam and longer arms.
- Is the firing order correct?
- Is the distributor properly installed?
- Definitely check the timing if it won't start.
4 Admin_AzBaja 5897 Baja Bugs on Wiki need...
1568 mufasavnvmc 925551 Re: what did you do to...
285 MusicManiac 223557 Re: Baja sightings
0 Northmountainauto 657 Shop Baja
No new posts New Members Baja hiding in Chandler 9 Upsbaja 2290 Baja hiding in Chandle...
