Visitors: 268
Total: 268
07: Event Calendar
13: Event Calendar
28: Event Calendar
43: My Account
44: My Account
45: My Account
46: My Account
68: Event Calendar
117: Pictures
122: Pictures
123: Pictures
130: Event Calendar
138: My Account
150: Baja Forums
154: Baja Forums
164: My Account
165: My Account
171: Baja Forums
176: My Account
177: My Account
178: My Account
179: Baja Forums
180: My Account
181: Home
182: Home
184: Baja Forums
185: Baja Forums
186: Baja Forums
188: Baja Forums
190: AMAZON.com
191: Event Calendar
193: My Account
195: My Account
196: My Account
197: My Account
198: AMAZON.com
199: Baja Forums
200: Event Calendar
201: Event Calendar
202: Baja Forums
203: Baja Forums
204: Baja Forums
205: Baja Forums
207: Baja Forums
208: Baja Forums
209: Baja Forums
210: Baja Forums
212: Baja Forums
213: Event Calendar
214: AMAZON.com
215: Event Calendar
216: Event Calendar
218: AMAZON.com
219: Event Calendar
220: AMAZON.com
221: AMAZON.com
225: Baja Forums
226: AMAZON.com
227: AMAZON.com
228: Baja Forums
229: AMAZON.com
230: AMAZON.com
231: Baja Forums
232: Baja Forums
233: AMAZON.com
234: AMAZON.com
235: Baja Forums
236: AMAZON.com
237: AMAZON.com
238: AMAZON.com
239: AMAZON.com
240: AMAZON.com
241: AMAZON.com
242: AMAZON.com
243: AMAZON.com
244: AMAZON.com
245: AMAZON.com
246: AMAZON.com
247: Event Calendar
248: Baja Forums
249: AMAZON.com
250: AMAZON.com
251: AMAZON.com
252: AMAZON.com
253: AMAZON.com
254: AMAZON.com
255: AMAZON.com
256: AMAZON.com
257: AMAZON.com
258: AMAZON.com
259: AMAZON.com
260: AMAZON.com
261: AMAZON.com
262: Baja Forums
263: AMAZON.com
264: AMAZON.com
265: AMAZON.com
266: AMAZON.com
267: My Account
268: AMAZON.com
Baja Forums -:- AzBaja.com Members -:- Projects and Builds -:- New Baja Build.. W/ Questions
logan44
logan44
Post Post subject: New Baja Build.. W/ Questions
Posted: Sun Apr 03, 2011 09:57 PM
Ok guys let me introduce myself. I'm 18 and have just gotten a Baja to build. I started with a simple pan buggy and now I'm hooked on Vw's.
Stats:
1969 Bug
1600 DP
Single Carb
IRS rear
Adjusters up front
I have a 4 pt bolt in cage(IDK how safe these kit roll cages look)
2 RaceCraft Susp. Seats
Set of 30x9.50x15's if they will fit
Fuel Cell to replace the back seat
I have a few questions though..
Right now it doesnt charge. I did the two tests I read about and the generator puts about 40-50 volts out with no load, so it tested good right? I also polarized it and it spun.. (another indication it is good?)
It wasnt passing the tests until I found a wire broken inside. It was the wire that connects to the DF terminal on the inside of the generator. Not the brush wire though..
The regulator looks new so obviously the P.O had the same problem..
The GEN light will come on if I run a jumper to its terminal on the regulator from the battery, but no other time. Not even if the belt is off. I think that is wrong, right?
I'm pretty mechanically inclined I just havent worked on VW's that much.. Give me a mopar and I can re-wire it in an hour lol.. (Ask me how I know Shocked )
Anyway, here she is.. Not to bad for what I got it for!
Posted: Sun Apr 03, 2011 10:26 PM
Welcome to the site. Keep the pics coming
jone$yyy
jone$yyy
Posted: Mon Apr 04, 2011 07:02 AM
nice car
Post Post subject: Re: New Baja Build.. W/ Questions
Posted: Tue Apr 05, 2011 04:12 AM
Welcome to AzBaja. If you can rewire an ol Mopar the VW is just as easy. The Bentley has the wiring diagram and test procedures for the generator. Generator supplies the ground for the gen light. With the key on if you ground the wire from the light to the regulator the light should light up. Building Bajas and Buggies shows how to modify the 4 point cage for best results.
Posted: Tue Apr 05, 2011 09:53 AM
I have a Duster and a Baja, Done wiring on both. If your Baja wiring is a rats nest just stand at the Back of the car and yank it all out. I did a full rewire on my baja in about 2 days. Has lasted me for well over 18 plus years now.
I also have ran an Orange Box from Duster on the Baja granted it has a Ford Engine, GM Alt, Chrysler Electron ignition and the Horn our of a Lincoln.
logan44
logan44
Posted: Tue Apr 05, 2011 05:04 PM
Haha Azbaja that is exactly what I did. I have since re wired almost everything, or at least have the wires laying in place. I found a rear windshield too! I'm trying to have it road worthy by my graduation in May
DeathBug
DeathBug
Posted: Tue Apr 05, 2011 05:27 PM
ha ha ha.. i think any original v-dub should have ALL wiring replaced A.S.A.P.... mine was completely trashed, and doin it myself took a few days bumper to bumper... good luck with the deadline and don't forget the great resorces at hand here in the forums! Twisted Evil
logan44
logan44
Posted: Fri Apr 08, 2011 03:26 AM
Ufta.. After a battle with the distributor I'm back making progress. Pictures coming tomorrow.
I have a set of 30x9.5x15's in the shop. Will they fit?. I put them up to the baja but its to close to call just by looking. What do you guys think?
Posted: Sat Apr 09, 2011 04:50 AM
They fit but trim the fenders or plan on launching the fenders in rough terrain.
logan44
logan44
Posted: Sat Apr 09, 2011 07:07 AM
Good to here. I think it will look sweet.
What about rubbing while turning? Is it bad?
logan44
logan44
Posted: Sat Apr 09, 2011 07:14 AM
Here is the progress from today..
-Mocked the seats
-Started a new dash
-Cleaned it up
-Tried to start it, no go
I have spark, i think I am getting fuel, gapped the new plugs, checked points... What am I missing? Timing?
-Mounted the VR and the other small box. What is the smaller one on the right?
More pics!
Posted: Sun Apr 10, 2011 10:29 PM
The relay on the right is the hi / low beam relay. Good spark and firing order correct? Fuel squirting from accelerator pump?
Posted: Mon Apr 11, 2011 10:31 PM
30 x 9.50s should fit fine on the rear. Too big for the front unless you have wider beam and longer arms.
- Is the firing order correct?
- Is the distributor properly installed?
- Definitely check the timing if it won't start.
5 Admin_AzBaja 6786 Baja Bugs on Wiki need...
1568 mufasavnvmc 999456 Re: what did you do to...
285 MusicManiac 241407 Re: Baja sightings
No new posts VW Volkswagen & Baja Bug General Discussion FREE VW BAJA'S 0 azdesertrat87 19 FREE VW BAJA'S
0 Northmountainauto 1530 Shop Baja
