Visitors: 112
Total: 112
27: Event Calendar
44: Event Calendar
51: Home
62: Event Calendar
104: Home
112: Event Calendar
1 2 3 ... 57 58 59 ... 103 104 105
AZ_Born_n_Raised
AZ_Born_n_Raised
Posted: Fri Mar 25, 2011 01:38 AM
Found out today that the previous owner of my Baja already had case savers in the engine case..and he stripped them right out of the aluminum, so my self tapping studs are now useless, and I'm gonna pretty much have to buy a whole new engine
Mjolnir
Mjolnir
Posted: Fri Mar 25, 2011 02:09 AM
Spent the last two days talking to powder-coaters to do my pan...
Pricing out new link pin frame heads compared to a steel adapter set to mount a linkpin in a balljoint front end...
Finding a good welder...and I hope he can do fabrication...
All that fun stuff...
Dave
BugLife
BugLife
Posted: Fri Mar 25, 2011 03:03 PM
Tore it down and found my crankshat to be all bad. Case and everything else is in good shape. Found a 78mm crank set up with new rods and needle bearings. Never heard of needle bearings befor this. Comes with all other bearings too. The price was less then $300 for all of it. Add my 94's and we'll be up and running once again. The price was my decision maker...lol.
Posted: Fri Mar 25, 2011 09:16 PM
TrailRail2110 wrote:
I bought two lightly used high back poly jaz seats and covers for the buggy for less whip lash effect, i felt they were a good deal at $60 for the pair.
Now how do i mount them so i dont hit my head on the roll bar because they sit up a bit higher...?
Good bargain. But the answer to your question will have to begin with another question...What do you have for seat mounts now?
Your answer with photos will help the rest of us help you figure out whether modifying your existing mounts or starting over will be the best solution.
bajaben1
bajaben1
Posted: Fri Mar 25, 2011 10:29 PM
rolled new baja off the trailer, and into the garage, man i could fit 3 of these things in my garage.....hmm mmmmmm....... wife said no way. Was going to go pick up second but it was snowing and I don't like to work out in the snow, especially while using methods that aren't that great to load a vehicle onto a trailer. Maybe monday, then the fun begins. What does it mean if my oil pan says BRAZIL on it, does this mean the motor came from brazil and coulb be much newer than 1965?
Posted: Sat Mar 26, 2011 02:17 AM
I fixed a cracked engine case. The 1776 in my daily driver got an odd crack in the top of the case above cylinder #1. So I spent a few days fixing it. Story in the thread on my Bug.
Posted: Sat Mar 26, 2011 02:23 AM
Cases came from VW since 1970 with case savers already installed.
You may be able to buy a case. Then you have to have it machined or at least checked by a machine shop for the correct bearings to work with your crank.
Posted: Sat Mar 26, 2011 07:16 PM
Pulled it out of garage,,,,let it run,,,,,walk around it a few times,,,looked at this,,,,looked at that,,,pulled it back into garage,,closed door,,,locked garage,,,,and thats all i got to say about that!
Crash
Crash
Posted: Sat Mar 26, 2011 10:11 PM
I actually drove my black car today. Started it up and drove it backwards twelve feet. Shut it down. Good times.
Mark
Mark Johnson
Blind Chicken Racing
www.blindchickenracing.com
Hooked
Hooked
Posted: Sat Mar 26, 2011 11:19 PM
brought mine home today just bought my first baja this morning its a 68
Posted: Mon Mar 28, 2011 12:07 PM
I'm planing a mode of attack. If I get all the other projects done I can start on the Baja again! Need to do to get the front done 1st the the back!
Posted: Mon Mar 28, 2011 07:21 PM
The folks here will all be looking for pics. And welcome to our addiction.
Posted: Tue Mar 29, 2011 03:45 AM
Got the pan all cleaned up and painted all new bushings front and rear. Rolled it outside and covered it up with a tarp. Did get the body moved into the shop and ready to do body work
cgoeschel
cgoeschel
Posted: Tue Mar 29, 2011 04:11 AM
sent it to Bugzyla down in Mesa for some suspension goodies. Cant wait!
gman3850
Colonel
Colonel
gman3850
Posted: Tue Mar 29, 2011 05:26 PM
Picted up a 64 baja today for 850, gonna go through the entire thing and rebuild it
5 Admin_AzBaja 6733 Baja Bugs on Wiki need...
285 MusicManiac 240884 Re: Baja sightings
No new posts VW Volkswagen & Baja Bug General Discussion Had to go play in the rain today! 3 azdesertrat87 1260 Re: Had to go play in ...
0 Northmountainauto 1504 Shop Baja
No new posts New Members Baja hiding in Chandler 9 Upsbaja 4073 Baja hiding in Chandle...
