Latest: Milkmanbryan
Overall: 3583
Visitors: 115
Total: 115
15: Home
32: Home
66: Home
67: Pictures
72: Event Calendar
79: Home
95: Event Calendar
99: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Bus Tran
Bus Tran
flyboy942003
flyboy942003
Post Post subject: Bus Tran
Posted: Mon Jul 28, 2008 03:32 AM
Hey is there a year of bus trans to stay away from or one to steer towards? Am thinking on going that route but was wanting to make sure I get the right one.
Post Post subject: Re: Bus Tran
Posted: Tue Jul 29, 2008 12:28 AM
Primarily you want a 3,5 or 6. Make sure it is a front shift, not a mid or side shift. Otherwise the shifter would be a PITA.
flyboy942003
flyboy942003
Posted: Sat Mar 26, 2011 04:00 AM
What is the 091 transmission? Is it a 6 rib only or anything out of a bus?
k-man
k-man
Posted: Mon Mar 28, 2011 04:05 AM
This should answer all your questions.
www.thesamba.com/vw/fo...p?t=143138
CatJockey
CatJockey
Posted: Mon Mar 28, 2011 04:32 AM
Side shift ya say?
Funny. Earlier today, while driving my bug, I had the thought 'It would be sweet if I could shift my seat about 6" to the right and get away from the door a bit'. Problem came when wondering how to do the shift rod.
I was thinking hydraulic pedals, gas and brake on right, hydro clutch on left. Accelerator cable tube would be a piece of cake and an external clutch rod tube as well. Some cutting and hammering in the back, but boy, if you don't need a passenger seat like I don't, it would be nice to have a bit more elbow room and Ford F350 front bumper protection. Get my head further away from internal roll cage, etc. Plus it would be cool.
Hmmm ....
flyboy942003
flyboy942003
Posted: Mon Mar 28, 2011 07:10 AM
That's awesome thank you. Talked to a guy today that said a 3 rib was just as good as a 6 but half the cost to buy. Any takers on that line of thinking?
Posted: Mon Mar 28, 2011 07:33 PM
The general consensus among gearbox builders for offroad racers is that the 091 is the strongest of VW gearboxes and the side shift is the strongest of 091s, but the shifter presents issues for many cars. Interestingly, the new Weddle HV-1 is a side shift box. Weddle has been manufacturing internal parts for VW-based high performance gearboxes for decades and supplies internals for other brands of aftermarket transaxles as well.
A 002 is quite a strong gearbox though just a shade behind the 091, and tends to be a lot less expensive. There are reasons for the price difference, but for most, the greater cost with the 091 is not worth the minor difference in result.
Posted: Mon Mar 28, 2011 07:39 PM
CatJockey wrote:
Side shift ya say?
Hmmm ....
By the time you get the tunnel cut away enough to move the seat over that far, you'd have been better off buying a Crumco chassis. The pan would be so weakened, a lot of additional cage work would be needed, and you may as well go full tube frame.
I don't think that's in line with your plans though CatJockey.
Getting back to the original question of this thread, the 1st year of 002 ('68) is quite different from the later ones and used Type 1 internals. It looks similar to other 002s, but has acorn nuts on the side near the CV. '69 or later 002 is fine.
CatJockey
CatJockey
Posted: Mon Mar 28, 2011 07:49 PM
Such as?
Posted: Mon Mar 28, 2011 08:01 PM
Just connecting the dots. Shift lever position to trans shift lever. With a tunnel, it's a problem, tube chassis not so much. But even in a tube frame, things like fuel cells tend to get in the way. Not a big problem if you're willing to pay 2x as much for a custom fuel cell with a shifter tunnel located differently.
