Visitors: 319
Total: 319
10: Home
19: Pictures
24: Event Calendar
28: My Account
41: My Account
59: My Account
98: My Account
99: My Account
100: My Account
101: My Account
102: My Account
119: My Account
121: My Account
122: My Account
123: My Account
125: My Account
126: My Account
127: My Account
129: My Account
130: My Account
131: My Account
164: Baja Forums
165: My Account
170: Baja Forums
173: My Account
174: My Account
175: My Account
176: My Account
179: Links
190: AMAZON.com
195: Baja Forums
197: Baja Forums
198: My Account
200: Baja Forums
202: AMAZON.com
204: AMAZON.com
205: Baja Forums
206: Baja Forums
207: AMAZON.com
208: Baja Forums
209: AMAZON.com
210: AMAZON.com
212: AMAZON.com
213: AMAZON.com
214: AMAZON.com
215: Baja Forums
218: AMAZON.com
219: AMAZON.com
220: Event Calendar
221: AMAZON.com
222: Event Calendar
225: AMAZON.com
226: AMAZON.com
227: AMAZON.com
229: AMAZON.com
230: AMAZON.com
231: AMAZON.com
232: Baja Forums
233: AMAZON.com
234: AMAZON.com
235: AMAZON.com
236: AMAZON.com
237: Baja Forums
238: AMAZON.com
239: AMAZON.com
240: AMAZON.com
241: AMAZON.com
242: AMAZON.com
243: AMAZON.com
244: Baja Forums
245: AMAZON.com
246: AMAZON.com
247: Baja Forums
248: AMAZON.com
249: AMAZON.com
250: AMAZON.com
251: AMAZON.com
252: Baja Forums
253: AMAZON.com
254: AMAZON.com
255: AMAZON.com
256: Pictures
257: Baja Forums
258: Pictures
259: Pictures
260: Pictures
261: My Account
262: Pictures
263: Pictures
264: AMAZON.com
265: Baja Forums
266: Baja Forums
267: AMAZON.com
268: AMAZON.com
269: AMAZON.com
270: AMAZON.com
271: AMAZON.com
272: AMAZON.com
273: AMAZON.com
274: AMAZON.com
275: AMAZON.com
276: AMAZON.com
277: Baja Forums
278: AMAZON.com
279: AMAZON.com
280: AMAZON.com
281: AMAZON.com
282: AMAZON.com
283: AMAZON.com
284: AMAZON.com
285: AMAZON.com
286: AMAZON.com
287: Baja Forums
288: AMAZON.com
289: Baja Forums
290: AMAZON.com
291: Baja Forums
292: AMAZON.com
293: Baja Forums
294: AMAZON.com
295: AMAZON.com
296: AMAZON.com
297: Baja Forums
298: AMAZON.com
299: AMAZON.com
300: AMAZON.com
301: AMAZON.com
302: Baja Forums
303: Baja Forums
304: Baja Forums
305: Baja Forums
306: AMAZON.com
307: AMAZON.com
308: AMAZON.com
309: AMAZON.com
310: AMAZON.com
311: AMAZON.com
312: AMAZON.com
313: AMAZON.com
314: AMAZON.com
315: AMAZON.com
316: AMAZON.com
317: AMAZON.com
318: AMAZON.com
319: AMAZON.com
1 2 3 ... 55 56 57 ... 103 104 105
Posted: Wed Feb 23, 2011 07:19 AM
MojaveRacer208 wrote:
I should be takein my baja home!!! This week. Will have to paint all the new parts do some rewireing install an new ignition and then be ready to go!!!
I haven't seen fresh photos of your car on here for a long time. What's it like these days?
Looks about the same just needs paint. The paint on the car was done around 93 or 94 time frame. Bugz thinks it can be buffed out as it was good paint and maybe just oxidized real bad.
Posted: Mon Feb 28, 2011 11:55 PM
Started doing the wireing on Project Willy Style, also started the rebuild on the pedals. Marked a couple things off the parts needed lists for all 4 cars, still no closer to having a running car though Sad
Hyperwrx
Hyperwrx
Posted: Wed Mar 02, 2011 05:06 AM
Pulled old rear cage, old exhaust, and added new exhaust.
BugLife
BugLife
Posted: Thu Mar 03, 2011 07:54 PM
Started to pull the engine off, ready for another rebuild and a paint job. Changing the color to "RootBeer" Black Walnut dash all laqured with new gages & this time a stero with Bluetooth. Pulling all glass for the paint. Will post pics along the way.
Hyperwrx
Hyperwrx
Posted: Sat Mar 05, 2011 03:58 AM
Bought a 1 piece fiberglass front end. Baja goes under the knife this weekend.
I wish someone gave good step by step instructions on what to cut up front with good pictures.
Hyperwrx
Hyperwrx
Posted: Sun Mar 06, 2011 02:54 AM
Cut front end down for new front end. Some test fit pictures.
Posted: Tue Mar 08, 2011 02:14 AM
Good job! You've retained the inner fender panels which will help keep caca out of the front and away from wiring, etc. 1st time I've ever seen anyone else do what I have done.
I have some rubber garage door seal to bolt to the fender holes so the lip will seal against the underside of the fenders. I hemmed the edge of the metal where I cut it to add strength and keep from getting cut. You can see the hem on the far side. I feel the rubber needs something to apply even force along the edge like a lip off an old fender or something.
Then I also intend to make a panel across in front of the gas tank to seal that opening off.
Now the downside to what you've done...
The doors will sag. You need to brace from the roll cage to the hinge area at the sides of the dash. In mine, the right door in particular tends to come unlatched just on the street. Strangely, it is far less likely to unlatch on dirt. Part of my problem is the 58 latches. It would probably be far less of a problem if the car had later style latches. But the doors will still sag when you open them.
Posted: Tue Mar 08, 2011 03:00 AM
For hinge and latches
Interior of the hinge is visible at the left. Hood pins are visible at the right in the rain channel with rubber seals.
There are also 1/4" thick neoprene rubber pads on the inside of the hood at the lower rear corners to prevent rattles. The rubber is glued on with weatherstrip adhesive and retained with a pair of 8-32 screws.
Hyperwrx
Hyperwrx
Posted: Tue Mar 08, 2011 03:02 AM
The welding of a brace to help door sag is smart. I'll do that. You are just extending a tab to the inside of the door area from your vertical roll cage bar or the one running horizontal under the dash?
Posted: Tue Mar 08, 2011 03:32 AM
1969Baja
1969Baja
Posted: Wed Mar 09, 2011 02:58 AM
I ripped every little last piece of wire out of my bug... gonna re-wire everything up to toggle switches.
AZ_Born_n_Raised
AZ_Born_n_Raised
Posted: Thu Mar 10, 2011 12:32 AM
Swapped out the blown Rancho front shocks for some fairly new KYB's, and put some air in the rear air shocks. They hold air with only a very slight leak. Also pulled the valve cover off the left head to start re-torqueing all of the bolts, only to find that 3 of the 4 bolts that are actually in with the valves are stripped down on the block itself..that would explain the oil leak, does anyone know how I could fix that? I also got down under the front end to see why the brakes are barely working (and that's with almost putting the peddle through the floor) and the only 2 things I can think it is, is that either the lines need to be bled, or it needs a new master cylinder. Any and all opinions and tips are welcome. =)
Posted: Thu Mar 10, 2011 05:07 AM
dont know what you mean about heat sinks,But it sounds to me(if your head bolts are striped in the case|) you need to put in some case savers, which is a threaded insert that goes into the case then the head bolts screw into them,This involves pulling both heads off ,maybe pulling jugs too,Not certain if you have to split case or not,,i think you can put them in with out splitting case but then you would get shavings of metal inside your case (not good)I would spit the case my self. ( WHAT SAY YOU PEEPS?)
AZ_Born_n_Raised
AZ_Born_n_Raised
Posted: Thu Mar 10, 2011 08:31 AM
Where can I get ahold of those and what's the price range? Sadly I'm on a budget =( Would it also be possible to use self tapping head bolts? (I think that's what they are)
TrailRail2110
TrailRail2110
Posted: Thu Mar 10, 2011 06:35 PM
I took my motor to Steve Norris at Norris racing in Milford, MI to breath some fresh life and get some more power out of it, i hope it doesn't break the bank to do so.
Plus this weekend going to yank my 4.37 type 1 switch over to a 4.12 and moving my super diff, hd forks and hd side cover over to the new trans too. This should be stonger set up and better handle the power of the new motor. I also hope the Taller gears give me more use, expecially out of first which currently is only a tractor gear.
Picked up a 400watt marine amplifier to replace my 240watt, now i hope to hear my music over the roar of the motor!
also, grabbed a used set of sand tires unlimited 1300 plus paddle tires on Douglas aluminum wheels for only $300. should make getting around the dunes and little faster!
I am trying to be ready for the spring and hit it hard!!!
I am looking for any other Michigan people to ride with this summer, PM me!
5 Admin_AzBaja 6775 Baja Bugs on Wiki need...
285 MusicManiac 241224 Re: Baja sightings
No new posts VW Volkswagen & Baja Bug General Discussion FREE VW BAJA'S 0 azdesertrat87 9 FREE VW BAJA'S
No new posts VW Volkswagen & Baja Bug General Discussion Had to go play in the rain today! 3 azdesertrat87 1276 Re: Had to go play in ...
0 Northmountainauto 1522 Shop Baja
