Visitors: 97
Total: 97
05: Event Calendar
23: Event Calendar
41: Links
56: Pictures
82: My Account
96: Home
Baja Ghia
1 2 3 ... 8 9 10 11
igivup30
igivup30
Posted: Sat Feb 19, 2011 05:45 PM
where did you get the aluminum gas tank I have been looking for one. Tha Ghia looks great bye the way.
Post Post subject: Baja Ghia
Posted: Mon Feb 21, 2011 05:43 AM
Thanks everyone. It's so close. I got the tank from Summit Racing. They have several different sizies
Baja_Blue
Baja_Blue
Posted: Sat Feb 26, 2011 06:54 AM
Wow, looks amazing. Great job with all the quality work and not taking any shortcuts. Can't wait to see it finished.
Btw, are you running 5x4.5 bolt pattern disks?
Also, how many gallons is your cell? Looks familiar Cool
Matthew 5:14-16
Posted: Mon Feb 28, 2011 05:53 AM
I am running 5x4.5 chevy pattern wheels. Figured it would give me more options on wheels. Yeah, that cell does look familiar. Mine is the 15 gallon one.
Posted: Mon Feb 28, 2011 06:07 AM
Well, after 4 long years the "Baja Ghia" went for it's first test drive this weekend. We went to Glamis and met some friends, and after working on it for most of the morning on Sat was able to go for a spin. Here are the photos.
Posted: Mon Feb 28, 2011 06:15 AM
Still have several things to get worked out, like the CV's. Had to loosen up the rear suspension to almost nothing in order to get them to stop binding. Will have to go with some better CV's and longer axles in order to get the travel I want and need. Need to adjust the shocks all the way around, think I have the right springs, but don't think the valving is even close. Also, the steering absolutely sucks! Don't know if it's the toe in or the rack or what, but it's pretty bad, actually EVIL is a better term. Other than that, not bad. Cruised over to the drags on Sat and actually had people coming out of thier trailers to watch me go by. Had lots of people looking and a lot of good comments, so that felt pretty good. I have a few little things to do, then plan to enter it in the Bug O Rama this year. Will keep the posts coming on all updates.
Posted: Mon Feb 28, 2011 06:30 AM
I told you that steering set up sucks, I couldn't steer the proseatz baja either. Its great to see it out, I love that car and enjoyed working on it: )
Posted: Mon Feb 28, 2011 07:55 AM
Get rid of that rack and pinion and replace it with a Saco. I have the Saco in the fasty and it works great. All of the cars I have seen with the rack you have dont steer well and have a crappy turning radius.
Posted: Tue Mar 01, 2011 12:11 AM
Congats on finally getting it going and the first voyage. Looks great cant wait to see it in person.
bugzapper
bugzapper
Posted: Tue Mar 01, 2011 02:01 AM
the 5x 4.5 should be the same as the ford ranger and older ford cars as well
"killing time isnt murder -- its suicide"
Baja_Blue
Baja_Blue
Posted: Fri Mar 04, 2011 08:52 PM
X2. 5x4.5 is what I have on the baja so I could run the same bolt pattern rims as my brother's Ranger in case either of us gets a flat.
Great work again, just gotta work out the little kinks now!
Matthew 5:14-16
_-Mad-Max-_
_-Mad-Max-_
Posted: Mon Mar 07, 2011 07:29 PM
i was wondering about your 3" body lift. how did you make it for the ghia and the front a rear pieces of it how did you make those too? and also how hard would it to keep the stock steering shaft and box after a body lift?
thanks
im in need of a new front clip for my 74 ghia, i dont care what year its from but i need one in order to fix my front end, can anyone help out?
Posted: Mon Mar 07, 2011 09:22 PM
Thanks guys for the input. I'm currently planning to get it to the BugORama show here in Phoenix here in a couple weeks.
To answer your questions Mad Max, most of the 3" lift was fabbed by yours truely, other than the front piece that goes over the tunnel. Bugzyla makes a kit that you can weld together for this, and since the it is the same as a bug, it makes it easy. Otherwise, I used 1 1/2" x 3" square tubing for the rest of the lift. As far as using the stock steering box after putting the lift on, not a problem, people do it all the time. I just got stubborn and wanted power steering, which I think will be good once I get all of the bugs worked out, but it is a substantial cost. Figure at least a grand on the cheap end not counting cost of the rack.
_-Mad-Max-_
_-Mad-Max-_
Posted: Mon Mar 07, 2011 09:35 PM
alright thanks cause thats going to be my first step in bajaing my ghia is the body lift. how would i make the stock steering shaft and wheel work with the lift. i also dont want to add a cage to the car as it will see more street then off road
Posted: Tue Mar 08, 2011 10:13 AM
Cool, Now are you a builder or a driver??? Seems like the Builders build cool cars then get tired of it...:( and start a new car. I hope you are a driver.
1 2 3 ... 8 9 10 11
5 Admin_AzBaja 6803 Baja Bugs on Wiki need...
1568 mufasavnvmc 1000013 Re: what did you do to...
285 MusicManiac 241547 Re: Baja sightings
No new posts VW Volkswagen & Baja Bug General Discussion FREE VW BAJA'S 0 azdesertrat87 29 FREE VW BAJA'S
0 Northmountainauto 1535 Shop Baja
