Visitors: 171
Total: 171
53: Event Calendar
100: Event Calendar
101: Event Calendar
103: Event Calendar
104: Pictures
106: Event Calendar
131: Pictures
153: Event Calendar
154: Baja Forums
168: Baja Forums
Baja Forums -:- AzBaja.com Members -:- Projects and Builds -:- 58' on a 68 pan will it work?
Bryman042
Bryman042
Post Post subject: 58' on a 68 pan will it work?
Posted: Thu Feb 24, 2011 12:11 AM
hey guys i was wondering will a 58 body fit on a 68 irs pan?
Never swapped bodies before so i was wondering before i started tearing it apart.
BUILD IN PROGRESS
crestfallen
crestfallen
Posted: Thu Feb 24, 2011 12:18 AM
Yes it will. This is a somewhat common swap. (early bug to IRS)
Bryman042
Bryman042
Post Post subject: Re: 58' on a 68 pan will it work?
Posted: Thu Feb 24, 2011 12:44 AM
cool thanks man. Guess i got a lot to do in a little bit of time. Wanna atleast take it out a couple of time before the weather goes to crap.
BUILD IN PROGRESS
Posted: Thu Feb 24, 2011 02:34 PM
The only mods you will have to make is on the rear of the body. There is a mount on the body that sits on the upper part of the shock tower on the pan. You will have to cut the mount off of the body and relocate it about an inch up. Not hard to do.
If the pan is an IRS and its a 68, make sure its not from an autostick car. If it is there will be no clutch tube. You will need to install a clutch tube (for the clutch cable to run through) in order to run the 4 speed trans. Its easier to do with the body off.
No new posts VW Volkswagen & Baja Bug General Discussion Engine Work 5 ghs215 1815 Re: Engine Work
 Mon Jan 08, 2018 12:59 AM
No new posts VW Volkswagen & Baja Bug General Discussion Server work has been done by godaddy. 6 AzBaja 4933 Server work has been d...
 Fri Jun 22, 2012 04:21 PM
No new posts New Members I need some one to do the work for me.
1970 Baja needs to be put together.
3 BaJohn 3040 I need some one to do ...
 Tue Jun 29, 2010 05:42 PM
No new posts VW Volkswagen & Baja Bug General Discussion Baja parts would they work together? (Any advice)
22 Timotyman 10683 Baja parts would they ...
 Sun Dec 06, 2009 10:15 AM
ChuckD View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Headlights wont work 8 bajamtbiker 7557 Re: Headlights wont wo...
 Sat Jul 11, 2009 04:57 AM
bajamtbiker View latest post
