Latest: xbluegto
Overall: 3573
Visitors: 99
Total: 99
08: Event Calendar
11: Event Calendar
22: My Account
26: Pictures
61: Pictures
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- starter bug
starter bug
bugzapper
bugzapper
Post Post subject: starter bug
Posted: Tue Feb 15, 2011 02:58 AM
i may have found a baja starter project-- what is all involved in putting a ford 2.3 in a bug?? what all do i need?
"killing time isnt murder -- its suicide"
Post Post subject: Re: starter bug
Posted: Tue Feb 15, 2011 04:35 AM
$$$$$$$$$$$$$ Shocked Cool
You need a motor, adapter plate, radiator, header. I would recomend at LEAST 3x3 arms in the rear or you will have the front end up in the air more times than not. You can stick with the bug trans, but just use a stock clutch like Eric does so the trans will hold up, but obviously a bus trans would give you better service.
Posted: Tue Feb 15, 2011 04:37 AM
And you might consider an Ecotec motor, they are cheap ($300-$500) and readily available, and only 50 lbs heavier than a bug motor.
bugzapper
bugzapper
Posted: Tue Feb 15, 2011 04:54 AM
okay i might stick with a bug motor for now but this bug doesnt have an engine so i was just wondering if it was feesable for me to go straight to the 2.3 but i might be able to get my hands on a FI super beetle engine
i was wondering if it is possible/ what the benifits are to put a diesel 2.3 in
Or the ford 2.9
thanks
thext94
thext94
Posted: Tue Feb 15, 2011 05:01 AM
Ecotec is the easiest (relatively) and least expensive swap, unless you're set on the ford engine. I've been looking to do an ecotec swap for awhile now, just need the $$$
bugzapper
bugzapper
Posted: Tue Feb 15, 2011 05:12 AM
the ecotec looks like a spendy swap its a relatively new engine---im guessing an adapterplate is needed just as the ford needs an adapter plate--what makes it easier or cheaper?
i am a fan of ford but im also a fan of Cheap upgrades
Posted: Tue Feb 15, 2011 05:16 PM
Posted: Tue Feb 15, 2011 06:53 PM
Unless you get everything for the conversion with the 2.3 Ford engine just go for the Eco tech conversion. Everything required for the Ford swap is the same as the Eco swap. Standard Eco engines are dirt cheap $500. And they are fuel injected and are not over 20 years old like the 2.3. The 2.3 swap was state of the art 25 years ago. With out upgraded suspension and transmission all you end up with is a butt heavy, ill handling Baja.
bugzapper
bugzapper
Posted: Wed Feb 16, 2011 04:23 AM
thank you guys
Posted: Thu Feb 17, 2011 02:33 PM
The motor adapter is about the same price for either Ford 2.3 or Ecotec. The Ecotec requires the electronic system and computer. You can find Ecotec engines for $500, but the wire harness, sensors and computer setup and programming typically costs over $2K. You can do a Ford 2.3 with a carb and conventional ignition and eliminate that portion of the cost. Later FI forms of the Ford will run into the same computer costs as the Ecotec. Other late model engines such as Honda or Toyota deal with the same cost factors.
Such a swap would be silly with a stock Type 1 gearbox. It was designed for 40hp. A Bus 002 would be the minimum in my book and many who are using Ecotecs are upgrading beyond into Mendeola or Weddell gear boxes for ~$7-8K plus installation costs.
Suspension upgrades would be needed to support any above engine swap too as Daryll said.
The FI late Bug engine brings its own set of problems. But the EFI can be replaced with a carb like a single 40 IDF Weber which will give good performance and reliability for a few hundred$. Dual Kadrons or even a Solex 34PICT 3 would also work on that engine.
No new posts VW Volkswagen & Baja Bug General Discussion Solenoid/Starter, eh? 10 bugengr 4786 Re: Solenoid/Starter, ...
 Sat Mar 24, 2007 03:59 AM
Bubba View latest post
No new posts VW Volkswagen & Baja Bug General Discussion starter/trans problem NEED HELP!!! 5 milleraj119 1921 Re: starter/trans prob...
 Fri Feb 02, 2007 05:49 PM
