Latest: xbluegto
Overall: 3573
Visitors: 134
Total: 134
03: My Account
23: Event Calendar
27: My Account
38: Event Calendar
65: Event Calendar
97: My Account
102: Pictures
115: Drivers
1 2 3 ... 54 55 56 ... 103 104 105
Posted: Thu Jan 27, 2011 03:18 AM
Seems you have neck problems or you need a rear view mirror.
[/quote]
Posted: Thu Jan 27, 2011 03:19 AM
I looked at my Baja today...Some one else is doing the work this time...
Posted: Thu Jan 27, 2011 04:57 AM
I charged the battery on the Fasty and put some gas in it so I could drive it. My suburban needs a throttle body overhaul and I dont have time to mess with it for a few days.
And as for the shop, we put a shift rod in a big green baja today, built a 3" body lift and a set of 3x3 rear arms, and other little projects. Laughing
Rybob
Rybob
Posted: Sun Feb 06, 2011 01:59 AM
Saw a Blue and White bug with Chirco on the side heading down University towards Power a little before 2 pm today. I believe i remember it from the Chirco show and i think its Mykuls car? Anyways nice bug either way! Good to see a VW out here in old people town!
(o\|/o)
Posted: Sun Feb 06, 2011 06:21 AM
I did nothing haven't touched my Baja in months Sad Been too buzy at work and working on the kid's bajas.
mikehtiger
mikehtiger
Posted: Sun Feb 06, 2011 07:17 AM
I Drove mine into work today!
Also bought aluminium dash and door panels, and a roll cage. And installed nerf bars and a light bar!
Posted: Mon Feb 07, 2011 11:11 PM
Drove it 70 miles by sunrise.
25 miles to take my wife to her vanpool to go another 60 miles to work and then back.
Then another 10 miles to take my son to High School and then back. Then time for breakfast and I'm about worn out.
Lot of miles for working at home ain't it!?!?
Thursday I took the beam out to drill out a broken lower adjuster screw and replace it. Back together just in time to go fetch my wife from the bus bringing her home from work. Hardened screws can be such a pain to drill. If the body were cut more, I could have drilled it without pulling the beam, but then the support for the stock gas tank would be compromised.
Normal ride height
Thursday
Getting started
Broken adjuster...The pressure block and upper part of the screw were laying in the skidplate in spite of having driven the car about 150 miles since the break. I expected them to be gone.
The broken off pieces. The screw broke in 2 places about 3 threads apart. The small wafer piece was still laying in place and lifted out with my fingers
Rather than disconnecting the brake lines and having to re-bleed, I dropped the beam so the upper tube was in the lower brackets and held it there with ratchet straps and a pair of beam clamps.
Had to pop off the tie rods and the steering box though.
Here's the extractor and the broken piece
I recently ordered some new screws for another car and Sway-A-Way referred me to Kartek as the closest source. They also gave me the part numbers to speed the ordering. I wound up receiving plain Allen Bolts they must have gotten straight from the hardware store shelf. Not specially ground point set screws. Had to grind the points myself. I told Sway-A-Way and they were unhappy as well. I could have gone to the local hardware store and bought them for about the same price and gotten them immediately instead of waiting a week for them to be shipped.
dansbaja
dansbaja
Posted: Tue Feb 08, 2011 02:24 AM
Hi, I'm a newbie. Got mine runnin better and changed the front bushings. Will post pic later.
thext94
thext94
Posted: Tue Feb 08, 2011 02:27 AM
Parker 425
Tyler
ghettodish
ghettodish
Posted: Wed Feb 09, 2011 05:50 AM
my first super beetle, and 21st bug
My neighbor gave it to me Smile
ghettodish
ghettodish
Posted: Mon Feb 14, 2011 05:22 AM
Put in a new steering column, replaced some wiring, replaced glove box lock, installed a new Optima battery.
Posted: Wed Feb 16, 2011 07:34 AM
I should be takein my baja home!!! This week. Will have to paint all the new parts do some rewireing install an new ignition and then be ready to go!!!
Posted: Wed Feb 16, 2011 07:39 AM
I started mine today!!!!
Posted: Thu Feb 17, 2011 02:17 PM
I haven't seen fresh photos of your car on here for a long time. What's it like these days?
dansbaja
dansbaja
Posted: Wed Feb 23, 2011 01:04 AM
[img][/img]took mine out to johnson valley this weekend
4 Admin_AzBaja 5720 Baja Bugs on Wiki need...
285 MusicManiac 219192 Re: Baja sightings
0 Northmountainauto 283 Shop Baja
No new posts New Members Baja hiding in Chandler 9 Upsbaja 1564 Baja hiding in Chandle...
Off-road event
1 wideopenmotorsports 967 Re: Baja run in March
 Mon Jan 08, 2018 06:09 PM
