Visitors: 101
Total: 101
21: Event Calendar
44: Home
52: Event Calendar
59: Event Calendar
78: Event Calendar
86: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- best way to mount a light bar or roof rack?
woodin
woodin
Post Post subject: best way to mount a light bar or roof rack?
Posted: Wed Feb 02, 2011 01:04 AM
im welding up a light bar for my bug, but not exactly sure best way to mount it to the roof. i see the store bought ones mount on the rain rails but i just dont see that being very strong. It also rains here a lot in tennessee so if i go drilling holes in the roof to bolt it in it would have to completely water proof. any input?
crestfallen
crestfallen
Post Post subject: Re: best way to mount a light bar or roof rack?
Posted: Wed Feb 02, 2011 01:24 AM
My light bar is redone so that it mounts to the same holes as the visor. It cleans the roof up a bit.
thext94
thext94
Posted: Wed Feb 02, 2011 02:22 AM
what about attaching it to the cage? (if you have one?)
Tyler
woodin
woodin
Posted: Wed Feb 02, 2011 06:40 AM
those both look good although i dont have a roll cage. but how are yall water proofing the holes you drilled through the roof? rubber gasket and silicone or something?
thext94
thext94
Posted: Wed Feb 02, 2011 06:43 AM
I'm using silicone sealant
crestfallen
crestfallen
Posted: Wed Feb 02, 2011 05:32 PM
Same here lol. Hasnt leaked yet
Posted: Wed Feb 02, 2011 11:16 PM
I have a stock roof rack on my baja and just welded 1x1 angle iron bar to the rack with hols boared in the bar for the lights.
woodin
woodin
Posted: Mon Feb 07, 2011 02:31 AM
i decided to go with a straight bar across the top with two 7 inch lights and two 5 inch lights. o00o <--- like that kinda. then welded to vercial pipes on each end and welded flat pieces on the bottom of the vert pipes to bolt into the roof. i cut up an old caution cone (redneck i know) and made some gaskets with it. and will also silicone the piss out of it. sounds confusing but pics to come in the near future.
No new posts VW Volkswagen & Baja Bug General Discussion Cool VW Bug Roof Rack 0 wideopenmotorsports 3570 Cool VW Bug Roof Rack
 Wed Jun 15, 2016 09:46 PM
No new posts VW Volkswagen & Baja Bug General Discussion Need Opinions On Light Bar
62 57baja 98428 Re: Need Opinions On L...
 Sun May 24, 2015 04:28 AM
69yellowbaja View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Rack and Pinion setup on a Baja bug 3 DFWbaja 3730 Rack and Pinion setup ...
 Fri Jan 30, 2015 01:44 PM
what do you use
4 bdrdunes 2953 Baja bug rear led ligh...
 Thu Dec 18, 2014 02:55 AM
No new posts VW Volkswagen & Baja Bug General Discussion oil light
electrical
5 terribletommy 2181 oil light
 Thu May 22, 2014 08:56 PM
