Visitors: 82
Total: 82
01: Home
16: Event Calendar
23: My Account
34: Home
41: Home
42: Event Calendar
63: Event Calendar
67: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- best way to mount a light bar or roof rack?
woodin
woodin
Post Post subject: best way to mount a light bar or roof rack?
Posted: Wed Feb 02, 2011 02:04 AM
im welding up a light bar for my bug, but not exactly sure best way to mount it to the roof. i see the store bought ones mount on the rain rails but i just dont see that being very strong. It also rains here a lot in tennessee so if i go drilling holes in the roof to bolt it in it would have to completely water proof. any input?
crestfallen
crestfallen
Post Post subject: Re: best way to mount a light bar or roof rack?
Posted: Wed Feb 02, 2011 02:24 AM
My light bar is redone so that it mounts to the same holes as the visor. It cleans the roof up a bit.
thext94
thext94
Posted: Wed Feb 02, 2011 03:22 AM
what about attaching it to the cage? (if you have one?)
Tyler
woodin
woodin
Posted: Wed Feb 02, 2011 07:40 AM
those both look good although i dont have a roll cage. but how are yall water proofing the holes you drilled through the roof? rubber gasket and silicone or something?
thext94
thext94
Posted: Wed Feb 02, 2011 07:43 AM
I'm using silicone sealant
crestfallen
crestfallen
Posted: Wed Feb 02, 2011 06:32 PM
Same here lol. Hasnt leaked yet
Posted: Thu Feb 03, 2011 12:16 AM
I have a stock roof rack on my baja and just welded 1x1 angle iron bar to the rack with hols boared in the bar for the lights.
woodin
woodin
Posted: Mon Feb 07, 2011 03:31 AM
i decided to go with a straight bar across the top with two 7 inch lights and two 5 inch lights. o00o <--- like that kinda. then welded to vercial pipes on each end and welded flat pieces on the bottom of the vert pipes to bolt into the roof. i cut up an old caution cone (redneck i know) and made some gaskets with it. and will also silicone the piss out of it. sounds confusing but pics to come in the near future.
No new posts VW Volkswagen & Baja Bug General Discussion Cool VW Bug Roof Rack 0 wideopenmotorsports 2565 Cool VW Bug Roof Rack
 Wed Jun 15, 2016 09:46 PM
No new posts VW Volkswagen & Baja Bug General Discussion Need Opinions On Light Bar
62 57baja 93540 Re: Need Opinions On L...
 Sun May 24, 2015 04:28 AM
69yellowbaja View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Rack and Pinion setup on a Baja bug 3 DFWbaja 3245 Rack and Pinion setup ...
 Fri Jan 30, 2015 02:44 PM
what do you use
4 bdrdunes 2660 Baja bug rear led ligh...
 Thu Dec 18, 2014 03:55 AM
No new posts VW Volkswagen & Baja Bug General Discussion oil light
electrical
5 terribletommy 1975 oil light
 Thu May 22, 2014 08:56 PM
