Visitors: 112
Total: 112
38: My Account
54: Event Calendar
84: Pictures
101: Home
102: Home
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- good daily driver?
good daily driver?
The following users give thanks for this topic perrib - Sat Jan 22, 2011 12:13 PM
Grunt-0341
Grunt-0341
Post Post subject: good daily driver?
Posted: Sat Jan 22, 2011 05:58 AM
Crestfallen,
Your bug sure is pretty! I'm in love.
Grunt-0341
81mm Mortar Man
1st Battalion 6thMarines
1985 - 1989
Semper Fi
Rom 1:16
www.infowars.com
www.oathkeepers.org
thepatriots.us/
thext94
thext94
Post Post subject: Re: good daily driver?
Posted: Sat Jan 22, 2011 06:38 AM
JWHracing wrote:
thext94 wrote:
I've never experienced motor problems. As long as you don't bore it out big with a turbo and a bunch of mods you will be ok. a 160 has plenty of power and is very reliable if you treat it right.
not entirely true. would i go 2332 with a turbo on a daily no, but a 1915 and a turbo yes. I run one in my car and it does awesome. good gas mileage as long as you're not in the boost all the time, and has plenty of power when you need it. keep the boost low, and you'll be fine. i run 5 psi on mine and it's great. keeps it reliable but its still fun Smile
Not dissing the more power, sorry if it came off that way! haha I'm sure if its built right it can be just as, if not more, reliable than a stock
Posted: Sat Jan 22, 2011 12:21 PM
Stock heater works well. The big problem is sealing the dash. Large tires kill a 1600 if you stick with 235 75 15 tires the engine will thank you. Installing a 3 rib T-2 transaxle helps. Keeping the engine in proper tune and oil temp in the 180-220 range is essential.
crestfallen
crestfallen
Posted: Sat Jan 22, 2011 09:44 PM
Grunt-0341 wrote:
Crestfallen,
Thanks man! Very Happy
driftmonkeyok
driftmonkeyok
Posted: Mon Jan 31, 2011 08:40 AM
What is a good AT tire for for a baja and what size? I am getting closer to getting one i am going to look at a 63 tomorrow
65bajabug
65bajabug
Posted: Tue Feb 01, 2011 09:32 PM
Yeah JWH no kidding about your boost, hard to keep up with you when you and I are dicking around on the highway
"My car isn't a piece of shit it's custom"
Posted: Wed Feb 02, 2011 02:34 AM
driftmonkeyok wrote:
I have just heard stories of the motors having problems with daily use
My 2332 was a daily driver for many years. Engle FK 10 style cam and 48IDAs never ran hot or pinged. It did end up with a cracked Carillo rod which is almost unheard of for Carillo. Now with a new case rods and crank it is a 2386.
My 2180 is 21 years old and the case and crank are still standard.
The top end has been gone through.
As long as you use good parts and blueprint set it up correctly and keep it
maintained the bottom end should be bullet proof. If you keep the compresion in the 7.0 to 8,0 range, keep the cam mild (Engle W 100, W110 cam with single valve springs the top end will last 60,000 to 100,000 miles. If your not willing to set it up and maintain it just do an Ecotech conversion. The ecm will kep it in tune and be cheaper.
29 AzBaja 31803 Re: "AzBaja Supporting...
 Mon Mar 09, 2009 07:32 PM
cyberjaw4 View latest post
8 AzBaja 3376 photobucket.com is a n...
 Fri Jul 07, 2017 11:37 PM
51 Yummi 28503 Doing good things for ...
 Sat Dec 14, 2013 09:00 AM
No new posts VW Volkswagen & Baja Bug General Discussion made a good score......... 1 vtbaja 1875 Re: made a good score....
 Wed Oct 09, 2013 12:19 AM
No new posts VW Volkswagen & Baja Bug General Discussion Doing good things for a Marine 2 Yummi 2599 Doing good things for ...
 Sun Sep 15, 2013 04:53 AM
