Latest: ecthemc
Overall: 3567
Visitors: 88
Total: 88
02: Event Calendar
15: Pictures
63: Event Calendar
75: Event Calendar
Baja Ghia
1 2 3 ... 7 8 9 10 11
AZsandaddict
AZsandaddict
Posted: Mon Dec 27, 2010 06:25 AM
pictures please!!! Shocked
Freeloader587
Freeloader587
Post Post subject: Baja Ghia
Posted: Tue Dec 28, 2010 04:39 AM
well i know its a bit late now but i found a model at the store i was worken that looked pretty cool
img718.imageshack.us/i/1260406.jpg/
img80.imageshack.us/i/1260405.jpg/
crummy pics but looks good normally
Posted: Mon Jan 03, 2011 04:58 AM
Didn't realize that it has been a couple weeks since I updated the progress. Last time I mantioned that I was going to pick up the trans, well, I did, so fit it in and finished up the upper mount, cleaned up the horns, and did some work on the rear cage.
Also couldn't resist seeing how the power steering resovoir would look. I like it!
Posted: Mon Jan 03, 2011 05:06 AM
Spent some time on part of the wiring. Got the gages and most of the switches put in so decided to go ahead and do the wiring under the dash. Had to make a plate to mount the fuse block and relays. I still have to terminate all the wires coming from the back, and the wiring for the lights and other "front" items.
Since I still have alot more wires to put in, I haven't started to tie them up, but this should neaten up quite a bit.
Also repainted the front beam. Got a little overspray on it.
Posted: Mon Jan 03, 2011 05:16 AM
Yesterday and today I focused on getting the pedals installed. I've been working on these for a while, and quite frankly, they've been kickin my butt. Getting the hole through the firewall in the right place and through all the metal thats in the way, then getting them positioned, which included bending the pedals to get the right clearance, has been a challenge. The result though I think is good. Also made a block for the brake lines out of a piece of aluminum that I had laying around.
Then I hooked up the power steering lines to the torque generator, and installed the fuel pump to the firewall on the passenger side.
Then I got the shocks put back on.
AZsandaddict
AZsandaddict
Posted: Mon Jan 03, 2011 06:06 AM
Damn! Looks good. Don't forget to leave room on the dash for a boost gauge.
Posted: Mon Jan 03, 2011 03:59 PM
I got a spot. If you notice, the gage to the far left is a water temp gage, which now is only good for checking the temp of the water that I drive through.
Posted: Mon Jan 31, 2011 06:13 AM
Time for an update. The car is currently with BajaWarrior getting a few details finished up, but hope to have it back here tomorrow evening. It's looking pretty close to being finished. Had a buddy come over the other day and help me with a few things. Like installing the front and rear windows.
Then we also got the Trans put in, bolted up the motor, and put on the rear cage.
Posted: Mon Jan 31, 2011 06:20 AM
Thought I would add these other two shots as well. The first showing the front shock and brake lines. Got some nice steel braided ones. The second is just a side shot of the car. I really like how the engine and cage made it look so much longer. I think once I get the front bumper on it will look really good. Also bought some different wheels yesterday. Discount Tire was having a sale, and just couldn't pass them up. I figured since the car was coming together, it was looking too good to have the black wheels. New ones are Aluminum with some black accents. Will have pics in a few days.
_-Mad-Max-_
_-Mad-Max-_
Posted: Mon Jan 31, 2011 06:38 AM
looks sweet as hell, one day my ghia will look as nice as this one but a lil different
im in need of a new front clip for my 74 ghia, i dont care what year its from but i need one in order to fix my front end, can anyone help out?
Posted: Wed Feb 16, 2011 06:25 AM
It's a VERY historic day in the life of "BajaGhia". It RUNS!!!!! Very Happy Been working pretty hard on it the last few days, getting all the little things hooked up, filled up and wired in, but it all paid off today. The power steering is going to be sooooo nice. Really glad I put that on. Here are a few pics of the engine. Had to make a bracket to support the oil cooler and filter, then find a spot for the coil and breather box. Things started to get a little tight, but looks like it will all work. I will have to keep an eye on the temps........having preheated air from the oil cooler blowing down on the engine probably isn't the best idea, but was limited on space, plus with the air coming through the scoop, think I will be ok.
Posted: Wed Feb 16, 2011 06:32 AM
Have done a few other things too. Got a new set of wheels. The others just did not go with the car.
Got the fuel tank mounted up front.
Couple pics of the interior, finished door panel, and shot of the brake and clutch lines. Got them all hooked up, and will bleed them tomorrow.
CherokeeBug
CherokeeBug
Posted: Wed Feb 16, 2011 07:24 AM
Absolutely sick. Looks great.
And when he sees Saint Peter he will tell, One more soldier reporting sir, for I have spent my time in HELL!!!!!
-1959 Baja, 1600dp, 1 piece front-tilt nose, Centerline wheels, and more to come.
-2001 Jeep Cherokee, 6.5'' LA lift, lockers, gears, D44 axles, 4.7L stroker kit, 4:1 Transfer, Lots & Lots More. Done. -1985 Monte Carlo SS
Grunt-0341
Grunt-0341
Posted: Sat Feb 19, 2011 08:15 AM
Looking good!!!
Grunt-0341
81mm Mortar Man
1st Battalion 6thMarines
1985 - 1989
Semper Fi
Rom 1:16
www.infowars.com
www.oathkeepers.org
thepatriots.us/
jk97
jk97
Posted: Sat Feb 19, 2011 03:43 PM
Wow. Nice work.
Jim
jk97
'66 Berry Mini-T IV
4 Admin_AzBaja 5071 Baja Bugs on Wiki need...
1567 mufasavnvmc 839411 what did you do to you...
 Tue Aug 15, 2017 03:29 AM
285 MusicManiac 205949 Re: Baja sightings
Off-road event
1 wideopenmotorsports 145 Re: Baja run in March
 Mon Jan 08, 2018 05:09 PM
No new posts VW Volkswagen & Baja Bug General Discussion Considering buying a Baja Bug, but I have questions 4 AutomotiveDino 3145 Considering buying a B...
 Mon Jun 19, 2017 09:39 AM
daelan37 View latest post
