Latest: strike77
Overall: 3575
Visitors: 112
Total: 112
06: Home
39: Event Calendar
48: My Account
52: Home
69: Home
84: Event Calendar
89: Event Calendar
91: Event Calendar
Baja Forums -:- AzBaja.com Members -:- New Members -:- New guy building a Baja
frog187
frog187
Post Post subject: New guy building a Baja
Posted: Sat Jan 29, 2011 05:17 AM
Newbie here and I will post pictures as soon as I get a new cable for my new blackberry.
This will be my first Baja, and my second VW. I'm a newbie but learning a lot of information. I had an extra pan that I tried to sell but after a not getting close to what I wanted and going off roading for the first time in over 10 years a couple of weeks ago the Baja was planned out.
Today I picked up my 3X3 trailing arms and widened beam today from Bugzyla and as soon as payday comes I will be getting some tires for my chevy nomad 1 rims.
The plans is to run disk all around with press in studs with chevy pattern, 1915 singleport (being built by Daryl shortly), Single side Cover Irs trans (superdiff), 31 back/15x7.00 front, Narrow eye baja Kit, and modern Fuze block.
By the way my name is Matthew and I work at Luke AFB. I just moved to Goodyear from Avondale and hoping to get to the Baja on the trails by the end of Febuary.
What Is A *Veteran? Whether active duty, discharged, retired, or reserve -- is someone who, at one point in his life, wrote a blank check made payable to \"The United States of America,\" for an amount of \"up to, and including his life.
Post Post subject: Re: New guy building a Baja
Posted: Sat Jan 29, 2011 05:21 AM
Welcome to AZBAja. Sounds like your off to a great start. While you building the transaxle get 3/4 gear ratio change to reflect the larger tires.
Grunt-0341
Grunt-0341
Posted: Sat Jan 29, 2011 08:46 AM
Welcome. It looks like you have a great project. I can't wait for the pics.
Grunt-0341
81mm Mortar Man
1st Battalion 6thMarines
1985 - 1989
Semper Fi
Rom 1:16
www.infowars.com
www.oathkeepers.org
thepatriots.us/
Posted: Sat Jan 29, 2011 08:07 PM
Stop in for the Pizza event and have some Pizza. No car needed.
alos welcome to the site.
4 Admin_AzBaja 5895 Baja Bugs on Wiki need...
1568 mufasavnvmc 925228 Re: what did you do to...
285 MusicManiac 223483 Re: Baja sightings
0 Northmountainauto 642 Shop Baja
No new posts New Members Baja hiding in Chandler 9 Upsbaja 2271 Baja hiding in Chandle...
