Latest: BlackIrish05009
Overall: 3574
Visitors: 129
Total: 129
12: Event Calendar
20: Event Calendar
28: Event Calendar
36: My Account
47: Event Calendar
58: Pictures
64: My Account
87: Event Calendar
112: Event Calendar
118: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- 61 bug swing axle to 67 bus swing axle help
pussiwillow
pussiwillow
Post Post subject: 61 bug swing axle to 67 bus swing axle help
Posted: Thu Jan 27, 2011 03:06 AM
i have a 1961 baja project im working on, its got a 60 bug swing axle in it also know as the crash box, no first gear syncros means no downshifting into first without grinding the thing to death. I am getting a real sick deal on a 67 bus swing axle trans and am wondering if my exsisting bug axles with fit the bus trans? i cant find any info anywhere on it... thank you!
Post Post subject: Re: 61 bug swing axle to 67 bus swing axle help
Posted: Thu Jan 27, 2011 04:55 AM
Yes the axles will interchange, BUT you will have to flip the differential in the bus trans before you install the axles. If you dont you will have 4 reverse gears and only one forward gear. You could always buy a set of Bugzyla Adapters and bolt the bus trans in as is with the reduction boxes and gain 3 inches of lift. Cool
pussiwillow
pussiwillow
Posted: Thu Jan 27, 2011 06:37 AM
i got alot of work left on this thing, the trans is practically free, so i was gonna swap it in next up will be stock width warrior beam and fox shox, future plan is irs this is to hold me over so i can drive it
im still learning as i go, is the 67 bus trans a good trans to put in?
Posted: Thu Jan 27, 2011 08:19 AM
Yes, its the same as a bug trans with the exception of flipping the diff.
pussiwillow
pussiwillow
Posted: Thu Jan 27, 2011 08:44 PM
Bugzyla thank you for all the info!
Gettinsomeair
Gettinsomeair
Posted: Fri Jan 28, 2011 07:39 AM
hey if you get tired of the 67 tranny I would be interested if it has the reduction boxes
\"Life is short, drive a Volkswagen naked\"\r\n\r\nBug Nakked VW Club Dover,Arkansas
16 DerekT 3256 Axle's needed
 Sat Dec 10, 2016 07:17 PM
No new posts Projects and Builds Swing Axle Dual Shocks 2 dave46 3477 Re: Swing Axle Dual Sh...
 Fri Sep 11, 2015 08:06 PM
dave46 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion needed asap swing axle trans 5 Dirtjunkie 2590 needed asap swing axle...
 Fri Oct 12, 2012 06:10 AM
No new posts VW Volkswagen & Baja Bug General Discussion another rear axle question 3 onthefarm 2588 another rear axle ques...
 Sat Aug 04, 2012 05:22 AM
onthefarm View latest post
No new posts VW Volkswagen & Baja Bug General Discussion swing to irs 1 Luckyvw13 1700 Re: swing to irs
 Wed Apr 27, 2011 03:56 AM
