Latest: strike77
Overall: 3575
Visitors: 135
Total: 135
29: My Account
43: Pictures
45: My Account
46: Event Calendar
50: Pictures
53: Event Calendar
55: Pictures
64: Event Calendar
81: Pictures
82: Event Calendar
118: Event Calendar
121: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- wanting feedback on 3 x 3 rear arms
ROCKSLAYER
ROCKSLAYER
Post Post subject: wanting feedback on 3 x 3 rear arms
Posted: Wed Dec 08, 2010 05:56 AM
im building a baja and was wanting to get some feedback on rear trailing arms.my plans are 3 x 3 arms,930's to 091 trans,coilover set up,disc brake.what are some of you guy's running? whats the pros & cons of your setup.any feedback would be greatly appreciated.im looking seriously at #1 a set from bugzyla (i got a ball joint/link pin conversion beam 8" wider 8" towers 2x1 arms w/combo spindles from him.im really impressed with the great craftsmanship & the super excellent service) #2 aset of chromemoly arms from race ready.some feedback would be great.i hate to toss a coin to figure this one out.thanks ed from bellemont az Cool Cool
Baja_Blue
Baja_Blue
Posted: Wed Dec 08, 2010 06:00 AM
Nearly the same question asked here...
inlandbajas.yuku.com/topic/230
Matthew 5:14-16
ghettodish
ghettodish
Posted: Wed Dec 08, 2010 09:05 AM
You may want to go with 5x5 or 6x6 rear trailing arms. Your front track is gonna be waay wider than the rear.
Hey Blue: You got a link for Laser Innovations? I wanna check them out after following your above link.
Baja_Blue
Baja_Blue
Posted: Thu Dec 09, 2010 08:39 AM
Yeah from what I've heard they are insanely expensive because they have to make everything custom from 'laser' machines.
Blindchickenracing is a much better I have heard nothing but good feedback from those who use their trailing arms.
Matthew 5:14-16
ikill6453
ikill6453
Post Post subject: Re: wanting feedback on 3 x 3 rear arms
Posted: Fri Dec 10, 2010 03:58 AM
i have the 3 x 3 set up with 930's going to a 3 rib bus tranny, king coilovers ... have had no problems at all.... and i beat the daylights out of my rail....
if you want to see some build pics i have a good album on photobucket.com search ikill6453 then look for my album called my rail the build.
now in hind sight if i had a choice i would have gone with wider ... but the only problem with that is if you trailer or go on narrow trails.
post pics of your build.... show us.
keep us posted.
Posted: Sat Dec 11, 2010 01:53 AM
Mine is 3x3 in the rear and 6" wider front beam. Rim offsets will affect track width. Zero offsets are best. If you make your front track an inch or two wider that would be fine as you'll know for sure if you can make it through narrow spots.
Posted: Wed Jan 19, 2011 08:45 PM
Having the front and rear track (properly measured at the center of the tires, not as an overall dimension) somewhat different produces a more stable car. It doesn't really matter which is wider for the stability. It's like dragsters...they used to use a very wide front and very narrow rear, these days the front is narrower than the rear.
A +6 beam and 3x3 rear is a good match with the front tires narrower than the rear.
ikill6453
ikill6453
Posted: Wed Jan 19, 2011 11:41 PM
rockslayer....follow the forum for chassis and suspension... there is a guy on there that is getting great info...he is asking some good questions .
post pics when you get them....
Posted: Thu Jan 20, 2011 06:25 AM
Tire & wheel combo makes a big difference on track width. On my fasty I have 33x12.50-15s rear with 15x10 wheels & min offset. Front are 30x9.50-15s with 15x5 wheels min offset. Rear is 3x3s and the beam is 10 over, the rear is 3 inches wider that the front.
BCR builds their arms as a boxed stock style arm, only problem I have ever had with their arms is not enough clearance for 930CVs without some slight mods. We build ours tubular with plenty of clearance.
Here is a pair of our 3x3s.
ROCKSLAYER
ROCKSLAYER
Posted: Fri Jan 21, 2011 05:53 AM
thanks for the input guys.i really like the looks of the bugzyla arms.anyone on here using these? hopeing to get started back on the baja project again soon.my dad passed away on the 12th & the funeral expenses kindof ate up my bug fund.
jon6.0
jon6.0
Posted: Thu Jan 27, 2011 07:01 AM
You should buy the whole rear off my Baja, lol. 3 rib bus box, 930's, tubular 3x3, axles, and disc brakes. I can make it a package deal if you do want it all. It's even at Daryll's, so he could swap everything over for you.
1967 Baja
2005 GTO
2009 Speed Triple
No new posts VW Volkswagen & Baja Bug General Discussion Max angle for rear axles 5 Wattsd 3202 Re: Max angle for rear...
 Fri Jan 29, 2016 05:03 AM
Wattsd View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Rear Rim Backspacing 1 LittleBaja 1897 Rear Rim Backspacing
 Fri Nov 06, 2015 04:13 AM
JWHracing View latest post
what do you use
4 bdrdunes 2475 Baja bug rear led ligh...
 Thu Dec 18, 2014 03:55 AM
No new posts VW Volkswagen & Baja Bug General Discussion [ Poll ] Wanting to get some opinions 2 Cadillric 2453 Re: Wanting to get som...
 Mon Sep 24, 2012 04:10 AM
blubaron66 View latest post
No new posts Projects and Builds Possible rear seat?? 4 TattooedIrish 3821 Possible rear seat??
 Thu Aug 30, 2012 08:55 AM
Rigger View latest post
