Visitors: 58
Total: 58
18: Pictures
46: Links
1 2 3 ... 52 53 54 ... 103 104 105
Baja_Blue
Baja_Blue
Posted: Sun Nov 14, 2010 04:41 AM
Got a new alternator, adjusted valves, set the timing, richened in up very slightly, runs fantastic! Hopefully get some 28mm Torsions before thanksgiving weekend!
Matthew 5:14-16
DanMach
DanMach
Posted: Mon Nov 15, 2010 04:50 AM
Was sad because its in the shop having someone else sort the brakes out.. which is a good thing. 3 master cylinders total now have been bad. The original, my replacement from Chirco, there chinese one and finally the good one I bought from a friend. I think I would of gone insane after the 3rd bad one.
Sometimes you just have bad luck Sad I was hoping to get it back today so I could repair the fiberglass upfront, but no such luck.
71 Baja, 1600, WIP
ghettodish
ghettodish
Posted: Tue Nov 30, 2010 09:03 AM
Picked up a 3 rib tranny and cut the back off of my '70
ghettodish
ghettodish
Posted: Thu Dec 02, 2010 05:08 AM
Pulled the motor. Tranny is next...gotta make room for the 3 rib tranny I picked up 2 days ago.
Rybob
Rybob
Posted: Thu Dec 02, 2010 07:01 AM
Sanded down drums and touched them up, and my fender beading is done on the front! Also cleaned up my rear engine cage mounts.
All thats left on my list before its driveable
Install Lights (i have them already)
Install Engine (have it too haha)
Finish factory trim and fenders!
Then Im done B)
(o\|/o)
Posted: Fri Dec 03, 2010 07:56 PM
Vacuumed, washed and loaded it up to go work Tech at the MORE Toys for Tots Holiday 200 Desert Offroad race at Barstow. The drive over there will be about an hour and 15 with about 1/2 of the miles on dirt. I may be going to work, but at least I get a fun commute to work!
Baja_Blue
Baja_Blue
Posted: Sun Dec 05, 2010 06:44 AM
Gave her a nice bath. Wash/wax. Cleaned and vacuumed the interior, shampoo'd the carpet. Cleaned up the engine. shiiiiiny stuuufff Cool
Matthew 5:14-16
Posted: Mon Dec 06, 2010 12:02 AM
I get to wash it again. Now that I've taken it across the desert, it's dirty again. Got some sprinkles yesterday, so it's more than just dust.
But it got used offroad in between. And that's the bottom line.
Well...On second thought...Mother Nature says If ya wanna wash your car, I'll help! It's raining now...Guess I won't wash it now...
Baja_Blue
Baja_Blue
Posted: Wed Dec 08, 2010 04:25 AM
Finally got a dust light. Really pissed me off almost getting run over by a few high nosed V8's in Ocotillo that didn't see my dim little 68 tail lights, so I gave in and got one. this thing is so bright!
Matthew 5:14-16
Posted: Thu Jan 06, 2011 05:54 AM
Put the rear and quarter windows in my sons baja "Wiily Style" Started working on installing the front seats (out of a subaru wagon) but ran out of time, maybe tomorrow.
Posted: Mon Jan 10, 2011 06:03 PM
Got the seats in yesterday and went to BAP where we picked up everything we needed to nrebuild the pedals and get them installed along with the cv axles.
Wheel_Works
Wheel_Works
Posted: Mon Jan 10, 2011 09:49 PM
I cut most of the front clip off to make way for the 1 pc carbon fiber front end
Posted: Mon Jan 10, 2011 11:58 PM
This week end I looked at the Baja... Smile
Rybob
Rybob
Posted: Tue Jan 11, 2011 01:51 AM
Figured out i might just need a wiring harness! gahh! Oh well, electrical is the last thing on the NEED to do list.
(o\|/o)
Posted: Thu Jan 13, 2011 01:51 AM
I picked up my bug from Bugzylla. Since then, I tightened all my fuel line hose clamps and the fuel sending unit (small leak that stunk to high heaven!), washed and vacuumed it, painted some areas with flat black paint, refastened the right headlight ground wire, trimmed and pounded the inner lip that was contacting the front tires at lockout and discovered that I need a dipstick.
4 Admin_AzBaja 5221 Baja Bugs on Wiki need...
285 MusicManiac 209460 Re: Baja sightings
Off-road event
1 wideopenmotorsports 372 Re: Baja run in March
 Mon Jan 08, 2018 05:09 PM
No new posts VW Volkswagen & Baja Bug General Discussion Considering buying a Baja Bug, but I have questions 4 AutomotiveDino 3312 Considering buying a B...
 Mon Jun 19, 2017 09:39 AM
daelan37 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion What is my Baja really worth? 1 Treeposter 948 What is my Baja really...
 Sat Jun 17, 2017 04:06 PM
