Latest: thelataviayoung
Overall: 3584
Visitors: 115
Total: 115
06: Home
13: My Account
48: Event Calendar
51: Pictures
57: Home
81: Home
85: Home
92: Home
95: Pictures
111: Pictures
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- need some radio info... car to car on the road/trail
ikill6453
ikill6453
Post Post subject: need some radio info... car to car on the road/trail
Posted: Tue Oct 19, 2010 08:12 PM
who is the radio/communication guru?
after this last weekends run to crown king i can see the need for a radio in my rail. what radio is the best? or maybe i should ask for a good better and best kinda answer. i am looking for a handheld with remote mike.
what channels/freq. are you on and where to buy one.
perri offered me a radio last weekend but i didnt want to loose it or break it. i hate breaking other peoples stuff but dont mind breaking mine.
other than that the run was great and will go next year .... got some good pics and couple of movies i will try to post.
mike
"MY RAIL"
Post Post subject: Re: need some radio info... car to car on the road/trail
Posted: Tue Oct 19, 2010 10:21 PM
That was a UHF Motorola radio set to 451 mhz.
azdesertrat87
azdesertrat87
Posted: Mon Nov 08, 2010 07:48 PM
we run the uhf radios because we got so tired of jerks on the cb messing around with us and there only good for a few miles on flat land these new radios are awsome I've been at the cinders in Flagstaff and talked to clubbers in Flagstaff thats far! plus since we have our own frecuency no one else can break in, some in our club also run headsets with an intercom setup so you can talk with your passenger, call out, recieve a call or listen to music all in your headset no external noises like engines or tires! really neat
DanMach
DanMach
Posted: Mon Nov 08, 2010 08:29 PM
Excuse my ignorance.. but is UHF considered under the CB airwaves then? If so, whats the difference between just standard 27 mhz CB and the UHF? What makes it less likely to be played with by other CB guys. Is it just more expensive equipment or something?
71 Baja, 1600, WIP
azdesertrat87
azdesertrat87
Posted: Tue Nov 09, 2010 02:38 AM
Don't know for sure all I know is that some trucker on a souped up cb can't heckle ya out on the trail, I guess all the race teams use this set up and the duners too its got fantastic range
DanMach
DanMach
Posted: Tue Nov 09, 2010 08:30 PM
Hmm I'll have to google it or something... I mean really any jerk can fire up a 100watt transmitter and set any frequency and everyone trying to use that frequency in a pretty large area is screwed..
Was just curios what made UHF less vulnerable to that. Maybe a line of sight issue.
71 Baja, 1600, WIP
6 AZOffroadSwapmeet 3438 AZ Off-Road Swap Meet
 Fri Dec 09, 2016 02:37 PM
No new posts Events and Get Togethers World Wide Annual 400 Miler Off Road Run/Campout May 16-17th 6 azdesertrat87 5984 Annual 400 Miler Off R...
 Tue Feb 09, 2016 03:23 AM
No new posts Events and Get Togethers World Wide 4-5 hour trail ride 11/28/15 7 Azdrtdog 3635 4-5 hour trail ride 11...
 Tue Dec 01, 2015 04:09 PM
No new posts Events and Get Togethers World Wide august trail days 0 gman3850 2217 august trail days
 Fri Jul 24, 2015 10:10 PM
gman3850 View latest post
No new posts Projects and Builds When Off Road Racing Was... 4 wideopenmotorsports 5358 Re: When Off Road Raci...
 Sun May 10, 2015 12:35 PM
