Visitors: 168
Total: 168
01: Pictures
20: Event Calendar
36: My Account
41: Home
54: Event Calendar
70: My Account
95: Event Calendar
128: Links
154: Baja Forums
161: Event Calendar
162: Baja Forums
163: Event Calendar
165: Event Calendar
168: Baja Forums
1 2 3 ... 50 51 52 ... 103 104 105
FLBaja
FLBaja
Posted: Tue Oct 19, 2010 03:53 PM
While washing the baja after a weekend of hell-raising I discovered a pretty good sized oil leak around the factory cooler.Picked up some new seals and gonna pull it apart tonight. Hopefully its just the seals and not the cooler
bajaboi727
bajaboi727
Posted: Tue Oct 19, 2010 08:05 PM
Fixed my leaky valve covers, and pulled off the side bars to get them ready to be painted. Hopefully they'll turn out as I'm hoping.
Baja_Blue
Baja_Blue
Posted: Tue Oct 19, 2010 10:00 PM
Got quite a bit done today!!
Replaced the throwout bearing assembly and painted the bell housing...
Replacing the clutch cable is a really really big PITA to do, you have to pull the whole pedal assembly...
Pulling the old cable out...
My cable was just a bit frayed lol
Finding the little tube inside the tunnel is probably what took me the longest, you gotta have really small fingers, which I don't have so I spent almost 20 minutes just trying to get the new cable in the little hole lol
Just a heads up if you plan on replacing your clutch cable don't make the same stupid mistake I did. I got it all back together, thought I was good to go, pushed the clutch petal and it stayed on the floor...noooooooo. Pull the assembly and when I was putting it back together I didn't realize the dumb german design allows for the cable to come off the hook while it's inside the tunnel!!! so I wrapped some bailing wire around the hook and put it back together and it's good to go lol
Tada! All back together with a new clutch cable!
Matthew 5:14-16
1969Baja
1969Baja
Posted: Wed Oct 20, 2010 03:31 AM
Went to BAP to pick up CV parts to repack the joints. Was driving home and the bug died on the on ramp to the 51....OUT OF GAS!!! So i spent the day running 2 miles to a gas station in sandals to get a couple tanks of gas. And When i got home I noticed i forgot to put the gas cap back on. Frack!!! so today....My baja got a new gas cap! Smile
crickifur
crickifur
Posted: Wed Oct 20, 2010 03:50 AM
Hey atleast yours is runnin right now my friend hahaha
Posted: Wed Oct 20, 2010 05:49 AM
Drove it to work after welding reinforcment plates over the cracks(which were also welded) in the pan head. To make a long story short it was cracking from where a channel was put in for the long tie rod. Feels much safer now and isnt creaking anymore HAHA.
crickifur
crickifur
Posted: Wed Oct 20, 2010 06:18 AM
WOOHOO!!!! congrats eric atleast one of our cars is back up lmao
Rybob
Rybob
Posted: Wed Oct 20, 2010 06:23 AM
Looked at it, thought Gahhh! This needs to be done already, and then finished my fenders and exhaust.
(o\|/o)
Posted: Thu Oct 21, 2010 09:47 PM
Good choice getting the "fully welded" cross shaft.
bajaboi727
bajaboi727
Posted: Thu Oct 21, 2010 10:10 PM
Painted the side bars.. turned out great!!
FLBaja
FLBaja
Posted: Sat Oct 23, 2010 05:33 AM
Fixed the oil leak at the cooler, changed the oil, cleaned and reoiled the airfilters, but it appears I still have another leak to track down Sad
crickifur
crickifur
Posted: Sat Oct 23, 2010 06:48 PM
WELL! I attempted to fix the busted spot in the crank case. (When attempting to change the pulley seal, i some how managed to pull out a chunck of the case around the seal flange. Seeing as I dont have the $$ for a new crank case OR to get my other engine completely done, I decided to JB weld it. I KNOW its not what everyone would recommend and trust if I had the money to tear the engine back down right now I WOULD, but Im pretty confident this will work great for now. I ground everything down so it was nice and rough, v channeled along the cracks and got it in everywhere really well. If this repair gets me til Jan, Ill be happy. Ill finish putting together my other engine and buy a new case for this one so I have a spare engine. WISH ME LUCK! If this doesnt work, no car for me for Hasayampa... Sad
thext94
thext94
Posted: Sun Oct 24, 2010 01:22 AM
painted rear fenders and sides black. also filled door molding holes with rivets
Tyler
Rybob
Rybob
Posted: Sun Oct 24, 2010 02:27 AM
Dang that looks GOOD! Very Happy Good idea on the rivets looks good and keeps moisture out. Mind if i ask what that is you used for paint?
(o\|/o)
1969Baja
1969Baja
Posted: Sun Oct 24, 2010 02:42 AM
Adjusted the bajas valves, changed oil and put new valve cover gaskets on of course! Runs amazingzingggglylyly!
4 Admin_AzBaja 6309 Baja Bugs on Wiki need...
285 MusicManiac 233399 Re: Baja sightings
No new posts VW Volkswagen & Baja Bug General Discussion Had to go play in the rain today! 3 azdesertrat87 666 Re: Had to go play in ...
0 Northmountainauto 1125 Shop Baja
No new posts New Members Baja hiding in Chandler 9 Upsbaja 3269 Baja hiding in Chandle...
