Visitors: 99
Total: 99
10: Home
46: Pictures
55: Event Calendar
95: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Roof rack help..
Roof rack help..
bajaboi727
bajaboi727
Post Post subject: Roof rack help..
Posted: Sat Oct 09, 2010 12:20 AM
I'm fabbing up my own roof rack and was wondering what others have done for attachment ideas. Can I buy the drip rail attachments somewhere and weld them to my roof rack? Or how have you guys done yours? pictures are amazing, I'd like to get a few ideas. Smile
Posted: Sat Oct 09, 2010 02:16 AM
mine is attached to my roof via the drip rails. mine mounts the same way a stock roof rack does, since that's basically what it is.
your other option is to mount it through the roof to the roll cage. it all mostly depends on what you're using your roof rack for. i have mine mounted to the drip rails, and i use my rack for bikes and an ice chest typically.
bajaboi727
bajaboi727
Posted: Sat Oct 09, 2010 12:50 PM
And that seems to be strong enough? Yea, I'd use it for the ice chest, chairs, and that kinda stuff for camping etc. and to mount some back up lights.
Posted: Sat Oct 09, 2010 05:14 PM
for what mine is it does fine. i've never had a problem with it. it stays on there just fine. In my opinion too, it is better to have it mounted to the drip rails and not the roll cage because if there is a chance of you rolling the car, the drip rail mounted rack won't have an effect on the cage if you put the car on its lid.
bajaboi727
bajaboi727
Posted: Sat Oct 09, 2010 07:15 PM
Yea, that makes sense...Is there any where I can buy just the drip rail mounts? I'm gonna be ambitious and make my own roof rack... Smile
Posted: Sat Oct 09, 2010 07:41 PM
i'm not sure where you can buy them, but i know they do sell them. i've seen them online before. you could also make your own as well. i have a feeling if you're gonna make your own rack you should be able to fab up some mounts.
bajaboi727
bajaboi727
Posted: Sat Oct 09, 2010 09:11 PM
haha... actually.... It's going to be a learning thing. I've got minimal play time with a welder, but my buddy who welded for a living the past few years is going to help me out, basically with the heat settings and what not. we'll see how it goes. ....
Posted: Sun Oct 10, 2010 12:38 AM
clamp 1
clamp 2
here's what's used on a stock vw rack. mine uses the second style.
Brettucks
Brettucks
Posted: Sun Oct 10, 2010 02:58 PM
Mine bolts on through the roof with 1/2-13 bolts through the bottom..
I cant think of any particular reason this would be better except maybe it could be handy if you needed to winch on it or a sllight advantage in being able to put more weight on it with no fear...
-Brett
bajaboi727
bajaboi727
Posted: Sun Oct 10, 2010 05:22 PM
Do you have any problems with the eye bolt hitting the roof? At the Haysayampa day, I wanna check out those clamps... I've never paid much attention to how they clamp exactly because I've never wanted one on our street bugs...
Posted: Sun Oct 10, 2010 09:11 PM
they don't come close to the roof on mine. i also trimmed mine a bit because they were too long for the locks i use.
bajaboi727
bajaboi727
Posted: Mon Oct 11, 2010 08:02 PM
I wanna check them out next time I see your car..
No new posts VW Volkswagen & Baja Bug General Discussion Cool VW Bug Roof Rack 0 wideopenmotorsports 1789 Cool VW Bug Roof Rack
 Wed Jun 15, 2016 09:46 PM
No new posts VW Volkswagen & Baja Bug General Discussion Rack and Pinion setup on a Baja bug 3 DFWbaja 2453 Rack and Pinion setup ...
 Fri Jan 30, 2015 01:44 PM
No new posts VW Volkswagen & Baja Bug General Discussion Roof Scoop?
16 mikehtiger 23164 Re: Roof Scoop?
 Thu May 31, 2012 06:00 PM
msligar View latest post
No new posts VW Volkswagen & Baja Bug General Discussion rack & pinion w/stock fuel tank 0 ghettodish 1628 rack & pinion w/stock ...
 Wed Nov 09, 2011 06:44 AM
ghettodish View latest post
No new posts VW Volkswagen & Baja Bug General Discussion I need a roof rack? 5 homeshark66 7091 I need a roof rack?
 Mon Jun 06, 2011 06:53 PM
DustinT3 View latest post
