Visitors: 127
Total: 127
12: Event Calendar
59: Links
62: Event Calendar
87: Event Calendar
95: Event Calendar
106: My Account
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- baja got hot
baja got hot
green68coup
green68coup
Post Post subject: baja got hot
Posted: Wed Oct 06, 2010 11:01 PM
I have a 74 baja beetle with a 1600 and one day on my way to work my belt broke and the engine got hot enough to melt the plug wires and stop running i got it home and replaced the plug and wires and it started up and ran but the day after that it wouldn't start i wondering if the pistons are the cylinders might have warped and when it ran for a little bit it wore the rings down and lost compression the motor cranks just no compression any ideas this is my first vw and i only had for about three weeks before this happened i really like driving and playing in it and hope to get it going again thanks for any help
Posted: Thu Oct 07, 2010 04:29 AM
Probably cooked the motor, Air cooled means moving air. When the belt broke you stopped moving air. I see a rebuild in your near future.
Post Post subject: Re: baja got hot
Posted: Thu Oct 07, 2010 03:51 PM
X2 . Adjust your valves a nd it should start. I have seen them get hot and the valve spring get so weak the won't acelerate until they get changed.
If it runs start building a new engine right away.
green68coup
green68coup
Posted: Fri Oct 08, 2010 01:44 AM
Thanks guys i was just going to replace the pistons and cylinders and have the heads inspected are rebuilt. A mechanic told me if there isn't any play in the crank pulley the bearings are OK is this true?
Posted: Fri Oct 08, 2010 04:33 AM
Maybe but if you don't have a good full flow oil filter they might not be very pretty and you never will know if it got hot enough to get center gap.
Posted: Sat Oct 09, 2010 12:51 AM
I gotta ask, did you not have a GEN light come on when the belt broke? I guess 74' would've had a an ALT light but still.. That's usually the first sign that the belt may have slipped off or broken.....
green68coup
green68coup
Posted: Mon Oct 11, 2010 02:07 AM
no i didn't have an alt lite come on it must not be hooked up Ive been asked that by few people but when i do get it going i will figure that one out differently need it. I order new mahle pistons and cylinders do they come already ringed in the cylinders thanks
Posted: Mon Oct 11, 2010 02:42 AM
Often you won't notice the tiny warning lights or even a guage. Mahle P&L sets come with the ringds but the cylinders need washing with hot soapy water and the rings clocked correctly.
Posted: Mon Oct 11, 2010 02:58 AM
I guess I'm just a nervous nanny. I'm always looking at my lights/gauges for fear of a problem. Maybe I need to install a buzzer... Rolling Eyes
Anyway, good luck with the rebuild if that's the way you go.
Posted: Mon Oct 11, 2010 03:02 AM
Buzzer,horn large lights are good since ff your going fast enough your eyes ignore small lights.
5 Admin_AzBaja 8407 Baja Bugs on Wiki need...
1569 mufasavnvmc 1061910 Re: what did you do to...
 Sat May 11, 2019 07:20 PM
285 MusicManiac 255999 Re: Baja sightings
No new posts VW Volkswagen & Baja Bug General Discussion FREE VW BAJA'S 0 azdesertrat87 1257 FREE VW BAJA'S
0 Northmountainauto 2197 Shop Baja
